#26 |
Double Dutch
![]() Did you know that Volvo provided extra enhanced Airbox clamps in case the original one's broke down?
![]() ![]() Yes these ones: ![]() Really taylormade by Volvo: ![]() BAM: ![]() Now I'm looking for some new headlight glasses, they fell out hmmm...
Flying Dutchman - Build and goodies thread ;P ======================================= Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition B230-FK Turbo - 90+ ported - 15G Ported - Airintake Erland Cox Regrind - Blabla Chips - 3 inch exhaust MBC on 0.95 - Wasted Spark - Sponsored by my wife ======================================= Last edited by Chilm; 12-09-2020 at 04:10 PM.. |
#27 |
Våga Vägra 8V
![]() :D i once did that on a Autobahnrastplatz to move on.. ;)
Nice and clean build.. :D |
#28 |
Double Dutch
#29 |
![]() A lot of my airbox clamps are knackered : great tip!!
#30 |
Double Dutch
![]() I have been weighing all of my connection rods. Three of them are between 478 and 481 grams very nice, number four is weighting 506 gram that is waaaay too much imho. I want to grind that one off at the shoulders, is that a good idea?
![]() Last edited by Chilm; 12-09-2020 at 04:10 PM.. Reason: Spelling |
#31 |
![]() You want to weight them with the caps on. Then you match the weight of the big-ends and the small-ends. There are pads on the cap where you remove material, and the pads on the side of the small-end are where you remove material as well.
#32 |
Double Dutch
![]() That's a very clear answer, thank you very much man...
#33 |
#34 | |
Double Dutch
![]() Quote:
#35 |
Double Dutch
![]() Been weighing and grinding my connection rod's and they are now exactly 716 grams each.
So that's done too for the bucket list (thanks to culberro for the link). ![]() Last edited by Chilm; 12-09-2020 at 04:11 PM.. Reason: Adding Photo |
#36 |
Double Dutch
![]() A short story about the oilpump, mainly because I've got my engine totally dismantled and I
don't want to spent a whole lot of money for a new big fancy oilpump so decided to just check and then port the old one. After measuring i thought that it was a ok to start porting. There are a lot of hairy edges in the internals to work on for better flow in my opinion. Just see for yourself... And if it doesn't help it won't hurt either ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Chilm; 12-09-2020 at 04:11 PM.. |
#37 |
![]() You'll port and polish anything won't you!!
(Yeah, arse-joke in there somewhere ![]() |
#38 |
Double Dutch
#39 |
![]() Fantastic build so far! I envy your attention to detail.
Would you say it was truly worth you time with the head work? I am thinking of doing something similar to a spare 530 head on bench. Mike
15G mbc Needs mer boost~~ ![]() |
#40 | |
Double Dutch
![]() Quote:
Also the position of the sparkplug is better (towards the outlet) and the combustion chamber has a different design too. I also shrouded the chamber at the outlet side, as you can see in the pictures. But... this one is not on yet and i did not measure the cc's so the gain will be a matter of trial and error. But together with all my other updates (still in progress) it must be worthwhile in my opnion. |
#41 |
![]() Nice head grinding. Did you mach the chambers size too with some liquid?
And did you flatten the head to increase the compression (grinding and 531 makes the compression chambers larger than original)? Last edited by dopski; 08-14-2015 at 05:41 PM.. |
#42 |
Gloss Boss
![]() Join Date: Oct 2003
![]() Nice fab skills sir
My other projects http://www.pbase.com/mikejr |
#43 | |
Double Dutch
![]() Quote:
no i did not measure the cc's, dunno why, maybe stupid but i think they are pretty equal although i am guessing that ![]() I am going for tight squish and i have to do the maths for it with the current block hight and going for the Comet way in that case. The head is in the shop now and allready flattened, i'll have to get it back woot woot. But you know the head hight has nothing to do with tight squish, only the block hight, piston clearance and the used gasket height. Thanks Mike, very appreciated. Last edited by Chilm; 08-17-2015 at 06:58 AM.. |
#44 |
Double Dutch
![]() My TB conversion plate for a 960 TB to the 940 (ported) inlet. I used a thick aluminium plate as "middleware" for the mounting. I think the pictures will speak for itself. The final mounting is done with epoxy raisin (JB weld as you call it) and one allen screw, it is very stirdy and will even hold against the heat and heavy vibrations. Again this is a little piece of the whole tuning picture in general.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I will post the build results later, everything has to be put together after I am finished with all parts ![]() Last edited by Chilm; 12-09-2020 at 04:12 PM.. Reason: Added photo |
#45 |
![]() Nice job with that middle adapter plate,
how much could you enlarge the manifold entrance by? Just a little? |
#46 | |
Double Dutch
![]() Quote:
as you can see in the pictures from 59 mm. to 65 mm. same diameter as the TB otherwise it's useless ![]() Last edited by Chilm; 08-18-2015 at 03:50 PM.. |
#47 |
Double Dutch
![]() At last found the guts to grind a hole in my right front fender to make a airduct for the airfilter inlet sticking in the fender. Stolen the idea from "Frans" (hello Frans) so all credits to him. First lined out the area to grind:
![]() After grinding I sanded the edges and painted them too against corrosion. ![]() Nice to see where the inlet sits in fact... ![]() Preparing the airduct (cheap from ebay Ford Cosworth hood scoops). You are looking at the back side/inner side. ![]() I had some gauze from a music box laying around which I cutted and sprayed. Did some bending too so it sits nice and tight. Automotive tape and Voila... ![]() Sprayed the duct in the color of the car so that does not stand out too much. ![]() Final result looks nice I think, like it's original (imho). Butt dyno says better throttle response in the midrange. And ofcourse more and cooler air... ![]() Last edited by Chilm; 12-09-2020 at 04:12 PM.. |
#48 |
![]() Awesome scoop inlet, do you have a link to the original you borrowed the idea from?
I'd love to see a red Volvo with an "F-40" version from the 1980s. |
#49 | |
Double Dutch
![]() Quote:
![]() Last edited by Chilm; 12-09-2020 at 04:12 PM.. Reason: Wrong forum name. |
#50 |
![]() nice job!
