Old 06-05-2020, 10:59 PM   #1
euro-trash97
euro-trash97's Avatar
Default 302 240 supercharger?
I have an 83 240 with a 302 converse swap, has anyone put a supercahrger on one of these? Specifcally the kenne bell. I'm curious if it will fit and if the rear end will hold up to 400 - 450?. If I put a trutac in will the rear end hold substantially more?
Originally Posted by Captain Bondo View Post
If by "can't drive a manual", you mean "refuse to drive like a pussy", then yeah, I can't drive for sh8t.
euro-trash97 is offline   Reply With Quote
Old 06-06-2020, 12:50 PM   #2
fatcatbestcat
fatcatbestcat's Avatar
I assume you're talking about a 302 small block, not a modular V8? Last I checked, KB only made superchargers for '96 - up modular engines.
Send help
Old 06-06-2020, 01:04 PM   #3
Fandango
Don't 302 blocks split in half around that power level?
Fandango is offline   Reply With Quote
Old 06-06-2020, 01:07 PM   #4
283SD
My first V8/350 Chevy in my wagon made 370+ HP, ran 3.90 gears, Powerglide, the shift into drive @64mph would break the tires loose. You will smoke the tires before you break the rear. BTW that was 32 years ago. Still driving it today with a 350 with 350 HP Chevy, first motor wore out after 200k hard miles, never an issue with the rear.
Old 06-06-2020, 02:17 PM   #5
Only when tuned like poop and not balanced well.
Old 06-06-2020, 03:26 PM   #6
euro-trash97
Yes a 302 windsor, I will be buying the Kenne Bell second hand.
Old 06-06-2020, 03:27 PM   #7
euro-trash97
What size tires in the back? Its also a T5 if that matters, though I don't plan on doing clutch drops.
Old 06-06-2020, 04:49 PM   #8
F*ck 12
I've broken 3 with turbo redblocks with a lot less power that that but I was ****ing around. Once in light gravel on the pavement to pavement, broke the pinion gear, once getting off of a shoulder, one tire on the pavement one in the grass, and one that had been making some noise just pulling out of 7-11 near my house with a bit too much throttle. Ended up doing 8.8 swap, just run yours til it breaks then do the swap.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 06-06-2020, 06:23 PM   #9
283SD
Originally Posted by euro-trash97 View Post
what size tires in the back? Its also a t5 if that matters, though i don't plan on doing clutch drops.
235/70/14
Old 06-07-2020, 02:19 PM   #10
If it is a stick car and you drive it hard, breaking rear axles is the norm.
Old 06-08-2020, 01:35 AM   #11
Going on 6(?) years with the welded diff in the v8 drift car without a broken axle. Just stepped up to some 240/40r18 tires. We will see how long that trend continues
Old 06-08-2020, 01:37 AM   #12
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
put a decent diff in it, and it'll be fine.
Megasquirt Tuning!
Old 06-08-2020, 07:14 PM   #13
euro-trash97
Any recommendations?
Old 06-08-2020, 10:23 PM   #14
fatcatbestcat
I'm pretty sure the Ford 8.8 isn't going to be that big an issue on its own. I'd recommend trying to beef up your T5 if possible. I had one in a Chevy Monza with a 305, and blew it up around the 300 hp mark.
Old 06-09-2020, 12:11 PM   #15
jjona5
They still sell the 302 supercharger. http://www.tpsmotorsports.com/kenne-...arger-kit.html There was a local guy selling one used when I had my 740 LS. My math said it would fit the 740.
Old 06-09-2020, 02:32 PM   #16
Truetrac, Wavetrac, or if you value your money, Toyota 9" Explorer 8.8 axle swap.
