I've got a crank no start, tach jumps around like crazy, the injectors are pulsing super fast. RPM signal out of wack? Seems like a bad CPS so I put in a spare, same issue
Going to check continuity in the harness between the CPS and EZK, Wiring checks out. Anything else I should look at?
If it's helpful the car **** itself at a light, fired back up after pushing it off the road but idled terribly. Would run better when revved but died under load and won't do more then pop now
