#176 | |
![]() Quote:
When I do paint it, I’m probably not going to go with the original color. I’d like to go two-tone, not sure what colors yet, though. I’m leaning towards red with a white top at the moment. I’m always changing my mind. |
#177 |
![]() It’s funny you say that. After I put the head on, I noticed I didn’t see any valve seals. I kind of panicked for a moment and called my engine builder. He told me he put em inside the spring this time. Not sure why, I’ve never seen that before.
#178 |
#179 |
The Librarian
![]() Older American cars use an umbrella seal under the retainer like where your machinist put them but these are supposed to go on top. I don't think it will hurt anything though.
#180 |
#181 |
![]() Picked up some sport springs from IPD. They were surprisingly easy to install. Anyone know if I need to get an alignment now?
![]() Front sprints old vs new ![]() Rear ![]() ![]() ![]() ![]() ![]() Last edited by wtarkington; 01-14-2021 at 04:12 AM.. |
#182 |
#183 |
![]() So I’ve been daily driving this car for a long time now. Over time the drivers seat began to fall apart. I’m tall and built, but I’m not THAT big. Has anyone experienced this before?
I swapped the front seats, and the passenger side is wayyyy better on my back, since it has been used way less for obvious reasons. BUT I feel like it’s so far forward. The keys dangle on my knee, and I’m basically hugging the steering wheel. Has anyone ever figured out a way to move the seats back a bit? I’m pretty sure these seats are for a 4-door, as there’s no way to move the seats to allow someone to get into the back. ![]() ![]() ![]() ![]() |
#184 |
![]() That seat looks kind of messed up. On the later style seats the U shaped tubular bit on the bottom of the seat unbolts from the rest of it with 4 bolts similar to a 240 seat and there are a few sets of holes so you can move it forward and back to have different "ranges" of adjustment. I'm lucky enough that the farthest setting back feels comfortable to me.
Maybe make some seat rail extensions?
1967 122s, B20F, M40 1989 240 B230F (V15 cam, chipped EZK), M47 (Lost a fight with a Chevy express van) 2012 VW Tiguan 6 speed auto (oh the joys of carbon buildup). |
#185 | |
![]() Quote:
#186 | |
![]() Quote:
When you alter the ride height you alter the front camber causing it to become less positive or slightly negative - depending on whether you started out with positive or 0 camber. Volvo initially recommended 0 to slightly positive camber. With modern radial tires slightly negative camber may improve things. If your car initially had a Volvo 'spec' alignment the the reduction in positive or change to negative camber may be beneficial; but, will increase the steering effort. The bigger problem may be offset of the rear axle. When you drop the ride height at the rear the panhard rod causes the rear axle to offset to the side of the car. Stand about 20 feet behind the car and look at the positioning of the rear wheels relative to the body. If the wheels appear to be offset to the left or right (I don't know which side the pan hard bar mounts on the axle) you will need to shorten the panhard to return the back axle to a centered position under the car. Depending on the amount of drop in ride height you may also need to check the pinion angles on your transmission output shaft and differential input shaft. If they are significantly different then you need to alter the back axle orientation to match the angles. That is a little more challenging fix. |
#187 |
![]() How much did those springs end up dropping it? I am tempted by some sport springs. VP autoparts and IPD both sell sets. But I like my ability to not scrape things on steep driveways.
#188 | |
![]() Quote:
I took a look under the car from far away and everything seemed to be lined up okay. I’m not experiencing any issues driving the car either. I think after 60 or so mm the panhard becomes an issue. At least that’s what I read. I could be totally wrong. |
#189 |
![]() It says the drop is 1.2 inches. It looks great. It doesn’t have that high rise look anymore. I can’t see into the wheel well, as you can with the stock springs. 122’s sit so high stock, this drop didn’t have any effect going over speed bumps or driveways or anything. It was worth it for me, and easy to do. Not too expensive either.
#190 |
![]() Seat problem has been solved. The distance, height, and lean is all perfect. The ONLY thing that kind of bothers me is the way the front bar sticks out. I say kind of because it’s not that bad really. I don’t notice it when I’m sitting. I can probably cover it with carpet when I get to that point. I thought about drilling a hole but, I believe the seat sits on a specific part of the frame for obvious structural reasons. I could be wrong.
#191 |
![]() Yep, the seat mounts in the floor are welded into the cross members for strength. You and your seat experience huge forces in an accident, so mounting a seat straight to the pan takes more than just drilling a hole.
I hope that's your prototype just to locate the seat, it's really not safe... |
#192 | |
![]() Quote:
So what should I do than to bring the seat back? It’s just as unsafe with it mounted normally, as I’m basically hugging the steering wheel and it’s really hard to see. Also I have to open my legs more, and my knees touch the dash. I’m only 6’1. |
#193 | |
![]() Quote:
What if I drill holes in the back to make two more anchor spots, to anchor the rail in the back so it doesn’t swing forward? |
#194 |
![]() Mounting a seat isn't simple: you can very easily get forces of a couple of g's in even a moderate crash. One way to think about it is how would any mounting idea handle being hit by a couple of NFL linemen.
Those straps aren't strong enough in any direction. Even if you welded the nuts and bolts so they didn't rotate, the long strap will bend easily when the linemen come to play. I think you're on the right path by anchoring to the rear. One way might be by making a box of 1x1 square tube, bolted to the side mounts and anchored to the rear floor pan with some plates to spread the load a little. Then mount the seat to the box. |
#195 | |
![]() Quote:
#196 |
![]() Yes, welded. You don't have to go to the extent that Canuck's done here https://forums.turbobricks.com/showp...03&postcount=8 but that's some ideas anyway.
#197 | ||
![]() Quote:
(3) 6x6" 1/8" steel plate. (3) nuts that fit the original bolts including the front center eyelet. Drill holes in the current floor where the new seat mounts need to be that is just a little oversize to the nut. Drill holes in the plates (as close to the center of the plates if you can) that will slip-fit the bolt. The rear ones will be tricky and might need some bending to get up the tunnel, and down the floor into the rear footwells. Put some old bolts through, tighten the nuts down, weld nuts to plate. Place plate over the new holes in the floor and weld them down. If you tack them down where ever they naturally touch the floor, you can take a 3lb sledge and beat them into the valleys, then tack some more. Then finish weld all the way around.
The Build Thread SVEA - PUSHROD TURBO! |
Thread Tools | |
Display Modes | |
