Old 12-11-2020, 09:30 PM   #101
volvowagoon
volvowagoon's Avatar
I just started moving pictures from imgur to my profile. Hopefully this works better for me.
Since it's been so long its time to update. I'm going to do it mostly with a photo dump and not much dialog this time. Sorry in advance. I think you'll get the gist though. I really needed to do something about the rust on the other side of the car. The interior was getting wet any time we drove in the rain.
Somebody before me tried to fix this issue with RTV. Didn't work to well, did it?
Oof. I didn't fully expect this.
The cut I had been dreading...
Bad vibes
Inner well rust cut.
1986 Buick Grand National - Restoring to stock™
2002 Camaro V6 T5 +T - The trashy car that's fun to drive
2010 C30 T5 - The boring but trusty daily
1989 245 DL - The boring but not trusty daily
IG: @v6buick
Old 12-11-2020, 09:38 PM   #102
volvowagoon
Time to rebuild
Needs some pounding.
I had to recreate the mudflap bracket. Getting the muflap to fit in the poorly stamped arch is a chore as well.
Filler time
More filler after sanding
Can you tell I warped the panel?
Yikes
After four coats of filler, I'm finally satisfied with the results. Primer in the morning.
I'm not too happy about how some things never managed to line up. However, I think once all the factory cladding and trim goes back on none of it will be noticeable. After all, this is a daily driver. I'm just going for survival here. lol
Old 12-11-2020, 10:46 PM   #103
Cwazywazy
Single jingle
Cwazywazy's Avatar
Did you buy reproduction panels or hack up a parts car?
I don't know what I have
Old 12-12-2020, 11:46 AM   #104
volvowagoon
Reproduction. After all the trouble I went through to make this one "fit", I wish I had reached out to you guys and had a CA car hacked up for me. There are a few spots that are going to annoy the crap out of me when it's done, but it wasn't worth the effort with my small choice of skill and tools. In the end, this car is just a driver, and it's going to be in much better shape than if were to have left it alone.
Old 12-12-2020, 12:28 PM   #105
white855T
Pictures are not showing up.
Old 12-12-2020, 12:44 PM   #106
volvowagoon
Thumbs down
I might have to resort to an off-topic roast just so that I can figure out how to properly post pictures. Photobucket failed all of us. Imgur updated in a way which I can't figure out how to downsize pictures. Then I tried using the internal turbobricks image hosting, but that's not sustainable since I'm already out of space. It doesn't seem to be working anyway. Not to sound whiny, but none of the other forums I'm on require image hosting or links anymore. I like it here. There's no better Volvo resource IMO, but I can't convey what's going on without pics.
Old 12-12-2020, 04:09 PM   #107
kampman
dunning-krugersquirt
Imgur will resize your pics automatically if you put an l (large thumbnail) or h (huge thumbnail) before the .jpg when you add the url to your post.
-Chris-
1966 220
1984 245T
2006 V50 T5M
Feedback Thread
kampman is offline   Reply With Quote
Old 12-12-2020, 06:13 PM   #108
volvowagoon
Does that still work?? I always just pressed the button, but that's gone now. I'll try it now.
EDIT: THANK YOU! I feel like I can be a functional member of society again.
Old 12-12-2020, 06:21 PM   #109
volvowagoon
Can you see it? Masking
First coat of primer.
The awkward transition from repoped steel to stock. I don't think this will be nearly as noticeable after paint and trim though.
This is the most satisfying part. All sealed up! You can barely tell how bad I hacked this either.
Old 12-12-2020, 06:32 PM   #110
volvowagoon
Post #101 updated. I'll update Post #102 after I apply some more primer.
Old 12-12-2020, 09:30 PM   #111
volvowagoon
I let the third coat of primer dry through dinner. Then I wet sanded with 1000 and 3000 grit. After wiping it down and blowing out the crevices, I applied my first coat of base.
That spot I'm bothered by looks even worse now, but I'm still convinced it will go away when I paint the pinch weld black and apply the trim.
Old 12-13-2020, 02:19 PM   #112
volvowagoon
I got the interior back together. Of course that didn't go without a touch of heartbreak though. I thought I had the seat back installed in it's lower catch but I hadn't. When I went to fold it upright it shattered the plastic C-pillar trim on one side. Then I tried folding it back down, and it shattered the other side. It was total amateur hour, and they looked mint before all this. I can only find them for $75 a piece used. Nobody seems to be repopping them, so I'm kinda screwed. Even if I could get one shipped in one piece, what are the odds that I could install them in the same manner? It's 80s plastic, so I think those odds are slim to none. Cracked is how they'll stay.
I did replace the seat bottom with the one from my old wagon though. I have no idea why I still had it, but it's in better shape than the one that was already in the car. The piping is straight and there are no holes in the vinyl. Why not?
I finally replaced that obnoxious tag light lens. It should actually shine downward instead of backward now.
The best news is that I'm in the clear! ....get it?
Old 12-13-2020, 03:17 PM   #113
white855T
Pictures showing up good. Repair is good.
C pillar trim is available but not cheap. https://www.swedishcarparts.com/mode...-pillar-covers
Old 12-13-2020, 04:15 PM   #114
volvowagoon
Thanks!
That was the site I was looking for earlier. I figured if anybody had them it was them. I'll bookmark it. Although it's not cheap, I'd rather buy those brand new than try to fool with OE stuff.
Old 12-13-2020, 09:51 PM   #115
volvowagoon
I'm coming close to my deadline.
Did I mention WHY I'm rushing through this work so fast? Roadkill life! I started cutting this car up only a day before I went on a trip in the Camaro. I was planning to rely on that car to get me to/from work while I did this. Afterall, it had been running/driving just fine since the transmission replacement. I drove that sucker all the way up to the western Chicago burbs from southern Indiana and back in a day. It was pretty fun. Long story short, I chucked 3rd gear out of the T5 again just several miles short of my driveway. Suddenly the 240 became the easier candidate to get on the road again. Okay, okay, maybe not EASIER, but certainly cheaper! I was already lending my other daily to my fiance, so that left us with one car capable of getting us to work. I tried to do all this in a weekend, but that proved impossible without hacking it too bad. We borrowed her dad's Hummer for a week. It's back in his driveway now, so I have to hussle!
Time to paint the lip and rocker tip black
Since I'm officially out of things to do until the paint is cured, this is how I'll be rolling into work tomorrow. It's not the debut I was hoping for, but oh well! I have some 3M trim tape which will secure the arch trim and modesty panel. I also have new clips for the rocker trim.
I was very excited to be able to take this picture without a glare from the busted tag light housing. lol
Old 12-13-2020, 10:58 PM   #116
Cwazywazy
Single jingle
Cwazywazy's Avatar
Wanna do mine next? I started buttcheek replacement but it's trickier than I was expecting. And the other side's worse.
Old 12-14-2020, 03:33 AM   #117
Scaramanga
Well done but why the heck did you paint the arch black? And what about the trim? Is that an US option? Swedish cars never had those
I wish I had the guts to cut and weld like you did
Volvo 145 1972, 245 GLT 1991
Scaramanga is offline   Reply With Quote
Old 12-14-2020, 08:47 AM   #118
volvowagoon
Haha I am hoping to avoid body work for a long time. I'm glad I was able to get this done cheap, but it's very time consuming. It's still not done very well either. In the future, I hope I can buy rust-free cars, keep them that way for a long time, and pay somebody else to deal with it when the inevitable happens. This repair was good enough given the fact that it's already out in the salt again, but it's far from professional. Good luck on the butt cheeks. I haven't had the pleasure, but they certainly don't look fun.
It will make more sense when I post the final pics with the trim attached, but the arches just don't look right to me when the trim is installed and the whole thing is painted body color. The trim is black and the pinch weld should be as well. Here's an example I found online.
I think the black arch trim only came on 86+ cars. It appears that GLs got chrome. Maybe somebody else knows for sure.
Old 12-15-2020, 03:44 AM   #119
Scaramanga
Ah that must be some US dealer special trim. They never left the factory that way But I can understand that they can help out hiding repairs in the arches.
Old 12-15-2020, 08:47 AM   #120
volvowagoon
It might be a North American thing. When I did some googling, I noticed that none of the cars with glass headlights had the trim. However, just about every '86+ 240 I've seen has had a strip of some sort on the arches. Sometimes its the black one like I have, and sometimes it's the residue it left behind. Some of the upscale versions -'85 had a chrome one too.
Anyway, I'm done. I just need to wash and wax it in a couple days. Then I'll call it "good to go!"
Old 12-15-2020, 09:10 PM   #121
IansPlatinum
IansPlatinum's Avatar
My god. Incredible! I need to harness your energy & skill for the rusty quarters on the 145.
Looks great man. Super impressed
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'93 Land Cruiser - "Ruby"
'01 Cherokee - "Janice"
Old 12-16-2020, 08:18 AM   #122
volvowagoon
Thanks! It's got some areas that I'm not particularly proud of, but it took every ounce of energy I had to complete. I think it's good enough for prolonging the life of a daily driver.
Old 12-16-2020, 08:28 AM   #123
volvowagoon
Also, how's that refresh going? I haven't seen an update in a while.
Old 12-16-2020, 10:05 AM   #124
IansPlatinum
I know, I've been lazy on updating my thread
Everything's good, I'm driving it daily now since the 850 blew a headgasket. I'll scrub the engine bay and take some photos
Old 12-16-2020, 10:22 AM   #125
volvowagoon
You're done?! Dang! I can't wait to see it.
