#51 |
![]() Got enough done where it runs ? Moves under it’s own power. Yowza! This old heap is way faster now.
#52 |
![]() Major life event. Not much to report other than the purge has begun.
#53 |
![]() Spent the day tidying up. Built wire harness for aw70 overdrive. Replaced shifter that was hiding in plain sight. Working on air filter box. Got some great tips from fellow members. 3 40 gallon trash sacks full of duplicate wire harnesses gone to the dumpster.
#54 |
cone dodging dilettante
![]() Hit so hard the tone ring flew out, it looks like!
1993 944 B230FT/M90 thread here: http://forums.turbobricks.com/showthread.php?t=345277 2x 1991 245 B230F/M47 (LeMons car, street car) I sell chips for LH 2.4! |
#55 |
![]() Na. That is was the a/c accumulater holder strap
#56 |
#57 |
![]() The 262 swap has 100 miles on it. Performance is better than expected. Because I have been a wee bit heavy on the go pedal economy is down. Or maybe I didn’t get the tank full?
#58 |
![]() Got the exhaust tidied up. Adjusted trans throttle pressure , it was shifting way late. Spent the evening sorting ecu stash.
#59 |
![]() Under the dash on the 262 looks like a bomb went off in the phone company. Keyless entry remote start non Oem radio. Wires every where. There is a new remote/keyless unit waiting for install. Great opertunity for cleaning up the mess.
#60 |
![]() All of the wiring came from 90 244 with abs and the better a/c. Left front turn signal did not work. So I ran a wire from the switch to the light. Being all the dash is out now is the time to fix. Found a added wire coming out of the body harness with the same colors as the lh turn light. Blinks now. I might have cut the terminal off during the swap not knowing it’s use.
#61 |
![]() LinkR-LT2 installed. Amazed that it works with my meager knowledge of things that go snap crackle pop or flash bang wiz.
#62 |
![]() Should have done this swap long ago. The old b230 with the zf trans was basic transportation. Now it is fun. Only glitch is the keyless entry is not in sync with the linker. Car is locked but the phone app shows it unlocked or app shows its locked but it is not. Now to get rid of the dead bodies. The purge is near.
#63 |
![]() Spent Saturday sorting parts. Where did all of these computers come from? Brackets hinges slim brake booster wheels transmissions. Looks like a hoarder lives here.
