Old 02-26-2012, 04:49 AM   #26
Mr. V
Mr. V's Avatar
Originally Posted by scottyd View Post
Look up "chinese water torture" if you really want to do it.
Here ...
http://forums.turbobricks.com/showthread.php?t=35053
Old 02-26-2012, 06:27 AM   #27
Snake oil.
Old 02-26-2012, 08:15 AM   #28
Fivehundred
Fivehundred's Avatar
Snake oil.
Fivehundred is offline   Reply With Quote
Old 02-26-2012, 12:00 PM   #29
photoman327
photoman327's Avatar
Originally Posted by jfleganscca View Post
When I have used it, 1/3 can through vacuum hose and 2/3 can in the fuel tank, I have always had good results. 2-3mpg gain. I do have to agree with the others in regards to getting mixed results. I sell a ton of it at a NAPA and I have heard horror stories when the local dumba@@ hicks get it wrong. But I have never had any negatives from it.
this is the second post that come with a 2-3 mpg increase. scared to put it in a vac line and water also would clean carbon. That is too over the top for me. I run this this stuff in the gas of my weed eater and lawn mower. It just works for me period.
Old 02-26-2012, 02:30 PM   #30
I'm just surprised you guys pay too much money for snake oil that you could home brew.
Old 02-26-2012, 02:59 PM   #31
vlvman
vlvman's Avatar
Water or ATF has always worked well for me, in the intake. In the tank I use kerosene and ATF. As for the crankcase, just run good oil.
Robert
http://www.volvowiringdiagrams.com/
82 244DL, 2004 S60R AWD, 2008 S40 GF's
Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T
vlvman is offline   Reply With Quote
Old 02-26-2012, 03:21 PM   #32
83Rabbit
Not sure how well it cleans engines but Ive used it to soak various injectors, parts, etc in and its GREAT in that regard.
83Rabbit is offline   Reply With Quote
Old 02-26-2012, 04:10 PM   #33
http://www.google.com/products/catal...wAQ#ps-sellers
Old 02-26-2012, 09:30 PM   #34
RepairmanJack
South-City Volvoman
RepairmanJack's Avatar
The guys at IPD recommend the stuff. I have a can for my tranny, but I've never used it. I've never heard anything bad about it.
_________________________
Feedback Profile http://forums.turbobricks.com/showthread.php?t=249486
RepairmanJack is offline   Reply With Quote
Old 02-26-2012, 10:27 PM   #35
smokeyfan1000
Guest
I'm surprised they buy cheapo gasoline, and try to fix the excess carbon build up with Seafoam. Run Amoco 91 Octane religiously and a can of Chevron FI Cleaner, every other 3000 miles, and/or a can of Ventil Sauber, "blow it out good" on the hiway once in a while and you'll have little need for Seafoam IMO. Especially if + turbo motor.
Old 03-15-2012, 03:49 PM   #36
Redbeard
Undiluted snake oil? Or is the pale machine oil in Seafoam the snake oil part?
Redbeard is offline   Reply With Quote
Old 03-15-2012, 10:52 PM   #37
ghettobrick
Originally Posted by weak-sauce View Post
your thoughts on seafoam.? would you add to oil, fuel or both.? thinking about tossing in a bottle in my 88 240 n/a w/150xxx miles
Make sure your car runs well (tune up), change the oil hot and often, use good gas, and put the HAMMER DOWN on a regular basis. I have used this and similar products in the past with good results, but if you maintain whatever you drive, and actually DRIVE the damn thing you should not need to resort to this stuff. I'm pretty sure in just about every owners manual I have ever read they strongly recommend to not and anything but gas (or diesel) to the fuel tank, and oil in the crankcase.
ghettobrick is offline   Reply With Quote
Old 03-16-2012, 01:29 AM   #38
Lando
Arthur Digby Sellers
Lando's Avatar
If you run quality fuel, use synthetic oil, and stay on top of maintenance, you wont need to use seafoam.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is offline   Reply With Quote
Old 03-16-2012, 01:37 AM   #39
cosbySweater
cosbySweater's Avatar
F#$% seafoam
Old 03-16-2012, 02:31 AM   #40
doucheNozzle
doucheNozzle's Avatar
I use it to clean up from previous owner's mistakes.
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 03-16-2012, 03:28 AM   #41
Josh
for real. all i run is chevron supreme and maintain the car like its supposed to.
Josh is offline   Reply With Quote
