Old 10-24-2020, 07:37 PM   #51
Cromlech
Cromlech's Avatar
Coming along nicely!
Cromlech is offline   Reply With Quote
Old 11-02-2020, 11:18 AM   #52
jstblz
jstblz's Avatar
***There will be a video at the end of this post!***
PTP Turbo blanket
Downpipe just to get the car started. It'll eventually be wrapped in PTP lava wrap. This will lead to a full 3" exhaust.
Finished up all of the front end wiring...
Good quality and bright LEDs for the headlights
I made this plate to hold the relays for the headlights and driving lights and front power distribution.
It hangs off the 2 bolts that hold the Miata wiper fluid reservoir.
Thiccboi radiator from Speedway
Made a bracket for the coolant tank w/ a fluid sight and a cover/upper bracket for the rad
84 242 TIC
jstblz is offline   Reply With Quote
Old 11-02-2020, 11:21 AM   #53
jstblz
jstblz's Avatar
Here's your gift for being so patient!
First Start!
Old 11-02-2020, 12:05 PM   #54
patrickstar
patrickstar's Avatar
First Start!
Congrats, that sounds incredible. Whats next?
1983 242 - 4.8/AR5
1980 242 - Daily
1980 242 - Shell
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 11-02-2020, 12:21 PM   #55
jstblz
jstblz's Avatar
Thanks!
Finish the cage, mount the seats, start finishing the wiring (audio, interior fuse box, accessories - until my eyes bleed), and the shaft for electric power steering.
Old 11-02-2020, 12:39 PM   #56
patrickstar
Thanks!
Nice, excited to see the final product.
Is the 2.3 a viable swap for the masses? This and the Ecotec from GM seem like good options for the Volvo community
Old 11-02-2020, 03:21 PM   #57
jstblz
jstblz's Avatar
I think so, but the motor is pretty tall. The motor can be had from all sorts of cars, obviously the mustang is the only RWD one and the FPP wiring kit made the electronics fairly simple.
Old 11-02-2020, 04:41 PM   #58
culberro
culberro's Avatar
I'm curious how the NPR intercooler will work with the FPP tune. The FPP tune on the 2.0 Ecoboost was a little zesty and it would go into limp mode from the charge temps being too high. I had to send the ECU back to Ford a few times to get a tune that worked well for racing, there's a few 2L engines with holes in lots of pistons and cylinders sitting in the corner of a friends barn. The initial tune was wayyyy too aggressive with boost and timing, and it pretty much ignored the knock sensor(?!?!?!). This was an issue they were starting to see in a few off road buggies/trucks that were using the 2.0L as well. Now SCT and a few others offer tuning kits for the the ecoboost swaps, but back in 2016 it was the dark ages... no one could tune one using the FPP ECU.
All this to say, keep an eye on things.
Old 11-02-2020, 06:35 PM   #59
RvolvoR
HPTuners support its now, iirc. That would probably be the best way to go.
Old 11-03-2020, 01:04 AM   #60
jstblz
jstblz's Avatar
Thanks for the info! I'm going HP tuners, so hopefully I'll be taken care of.
Old 11-03-2020, 10:59 AM   #61
Tfrasca
Tfrasca's Avatar
That was quick! This makes me want to want to scrap my engine swap and steal the 2.0 from my wife's Escape...
Old 11-03-2020, 02:45 PM   #62
jstblz
jstblz's Avatar
Lol it's not that quick. I wanted to make sure I had a running car before telling anyone about it, but I've been working on it since late November. On the free weekends and evenings. Covid did slow things down a lot.
Old 11-03-2020, 03:02 PM   #63
culberro
culberro's Avatar
Do it. Especially if you can fit the engine in (length and height). The 2L with the controls pack drives super well (amazing DBW throttle feel), and still returns near OEM fuel economy.
With the 2L, you can swap on the 2.3 intake, oil pan, and upper water pipe. Basically making all the accessories be RWD oriented for a few hundred dollars.
There's also a ford t5 adapter kit, or you can use the mustang trans/flywheel/clutch/starter.
Or you can use a NC miata trans/clutch/flywheel/starter and pray it holds together (it won't btw...), but it's really easy to make it work.
Old 11-03-2020, 03:28 PM   #64
vertigosity
vertigosity's Avatar
2.0T is a little shorter (difference between the 2.0, 2.3, and 2.5 is all in deck height + stroke), but Ford stopped making the "control pack" for it due to lack of interest / to focus (pun intended?) on the 2.3T kit. I'm not sure if the 2.3T control pack would directly work, but it would definitely need to be retuned, for whatever that's worth. Maybe someone dumped the 2.0T pack's ECU's tune and you can just directly load it? Not really a lot of good information out there on oddball configurations, kinda just have to dive in.
93 245 5.3L LSx / 90 Miata / 90 Spec Miata
Old 11-03-2020, 05:47 PM   #65
You could just use the MT-82...
Old 11-03-2020, 07:35 PM   #66
culberro
culberro's Avatar
That's too logical for TB, and you know this!
Old 11-03-2020, 09:46 PM   #67
jstblz
jstblz's Avatar
Old 11-04-2020, 10:50 PM   #68
SquareD
An Anomaly
SquareD's Avatar
Dang dude. Nice work getting it running that quick! Sounds good!
1994 945ti | 15g @ 15psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits.
Old 11-05-2020, 09:47 PM   #69
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
****in whoa dude
Old 11-06-2020, 09:39 PM   #70
jstblz
jstblz's Avatar
Originally Posted by Wilford Brimley View Post
****in whoa dude
Thanks guys!
Old 11-16-2020, 12:43 PM   #71
jstblz
jstblz's Avatar
Default Working on the cage
My main focus was to add safety, but be as unobtrusive as possible as I'm 6'5" 300lbs and this isn't a "full race" build.
Plates added for front posts and main hoop
Rear section
The dash structure still fits!
Up next is the seat mounting and making the harness and door bars to finish the cage.
Old 12-03-2020, 12:12 AM   #72
permavirgin777
Interesting, Great work.
I've given thought to doing something similar around the fuel sender area. I still might, just have a better idea of what it will look like now...
permavirgin777 is offline   Reply With Quote
Old 12-03-2020, 06:03 PM   #73
dmacl
I've seen a few cages done like this and wondered why - specifically where the tubes land on the rear wheel tubs.
In a car with strut tops near there it would make sense, but in 240s the dampers and springs mount on the chassis rail inboard of the wheel tub.
Would it not be stronger / give more rigidity to the car to run the cage through the rear firewall and land it in between the spring and damper mounts?
I'm not criticising, I'm just hoping to learn something!
dmacl is offline   Reply With Quote
Old 12-03-2020, 07:51 PM   #74
RvolvoR
You are 100% correct. Running the downtubes to the rear wheel wells isn't the best idea on a 240. Its a lot better to go through the rear firewall and down to the frame rails where the shock/spring are mounted.
Old 12-04-2020, 10:48 AM   #75
Its much better to run it to the frame rail like you are saying... its easier to run it to the wheel wells so that where people go.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
