WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
- Sep 29, 2008
- Western PA
Yea I always use OEM top seals. The Hepu fits better though than an OEM pump. I had an OEM pump before the Hepu and it never fit quite right.
Y'wanna know why? The top seal Hepu supplies is garbage, so it compresses easily, making it real easy to thread the screws. In a year or so, you'll have a leak. I did. Twice. I replaced two pumps with Hepu's at the same time, both failed there after the same number of miles. I've done countless B230/B234 water pumps, and never had a leaker.
On stamped impellers in OEM pumps: Lotsa "I know best" in the community on this subject. I never had a problem with cooling. I did a water pump on an XC-90 T6 and was surprised to see a nearly identical impeller on that pump. For 6 cylinders, and two turbo's!
Best thing you can do is go Hepu with seals from Volvo, but then you're paying as much or more than OEM. OEM Pump from Tasca is $71 as of last night.
-Ryan
I have always purchased the GMB units...
No bad reports to share.
Didn't know Bosch was in that bizz.
Welp, I'm 3 for 3 on the last Hepu top seals leaking within a year.
I chose a HEPU pump for the first and only time ...
After 1 year and 20K miles ...
It failed at the shaft seal.
The Kool-aid is strong. Post #26
What is the latest verdict on water pumps?
