#51 |
![]() That's nice!
Groeten van Frans. |
#52 |
![]() A lot of inspirations in this thread! Nice job man
![]() I'm currently fighting with the same kind of POD you made. But rather ashtray I'm using the original panel with a cigarette lighter, want to put the pod a little bit "inside" it, using the factory mounting points (those 2 screws) When I'm done - I'll post a picture, so I can sign it "idea stolen from Chilm" :-) Greetings from Haarlem! |
#53 | |
Double Dutch
![]() Quote:
![]() At first I also thought tu use that plastic box as a "holder" for it, but no way the gauges are going to fit, just my thoughts, but... if you dont't try you'll never know so keep yourself posted here.
Flying Dutchman - Build and goodies thread ;P ======================================= Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition B230-FK Turbo - 90+ ported - 15G Ported - Airintake Erland Cox Regrind - Blabla Chips - 3 inch exhaust MBC on 0.95 - Wasted Spark - Sponsored by my wife ======================================= |
#54 |
![]() I already destroyed this holder, so it needs to fit in there! ;) A lot of drilling, fabricating and in the end it will look probably worse than your job, but oh well. I'm half way done and so far it looks promising...
#55 |
Double Dutch
![]() I'm gonna do a "Yoshifab" PCV the TB way using an old PCV and some sawing, sanding and elbow grease, like being "the human lathe"
![]() ![]() ![]() ![]() Epoxy is your friend again. ![]() ![]() ![]() Hard labour with the grinder and cutting wheel. ![]() ![]() Looking good to me, ![]() To be continued ![]() Last edited by Chilm; 12-09-2020 at 04:13 PM.. |
#56 |
![]() good job
#57 |
Double Dutch
![]() @moise: thank you.
Everything is coming together now: ![]() ![]() I collected a hydraulic oil pump housing from a waste tank when I was hording around. That would come in handy i thought so voila, my future catch can. ![]() ![]() In fact the only thing I have to do is making some holes and a bracket, dead simple. ![]() ![]() Horder as I am I found this motorbike thingie in my magic shed. ![]() Victor Reinz chiming in too ![]() ![]() ![]() Aaaand almost ready. ![]() To be continued, tomorrow is another day. Last edited by Chilm; 12-09-2020 at 04:14 PM.. |
#58 |
Chinese guy/Swedish rides
![]() That is awesome! Going to put some steel wool inside for baffling?
'08 XC90 V8 Big Björn|'88 245DL Uncle Sven, sold|'95 945T Darth Haul, sold|'82 242GLT B23E Lumpy the Angry Viking, sold|'77 244DL, sold|'90 744T, sold mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts. DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg. -Feedback- |
#59 |
Double Dutch
#60 | |
![]() Only issue I see is the louvers are pointing the wrong way. At speed, that will be making the area a low pressure area and trying to suck air away from the Airbox.
They need to face forward to "scoop" air into it. Quote:
#61 | |
Double Dutch
![]() Quote:
After driving it for a few months now I can say it is breathing (cool air) very well. |
#62 |
Is posting from the grave
![]() This car is cooler than hell
#63 |
Double Dutch
![]() Hi, decided to do the kyote way coilovers so bought a set of used struts:
![]() And after some cutting, grinding, sanding and elbow grease: ![]() ![]() And now I have to give Ben a call and spend some money, to be continued ![]() |
#64 |
![]() the good way!
#65 |
![]() So much good stuff in your thread!
Blue 79' 242 GL Engine Rebuild in process! |
#66 |
Double Dutch
#67 |
![]() Very cool- some great work going on here! I think I'm going to copy your idea for the PCV hose, the foam around mine is starting to deteriorate.
1985 760 Jurbo- 80k miles, finally running. Build thread HERE 2000 Honda CRV- Ã…snan 2012 Honda Civic LX- Reliable. |
#68 |
Double Dutch
#69 |
Double Dutch
![]() Hi, I`ve designed and 3D printed a "Piston install jig" fo easy installing your pistons with piston rings in to your engine.
The tool is tapered so the top is wider then the bottom. In this way you can easily fit the piston rings, slide it down and drop it in the bore. Tested it and works great. The "bubbles" on top are for easily recognizing the top of the jig ![]() Here we go, pictures are self explaining: ![]() ![]() ![]() ![]() ![]() Last edited by Chilm; 01-09-2021 at 12:21 PM.. |
#70 |
Double Dutch
![]() And another piece of 3D that I`ve drawed lately, cuz the speaker caps are mostly gone...
The supports are different, left and right and are trapezoid shaped so keep that in mind. ![]() Last edited by Chilm; 01-11-2021 at 02:57 PM.. |
#71 |
Keep it clean...
![]() Brilliant!
Derek 1 Owner - 85k mile 1980 242 Recaro LX Bs - 16" ARE 398s - 25/25 Sway Bars - Bilstein HDs - SuperPro Poly/STS Derlin Bushings - MSD - R Sport Wheel -Project Thread- Follow on IG: @vol242vo |
#72 |
Våga Vägra 8V
![]() Now, that's cool.. Can you print smth like this for the mirror Plastik triangles? Almost every pin is sheared off on those
#73 |
Double Dutch
#74 |
Double Dutch
![]() Photo's from the rod and washer trick I did for the caster (and so many people asked for):
Concerning thread: DET17 camber mod Concerning thread: Janspeed in Renny D's post ![]() ![]() ![]() And an interesting document concerning the special tool (sorry in Dutch but you get the drift) about the three different rods. Standard 390,5 mm Short 385 mm Long (so called tTaxi rods) 396 mm. ![]() ![]() Last edited by Chilm; 01-14-2021 at 04:45 PM.. |
#75 |
![]() That's cool, I might try that with my second set of control arms!
Volvo 745 - IPD springs, 25mm/19mm swaybars, K-cam, LH2.4, M90 swap, 3.54 \w racingdiff lsd, track/daily ------------------------------------------------------------------------------------- I sell LH2.4 Chips for Europe! |
