Old 04-07-2015, 05:49 PM   #176
MrBrown
MrBrown's Avatar
It's a bosch kjet turbo pump. Brand new and driven prior to turbo addition as wm as the intank pump but the intank is not bosch though I don't think.
Never changed any wires though it's a 91.
A few thoughts I had:
I tapped the smaller line on the throttle body for the charcoal can and T'd it into the larger line since they were both routing into the same place and blocked it off. Could this cause the problem?
The MSD is grounded to body and not battery?
Furl pump under car sounds louder than normal and changes pitches while operating at idle?
New chip that hasn't been driven very long enough to learn?
BOV is releasing air and getting stuck sometimes?
These are a few things I have noticed. Tmwyt.
Old 04-07-2015, 05:52 PM   #177
cwdodson88
Originally Posted by MrBrown View Post
Maybe the computer has not learned yet?
about your AMM? hmmm, this sounds possible..... I think I read this somewheres
The Build Thread
SVEA - PUSHROD TURBO!
Old 04-07-2015, 07:03 PM   #178
cwdodson88
sounds like its starving, or getting fluctuating voltage.
Old 04-07-2015, 08:44 PM   #179
MrBrown
MrBrown's Avatar
Maybe. it drove fine NA. same noises.
Im getting tired of trying to figure this out though.
Old 04-07-2015, 08:53 PM   #180
photoman327
photoman327's Avatar
Take a step back and relax. Often the simple thing that is over looked. Verify pump pressure or volume. I changed my 87 to later 92 up rail to easily check pressure.
Old 04-07-2015, 09:00 PM   #181
MrBrown
MrBrown's Avatar
True.
I guess im just so excited to get this far and do everything right to find out something is wrong.
I need to figure out wether the in tank pump is providing. I just heard it may not be good to have the Kjet intank pump. I will test first then maybe install the stock pump and see.
I have another rail that has a pressure valve on it if I can dig it out and find it, ill swap it this weekend.
Old 04-07-2015, 09:16 PM   #182
photoman327
I made a toggle switch to plug in place of the fuel pump relay years ago to turn on the pumps the got to the tank to verify they are working. On that white wagon I gave to my brother kid, I had a problem with the pickup. Pump good when I tested it before installing it. Then it was hard to tell if it was running. I found it by undoing the hose going to the pump under the car the flipping the switch. No gas under the car. Took the pick up back out and tested it and that was my issue. Now I test the pickup before installing one.
Old 04-09-2015, 12:42 AM   #183
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
Amazing thread so far. Seriously inspiring, especially since I just got my 242 running after a year of it sitting at work.
'08 XC90 V8 Big Björn|'88 245DL Uncle Sven, sold|'95 945T Darth Haul, sold|'82 242GLT B23E Lumpy the Angry Viking, sold|'77 244DL, sold|'90 744T, sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 04-09-2015, 01:52 AM   #184
cosbySweater
cosbySweater's Avatar
just run a single walbro in the tank, its simple and will provide ample fuel
1984 Volvo 245
1995 Porsche 993
2013 VW Passat TDI
Old 04-09-2015, 09:47 AM   #185
Sharingan 19
Sharingan 19's Avatar
^^^this!
If you go that route I got dibs on the kjet.
Sharingan 19 is offline   Reply With Quote
Old 04-09-2015, 10:59 PM   #186
MrBrown
MrBrown's Avatar
REEEEEEPORT
Dead intank fuel pump. Does not perform when 12v applied.
Guess I needs a new one. I am thinking just stock for my measly 300hp goal. But Aeromotive offers that nice 255lph pump too.
What all do I have to do to install the high lph intank pump as far as new lines, new wiring, relays (which type of relay) etc?
Thanks guys.
Old 04-09-2015, 11:10 PM   #187
amerbritcan
Hnnnnnng
amerbritcan's Avatar
Thank you for verifying I'm not crazy lol. As soon as you mentioned that it runs better above a certain level in the tank, that's the first thought, first thing to check.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 04-09-2015, 11:12 PM   #188
MrBrown
MrBrown's Avatar
But even with the gas above the pump level it still ran like crap so there are other problems still. We shall see though.
Old 04-10-2015, 06:42 AM   #189
oldschoolvolvo
oldschoolvolvo's Avatar
Stiggy Pop used an Aeromotive 340 single in-tank pump for his car...check it out:
http://forums.turbobricks.com/showpo...&postcount=183
http://forums.turbobricks.com/showpo...&postcount=184
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 04-10-2015, 10:34 AM   #190
cwdodson88
Just an FYI, Walbro pumps DO NOT LIKE LOW VOLTAGE, if they are run at less than 13 volts frequently (lots of cold morning priming/running before the alt picks up), they start having issues.
Old 04-10-2015, 11:27 AM   #191
MrBrown
MrBrown's Avatar
I would get an aeromotive since I have hear great things about them.
Old 04-15-2015, 08:41 PM   #192
MrBrown
MrBrown's Avatar
Update. New intank pump in. I will test drive tomorrow and fill in my observations. No more whinning main pump.
Old 04-15-2015, 08:53 PM   #193
chris gilmour
yay! something to look forward to for tomorrow!
chris gilmour is offline   Reply With Quote
Old 04-15-2015, 09:20 PM   #194
MrBrown
MrBrown's Avatar
Ill leave this here to provide some type of update, its coming back together but slowly.
Old 04-15-2015, 09:23 PM   #195
chris gilmour
any plans on body colour?
same as the bay? or is the bay a contrast?
Old 04-15-2015, 09:26 PM   #196
MrBrown
MrBrown's Avatar
I have a plan. I won't say since I know what the reaction will be. You will just have to wait and see. And it's not the bay color.
Old 04-15-2015, 09:38 PM   #197
chris gilmour
im excited to see it all come together man! even with the primer and blue fenders its got a mean look to it!
Old 04-15-2015, 09:40 PM   #198
MrBrown
MrBrown's Avatar
Old 04-15-2015, 09:40 PM   #199
Asphyxious
I really need to get my hands on a set of of single or dual rounds, makes all the difference when it comes to front end looks.
Daily driver '85 Volvo 244
Drift project '84 Volvo 244
Sold '85 Mazda 626
Sold '90 Volvo 745 GLE
Sold '99 Volkswagen beetle
Asphyxious is offline   Reply With Quote
Old 04-16-2015, 01:31 AM   #200
Sharingan 19
Do it run?
