Owsley
- Dec 3, 2008
- San Francisco
Sent the '87 240 to the independent Volvo mechanic. He charged it (again) with R134a. Barely gets cool. He put an R134a splice with fitting in the low pressure hose, but did nothing on the high pressure side and says it's hard to get to. He will only charge by low pressure readings. Without checking high side pressure, how do I know if the problem is the compressor or something else? He talks about the sight glass, but from what I understand, with R134a, reading the sight glass is ineffective. The guy who did an older Japanese car of mine said he charged by weight only. I know I'm not going to get 30 degrees, but I should be getting better than I am. What's the next step? I'm looking for advice, whether by tweaking R134a or going hydrocarbon. I'd really be ok with doing hydrocarbon, but every time I check a thread on it, it either dies or is pretty inconclusive. You can prvt me if you don't want to post to the thread. If I'm going to blow something up, I'd rather it not be MY car.
