Murploid1
- Apr 6, 2017
- Houston, Texas
Hi Guys,
Aside from leaking fuel, and playing around with the CO mixture of the KJet system what would one look for when trying to assess why my car is so thirsty?!
From a mechanical perspective it has:
- New spark plugs & Cables
- Fresh oil change and filter
- New air filter
- Correctly inflated tires
- Fuel pumps that are producing a lot of pressure and both working
- Running it on 93 RON
I am mainly using it on the freeway (no AC as new compressor has yet to be installed) so very little start and stop, sitting at around 65-70mph off boost in OD (2500-3000rpm) and I am getting 16mpg?! Surely this car should manage at least 20mpg?!
I am not aware of any boost leaks, car is not short of power, seems to run just fine. No smoke from the exhaust unless I am higher up in the rev range and pushing it (5000rpm)
Also, I have a wide-band fitted and the car seems to be where it should from an AF ratio - 14-15 when cruising. Dips down to 13 when i come off the throttle.
Thoughts?
Nick
- New air filter
Thoughts?
Nick
