Old 10-08-2020, 05:47 PM   #201
tomasss
former PRVert
tomasss's Avatar
M90 receiving some cleanup & OEM love...
Old seals out...
Cleaned, new o-ring and input shaft seal...
New output shaft seal
Volvo 740 Turbo B204GT 1991 >project thread<
It's the oversteer that scares passengers. It's the understeer that scares the driver.
Originally Posted by Wren View Post
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 10-13-2020, 05:11 PM   #202
tomasss
former PRVert
tomasss's Avatar
M90 stop ring welded. There is by the way very good new instructional video on >>> youtube <<<
Old 10-20-2020, 05:35 PM   #203
tomasss
former PRVert
tomasss's Avatar
Finishing the M90...the shifter rod seal has been replaced, final checks done and the transmission case is sealed again
Old 10-20-2020, 07:09 PM   #204
Question
What fluid will you be using?
Old 10-21-2020, 03:09 AM   #205
tomasss
former PRVert
tomasss's Avatar
I have some Febi API GL-4 75W-80 laying around so I wanted to use that, but reading now the >M90< topic I'll check with Volvo dealership. The issue is that the recommended 1161745 (GL-4 75W-80) seems to be no longer available and it's official replacement 31259380 is different spec (GL-5 75W-90). Not sure what is the best way to go here...
EDIT: Dealership responded that the replacement is #31280771 (API GL-4, SAE 75W), it replaces Volvo Transmission Oil 1161645 (API GL-4, recommendation for M45, M46, M90). So that one is ordered and will go in.
Old 10-22-2020, 05:38 PM   #206
tomasss
former PRVert
tomasss's Avatar
Transmission filled, sealed and ready for installation
I have also ordered stainless braided clutch hose as I have been reading bad experience using the oem hose with a performance pressure plates.
Old 10-23-2020, 02:48 AM   #207
Sjeng
Sjeng's Avatar
I used exactly this in my rattling M90. Shifts smooth.
Old 10-24-2020, 03:03 AM   #208
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
have you ordered the KL.Racing one or any other?
Old 10-24-2020, 03:14 AM   #209
tomasss
former PRVert
tomasss's Avatar
Ok...in case it rattles with the original oil, I know what oil to switch to
Old 10-24-2020, 03:16 AM   #210
tomasss
former PRVert
tomasss's Avatar
I have ordered it from saabits.com...this one:
https://www.saabits.com/all/volvo-74...lutch-hose-kit
Old 10-24-2020, 02:26 PM   #211
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
nice, curios if it works better..
Old 10-24-2020, 04:57 PM   #212
tomasss
former PRVert
tomasss's Avatar
Means the KL Racing one is not a good fit? Just to know...
Old 10-24-2020, 07:51 PM   #213
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
no, but 5 times more money
Old 10-26-2020, 06:44 AM   #214
tomasss
former PRVert
tomasss's Avatar
Oh, ok. From >this post< I understood that the HEL units are good, and the same manufacturer (HEL Performance) is in the description on the saabits web, so it should be the identical one.
Old 10-26-2020, 05:23 PM   #215
tomasss
former PRVert
tomasss's Avatar
Productive evening today...stock valve springs replaced by the Ford 4.6l ones (Melling VS1268). So relaxing job when you have the right tools!
EDIT: Hmm...just noticed that the manual says to put closely wound coils at the bottom. So few of them to be flipped
Old 10-27-2020, 12:33 AM   #216
Looking good!
I don't wanna derail the thread. Would you please post up the part numbers for those seals in the M90 thread? http://www.forums.turbobricks.com/sh...=94325&page=23 I need the seals for my M90. (I have quad square US 740 headlights for trade.)
I am interested to see the powerband with this engine/gearbox combo. My setups were freeway screamers and not stump pullers. What tire size and rear gears?
Old 10-27-2020, 04:10 AM   #217
tomasss
former PRVert
tomasss's Avatar
Looking good!
The seals that you can still get from the dealership are the input/output seals 9183891-1 and 6843480-1 and also the 978268-1 O-ring.
Other than that you also need the shift linkage seal (Corteco 01019151B, NLA from dealership).
I am using 205/55 R16 tires and 3.73 ratio. Of course also very curious about the way how it behaves on the road
Old 11-11-2020, 03:05 PM   #218
tomasss
former PRVert
tomasss's Avatar
Based on the aristg/Gary's >idea< I've fabricated my stainless steel oring guard ring too
Old 11-25-2020, 06:01 PM   #219
tomasss
former PRVert
tomasss's Avatar
New bigger pistons from Yoshifab finally arrived, so I've gapped the piston ring ends and installed the pistons in the cylinders...hooray!
Old 11-28-2020, 07:46 AM   #220
tomasss
former PRVert
tomasss's Avatar
Maxpeeding conrods got new bearings & were connected to the crankshaft, oil splash guard & oil pump tube & oil pan installed too...it's slowly coming together!
Old 11-28-2020, 08:41 AM   #221
tomasss
former PRVert
tomasss's Avatar
Also a short video once the conrod caps were tightened to the spec:
Old 11-29-2020, 04:11 PM   #222
tomasss
former PRVert
tomasss's Avatar
Is this board still alive?
Anyway...more progress today. Headbolt threads re-tapped, head surface cleaned, headgasket sprayed both sides with Permatex Copper Spray-A-Gasket Hi-Temp Sealant, ARP studs from Yoshifab fitted and head installed!
What surprised me is that the headgasket is missing some coolant passages, is that normal? For example the left side of the first cylinder...
Old 11-29-2020, 05:39 PM   #223
oldschoolvolvo
oldschoolvolvo's Avatar
nice and clean
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 12-11-2020, 06:15 PM   #224
tomasss
former PRVert
tomasss's Avatar
Thanks!
If there is something you really don't want to happen...it is to find out after assembling the engine bottom end that your torque wrench is pretty much off the scale so that's exactly what happened. Set to 80Nm and clicking on 50Nm. That basically meant all my main cap bolts / crank pulley central bolt / oil pump gear were tightened with wrong (too small) torque.
So new calibrated torque wrench, disassembly and re-torqueing all these bolts and re-assembly was a task of today. All is back together so more constructive progress to be done during the weekend.
Oh and also I couldn't resist to put this one from >Pete.M< on
Old 12-12-2020, 04:12 AM   #225
Pete.M
Slow Member
Pete.M's Avatar
Nice. I'm guessing you managed to get someone to convert the image to something usable.
How did you find out about the torque wrench? That's a lucky save.
Pete.M is offline   Reply With Quote
