Old 06-13-2019, 12:27 AM   #151
122power
dude
122power's Avatar
Originally Posted by culberro View Post
Wilwood forged superlight internals (1.62 bore) in the front with 11.75" x1.25" rotors, and some dynalight 4 piston (1.12 bore) on 11x0.8" rotors out back.
MCs are 3/4" front and rear, with a Tilton bias bar added into the stock pedal box using a 6:1 ratio. I'd probably go 5.5:1 next time.
Stay tuned for a brake kit using these calipers from STS... they'll fit withing an OEM 16" wheel or most aftermarket 15" wheels.
There are some pictures of the pedal box and firewall plate in this album:
Rally Racing
Nice photos! Have a build thread? Always like your posts and info that you post up!
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 06-17-2019, 05:00 PM   #152
Duder
Comes with a free Frogurt
Duder's Avatar
More thoughts about brake boosters - I just found this Australian remote booster, the PBR VH44. No idea if this is a decent product or not but this (or something like it) may solve a few problems at once for me here. It would allow vacuum boosted brakes for simplicity's sake, without the need for any electric or electro-hydraulic boosting apparatus. The fact that it's de-coupled from the master cylinder would let me choose the best MC for the job in regards to volume ratios vs. the calipers. I think it may also be compact enough to hide it under the inner fender, ahead of the front wheel on the driver's side.
I'm writing this up now mostly as a reminder to myself to look into this more!
Old 06-17-2019, 05:42 PM   #153
Tfrasca
Tfrasca's Avatar
That's interesting. So the remote booster just gets plumbed in-line from the master to the junction block? I'm also sort of always looking for good options to remove the stock booster.
Old 06-17-2019, 06:12 PM   #154
vwbusman66
Stößelstange über alles
vwbusman66's Avatar
Jaguar did a similar thing with much of their 60's and 70's stuff.
Most familiar to me is the 3.8S/4.2S cars. They had a master on the firewall, then a remote booster and "solenoid" plumbed in to improve power.
vwbusman66 is online now   Reply With Quote
Old 06-17-2019, 06:25 PM   #155
The Librarian
Won't you need 2 of the boosters to have power brakes on all 4 wheels?
Old 06-17-2019, 08:51 PM   #156
vertigosity
vertigosity's Avatar
I'm guessing the master on the firewall is just a single circuit and its only job is to jab at the back of the booster, just like the rod directly from the pedal normally would, and then the master on the remote booster has a normal-ish F/R split. PBR is reasonably well known for pads, so it might not be garbage, lol. I wish I'd known of something like that back when I had a 140 I was dreaming about engine swapping
93 245 5.3L LSx / 90 Miata / 90 Spec Miata
Old 06-17-2019, 11:06 PM   #157
Volvo244GLE
Volvo244GLE's Avatar
The VH44 has been around since the 50's or there about's and continues to be used on a lot of older cars. There is a lot of info around on the net about them. You may need a larger booster though such as the VH40 which is similar but a bigger diameter and provides additional booster assistance.
PBR are well known in Australia and supplied brakes for a lot of cars built in the country back when that was still happening.
244GLE Project - Rebuilt B23, ported 405, 37.5 exh. valves, BMW oil squirter's, MS2e, H cam, King Springs, Bilstein HD's, upper+lower chassis braces, 26mm Falcon front sway bar, SAAS bucket seats, hi flow rear muffler, almost every factory option.
242GT Project - who likes rust?
Volvo244GLE is offline   Reply With Quote
Old 06-17-2019, 11:15 PM   #158
Volvo244GLE
I should add they are designed with 1 line in, 1 line out. When it comes to dual circuits there are a lot of things to consider but one option with appropriate sizing may be using a dual circuit master cylinder with only the front brakes going through the booster. Otherwise two boosters to do the two separate circuits.
Old 06-18-2019, 12:28 AM   #159
MCHN8
Packaging can certainly be a challenge! I ended up running a relocated Hydroboost fed by a KRC pump on my E30 with good results. KRC also has a range of valves to play with for dialing in the amount of assist you like.
Bell cranks to relocate:
MCHN8 is offline   Reply With Quote
Old 06-18-2019, 01:02 PM   #160
Duder
Duder's Avatar
Whoa, thanks for all the feedback guys.
Ian - of course, and good point. The remote booster would indeed only work on one circuit. There may be something to the idea of boosted front / unboosted rear, if I end up going that way. I do like the remote vacuum booster idea because it eliminates another hydraulic circuit.
Volvo244GLE - good input; thanks for chiming in with the knowledge!
Tyler - yes, this gets plumbed in-line (in one circuit as others noted) with the output of the un-boosted MC feeding the inlet port of this remote booster. I wonder if any analogous dual-circuit remote boosters exist out there...
Nate - I remember seeing your bellcrank linkages but didn't notice (or internalize) the fact that you used hydroboost on the E30. I'll pick your brain more on that soon. In my project I have room for the MC on the firewall, and I think I have room for hydroboost there as well. I haven't seen any 3-valve 4.6 into 240 swaps other than mine but I know of several people here who've used hydroboost and had clearance for it with 2-valve and 4-valve 4.6 engines. How's the Smurf?
Old 06-18-2019, 01:46 PM   #161
The Librarian
If you split the dual diagonal system into separate front and rear systems then it would be possible to boost just the front brakes but you may not have enough pressure to lock the rears. Using a dual master setup with a balance bar would allow you to properly size the master for the rear unboosted brakes.
The only dual circuit booster I've seen was on a Lancia Flavia Zagato that one of my customers owned and conned me into working on.
Old 06-18-2019, 04:18 PM   #162
aidanahunter
aidanahunter's Avatar
I will add my input. So far the hydroboost has gone in smoothly-ish for me. It just barely clears the heads and looks fairly normal in place. The mods that I did need to make to it were all simple - nothing major. A lot of it actually lines up quite nicely with the Volvo setup as well...pedal attachment, master cylinder final location, etc. That being said, I'm very not excited about the hydraulic lines. I just know they're going to leak...lol. With turbo manifolds, I'd be nervous. There really isn't much room in that area with the engine in place, as you know. However, if I've learned anything in my endeavors with my build, nothing is impossible!
I like the idea of trying a dual master cylinder unboosted setup like culberro's. It's compact, simple and completely out of the way. I think of the 2nd to last picture in that flickr album when I say that.
I'll be writing a post detailing how I did the hydroboost on my car in the next day or two. I plan on driving the car with no power steering or hydroboost for first drive. If it's tolerable, I'll leave it that way...
Aidan
4.6 32V 240 Wagon
aidanahunter is offline   Reply With Quote
Old 06-18-2019, 05:12 PM   #163
MCHN8
Cheers! Happy to assist.
Lots of planning but not much physical progress so far with the Smurf. The associated pile-o'-parts is growing: Parts Car, Engine, Wheels, EFI, Brakes, Tranny, and Clutch are all there heckling me regularly! The time is nigh.
Old 06-23-2019, 11:30 AM   #164
jmc0369
jmc0369's Avatar
Another amazing build shaping up. I am especially interested in the E36 strut swap. i NOTICED There is a D24 on craigslist in the LA area (I'm in San Diego).
Member: TBCCS
"Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who!
"It is no measure of health to be well adjusted to a profoundly sick society" - Jidu Krishnamurti
jmc0369 is offline   Reply With Quote
Old 07-24-2019, 09:24 PM   #165
Duder
Duder's Avatar
Minor job in the past few weeks, but it's something. Battery tray carefully cut out using a spot weld cutter and angle grinder. Was able to clean up the inner fender very well, and there aren't any holes in it which is great. Just needs some surface prep, priming, and eventual paint. I'll likely do the spot painting at the same time I spray after rust repair on the windshield frame and rear window frames.
Old 07-25-2019, 02:04 PM   #166
Duder
Duder's Avatar
I've been distracted with this little guy lately. 1967 Opel Kadett Kiemencoupe. Been sitting for a decade or so but it runs. It's like a scaled-down Chevelle or Chevy II meets an early fastback Barracuda. I had the bad thought of taking the B20 from the green 245 and swapping it into this Opel, but am holding off on that until I've explored all other options with the teeny tiny little 1.1L pushrod four it came with.
Old 07-25-2019, 02:13 PM   #167
OLIVEEEEEEEER
Old 07-25-2019, 02:45 PM   #168
Duder
Duder's Avatar
OLIVEEEEEEEER
Oliver was a Kadett A (1st gen); this is a B, but I'll allow it
Old 07-25-2019, 02:48 PM   #169
sksmith
sksmith's Avatar
Be a shame to remove that little Opel lump. Not many of those around anymore.
If you could find a 1.9L from an Opel GT, it might drop right in?
Steve
Old 07-25-2019, 03:11 PM   #170
Duder
Duder's Avatar
Steve
The B20 is better on paper in every way except for weight and physical size. At first I was convinced it would be an easy conversion, but after taking some measurements it revealed itself to be more of a pain.
Current plan is to hop up the 1.1L a bit. My Lemons teammate has been doing just that to another '67 Kadett 1.1L, with hilarious results. He found that Honda B16 valves make a nice upgrade; slightly larger heads but much skinnier stems. He ported the head and had valve seats and guides installed for the Honda valves. Then adapted a pair of Ducati carbs to it with a homemade manifold and airbox. It makes probably 75bhp (flywheel) now - up from 54bhp stock in 1967.
The head work is probably in the cards for this one but "induction" will be of a different variety.
Old 07-25-2019, 04:16 PM   #171
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
OLIVEEEEEEEER
That's what I thought too!
It's adorable, I dig it
1980 242 Turbo
2004 V70R
Old 07-25-2019, 04:55 PM   #172
Duder
Duder's Avatar
Hehe, thanks. Are you guys out in Texas yet?
I started a thread for Kadett stuff on the GRM forums for anyone who's interested in progress. Has some photos and more info about the race car too.
https://grassrootsmotorsports.com/fo.../155430/page1/
Old 07-25-2019, 05:13 PM   #173
vwbusman66
vwbusman66's Avatar
Induction, forced induction?
Old 07-25-2019, 06:03 PM   #174
Duder
Duder's Avatar
Indeed - it would be rude not to. I've had this little GT12 on my desk as a decoration for years now. Just so happens it would work quite nicely up to ~100hp on an ancient 1.1L 8-valve engine revving to ~6krpm...
Old 07-25-2019, 06:11 PM   #175
Tfrasca
Tfrasca's Avatar
That's going to be awesome!
