Old 06-28-2020, 07:55 AM   #76
TurboDutch
Just found this topic now, I'm very much into this! Stock S90 maf is big enough for 18T ish turbo on 5 banger.
Bmw mafs flow much more indeed. On m4.4 wikia you could find a maf table converter.
Soon I'll be running my 164 T6 on M4.4 ecu from T5 with COPS.
The ecu is modified to use cops and had 6 bin on it... soon we'll find out if it's working as intended.
If you need anything about M44 please ask!
TurboDutch is offline   Reply With Quote
Old 06-28-2020, 10:09 AM   #77
Broke4speed
Broke4speed's Avatar
The MAF table converter from the M4.4 wikia doesn't work with the B6304 M4.4 bin since the MAF tables are in a different spot :(. I've decompiled the program and know where to change the addresses, but I'm lost when it comes to recompiling. That's why I put a bit more work into the 6-cylinder M4.4 XDF, so the MAF tables would be useable .
I'd love to know more about modifying a 5cyl bin for 6cyl usage. I've tried reading the Volvospeed thread, but it's pretty hard to go through nearly 500 pages. I know I've read that the 5cyl bin actually has outputs for the 6 cylinder, but I never saw any more about that.
1984 244/ AQ140A / M46
Old 06-28-2020, 05:26 PM   #78
TurboDutch
The output used for TCV is used for 6th injector so you'll have to figure antoher way to control boost, not that the load control is working that great anyway.
I need to look into it again because it was almost a year ago I've been busy with it.
I'm figuring that I'm using a 6 cilinder (s90) bin and just have it flashed in the 5 cilinder ecu.
Myself is also not the brain behind all this, my friend piet is helping me out with the ecu solderings and bin digging.
You probably know him from the thread at volvo speed.
Are you using the 6 cilinder ecu now on B6304 yes? I would run it on stock maf first since it's quite big.
If you like to do some testing we maybe should share phone nr's and get kicking on this?
I'd love to run my 164T6 on M44 but it's far from ready yet. Seems your further on in the project and might actually be able to get something working right?
I could even ask piet to send you a modified 5 cilinder ecu for use on your 6 banger
Old 06-28-2020, 06:52 PM   #79
Broke4speed
Wow! Much appreciated!
I'm not on M4.4 yet, but as soon as all the parts show up, I'll be swapping over. I will be working with the stock B6304S M4.4 ecu, and since I don't plan to run much boost (it only hits 7 psi currently, with the Speeduino), I think I might be able to stay under the load limit of the stock MAF and just do a basic tune to handle the fueling/timing.
For the moment, I would love to be kept up to date on the progress you're making. I'm in Canada so communicating by phone might be difficult, haha .
Old 06-29-2020, 03:15 AM   #80
TurboDutch
Gehe I was hoping you could do some testing before me.
Will keep you posted.
Old 06-29-2020, 08:58 AM   #81
240wagonguy
Ok this is exciting. Haven't had the time to put together my B6304S+T swapped car yet, but I had been debating pulling the trigger on an MS3 for the swap since I have a complete 960 harness installed in the car. Definitely interested in any updates that come along and once the car is together can do some testing.
Old 06-29-2020, 10:39 AM   #82
Broke4speed
Depending on when I get all the bits I need, maybe I could, lol. I'm waiting on a harness currently .
Old 06-29-2020, 10:42 AM   #83
Broke4speed
It's possible that it could be quite simple. The stock MAF is obviously not overflowed at stock power, so there's a bit of wiggle room for some boost. Not a lot, but it's a good start. Adjusting the timing maps would make it safer to run boost as well. I've done these sort of mods on VW motronic 2.9 bin files before and despite being driven like it was a stolen car, it held up nicely .
Old 06-29-2020, 11:19 AM   #84
240wagonguy
I feel like this is doable, considering guys in Europe turbo these things without even tuning the ECU. Seems its a very forgiving system. I am also excited about not spending $1000 on MS3 if I don't have to.
Old 06-29-2020, 11:29 AM   #85
Broke4speed
As it stands right now, the XDF that's been posted on the first page somewhere (can't remember where), is 'complete' enough to adjust for larger injectors, and POSSIBLY adjust the timing curve. That's something I'd highly recommend doing, if you're using the stock B6304S with it's 10.7:1 engine. Mine is holding up to 7 psi so far .
Old 07-01-2020, 05:34 PM   #86
TurboDutch
M4.4 is almost equal to standalone management actually we can almost do anything with it, even run it on wideband control, mapswitching during driving, it even does launch control and cops on 5 cyl.
The great benefit of the system is that it's with adaptive knock control, so it's "self learning" on timing within the limitations of the system ofcourse.
But any cheap ms, speeduino, kdfi stuff don't have knock sensing. So if we are able to get this working, the possibilities are endless.
Same goes for the maf size, if we could figure how to convert tables (i'm sure piet will be able to find the correct adres) then we can run BMW 540 maf or bigger.
The 5 cilinder M44 is really great, and works really nice, almost as standalone but a bit more complicated.
Old 07-01-2020, 07:32 PM   #87
Broke4speed
I have the MAF tables listed in the XDF I made.
Old 07-01-2020, 08:03 PM   #88
TurboDutch
I know I have seen it, great job! But now how to change them into some workable matter
But I'm sure Piet will be able to figure it out, he reads the bin like saturdays newspaper :D
Old 07-01-2020, 08:10 PM   #89
Broke4speed
I figured that out too . Its just not in the version that is posted, because I am forgetful. I am pretty sure I copied the way it was done from the 5cyl XDFs, so it's probably his work already, lol. I'll try to update the first post.
1st Post updated with the version that shows the MAF tables correctly .
Old 07-02-2020, 01:37 PM   #90
TurboDutch
Ahhh thats great! Will have a look into it soon
Old 07-28-2020, 07:26 AM   #91
vlr7
vlr7's Avatar
Is there a solution to switch off rear lambda control?
Also what value do you guys use for load threashold lambda control?
Anybody know whats the load at peak hp?
One of the 204hp maps has better curve but still.
vlr7 is offline   Reply With Quote
Old 07-28-2020, 07:41 AM   #92
TurboDutch
Rear lambda is not in the XDF? From my head it's called rear cat check 1, 2 and 3 they also have upper bank 2 and 3...
Abt load threshold lambda control you could make it a bit lower so that you start running rich a bit earlier, as soon as load threshold lambda control setpoint is reached it will run on VE table only. (by air mass ofcourse)
About load and how to read it depends of air mass and injector opening. Better to carefully read M44 wikia about the theoretical part.
Load 8 is some 240 hp in V70 T-5
If you want to run higher loads better to re-scale load scaling from 0 to 12.24
There is a re-scaling tool for this purpose. You could also find it on wiki.
Are you succesfully running and flashing M44 6 banger?
Old 07-28-2020, 08:22 AM   #93
Broke4speed
I didn't put much effort into converting the 5-cyl diag functions of the XDF over to the 6-cyl, so they're all wrong, I would assume.
Old 07-28-2020, 11:33 AM   #94
TurboDutch
Most in and outputs are on the same pins too so cannot be too much difference I'd guess?
Old 07-28-2020, 12:37 PM   #95
Broke4speed
In the code, there will definitely be a difference. The addresses will be different. The maps are 'easy' to sort out, but most of the diagnostics are single-byte values, so there's no way to match patterns in the code and re-address the XDF for them.
Old 07-28-2020, 12:39 PM   #96
TurboDutch
My friend Piet is on it, just be patient he reads the bin like a saturday morning newspaper :D
Old 07-29-2020, 03:10 AM   #97
vlr7
vlr7's Avatar
I have done some T5-s and am familiar with its functions. Lets wait the Piet results then. Waiting for my extra R6 ecu to start modifing.
Old 07-29-2020, 03:45 AM   #98
TurboDutch
Great news! I'm really looking forward to do some experimenting here!
Old 07-29-2020, 11:39 AM   #99
pietvolvo
Here are some addresses regarding the lamba probes / catalyst in the S90 bin:
1. "Rear Cat check (1)" (should better be called "Rear Lamba probe Heater check") : 0xEB0
2. "Front lambda probe heater check" : 0xEB1
3. "Rear Cat Check (2)" lower bank : 0x1025
4. "Rear Cat Check (2)" upper bank : 0x11025
5. "Rear Cat Check (3)" lower bank : 0x1137
6. "Rear Cat Check (3)" upper bank : 0x11137
pietvolvo is offline   Reply With Quote
Old 07-29-2020, 01:20 PM   #100
pietvolvo
I think for a 3.25 "ID MAF with the original S90 maf sensor in it, the MAF table should be multiplied by about 1.45.
I have made a small app that allows you to convert the MAF table by entering your own conversion factor.
Based on the air mass stationary, you can then tweak the conversion factor until the same air mass is measured as with the original S90 MAF..
In order to do that you need to be able to log, so I have added a log routine to the S90 bin.
And made an ADX for it.
I can't test it myself because I don't have an S90 (anymore).
So if anyone wants to test it, the files can be downloaded here:
-Bin with logging routine:
(deleted)
-the ADX that goes with it :
(deleted)
-S90 MAF conversion app for Windows:
(deleted)
A new improved set of files can be downloaded here:
https://www.dropbox.com/s/qw4khprm2o...gging.zip?dl=0
