Old 01-31-2021, 07:02 PM   #101
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Originally Posted by jstblz View Post
I'm not sure yet. I'm going to definitely get it tuned so I can make the most out of the bigger wastegate spring, big intercooler, big exhaust and intake, running 93 octane, and colder spark plugs. A friend has HP Tuners and they support the Ford Performance kit it so I think I'd like to find someone to tune it with that instead of having to buy the accessport ($630ish last I looked) and then have someone tune it.
- The kit
All good! I swear that clutch line connector is newer. I didn't see it last winter when I was researching for the failed clutch setup. Your setup looks cool!
Thanks for the link - yeah - I wouldn't need the entire kit.
I've never seen the hose end for sale before, so likely it is as you say, a newer addition.
I'm enjoying your build, precisely because you are including the nitty-gritty details & not glossing over the grunt work it takes to get things right.
Old 01-31-2021, 09:02 PM   #102
jstblz
jstblz's Avatar
The 1-hour car build shows kill me because of the lack of details. Plus my memory is garbage so this helps the process haha.
84 242 TIC
jstblz is offline   Reply With Quote
Old 02-01-2021, 10:17 AM   #103
lookforjoe
lookforjoe's Avatar
The 1-hour car build shows kill me because of the lack of details. Pus my memory is garbage so this helps the process haha.
EXACTLY why I do the same
Old 02-01-2021, 12:58 PM   #104
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
cool project!
Megasquirt Tuning!
Old 02-01-2021, 01:29 PM   #105
jstblz
jstblz's Avatar
cool project!
Thanks!
Old 02-05-2021, 03:37 PM   #106
dorvin
idunno
dorvin's Avatar
Impressive build, nice work!
'77 Oldsmobile Cutlass Supreme
'85 Cadillac Eldorado
'91 Volvo 740
'93 Volvo 240 - 683/1600
'12 Volvo S60 T5
dorvin is offline   Reply With Quote
Old 02-27-2021, 06:26 PM   #107
jstblz
jstblz's Avatar
Thanks!
Old 02-27-2021, 08:34 PM   #108
jstblz
jstblz's Avatar
Default *3D printing zone*
So I don't know how many of you are interested in 3D printing, but I lucked up on a Creality Ender 3 Pro. I've wanted to learn more about the process so I decided to include it in my build.
With the way the cage is, I didn't have room to mount the OEM mirror and I didn't like seeing all the bars behind me that also blocked my view. I picked up a digital rear view mirror that also has a front facing dashcam. The rear camera will be mounted in the rear window.
The Dashcam
This is supposed to strap onto the original mirror, but since I wouldn't have one, I had to engineer around that. Starting in Fusion 360, I went with this design 1st. (*I'm a 3D modeling amateur. Please be nice or helpful.)
Which turned into this quick and dirty model printed in PLA.
This and future pieces were printed ASA as to better withstand the interior temperatures that a summer car can reach. A notch was added to tuck the mirror a little closer to the bar.
Then came the destructive testing. This was also to see how the orientation of the print affected the strength in the direction of possible forces.
I then had to make the cage clamps out of ASA too. As you can see, I decided to go with a GoPro style mount. It's simple and it works.
And we're left with this...
IT WIGGLES SLIGHTLY WHEN BUMPED OR JOSTLED. I HATE IT.
Let's try again.
Old 02-27-2021, 09:30 PM   #109
Jerd
Jerd's Avatar
Let's try again.
Really cool stuff man.
Old 02-27-2021, 11:17 PM   #110
Duder
Comes with a free Frogurt
Duder's Avatar
That's a super cool product and nice mount you designed too.
The GoPro style clamped joint might not be able to cope with that much mass cantilevered off of it. You could try doubling it up, with two mounting points and two clamps. Either way it would be good to add a fillet radius at the base of each tab where it joins into the main base of your mount.
Old 02-28-2021, 10:45 AM   #111
jstblz
jstblz's Avatar
I never thought about that base radius, but that's a great idea.
Old 02-28-2021, 10:57 AM   #112
jstblz
jstblz's Avatar
Default 3D Model II: The Sequel
The very cool thing about Fusion 360 is it's timeline feature that allows you to go back and make changes to old designed pieces and the change reflect to the current iteration of the part. I went back a few versions and made a new branch.
*FYI putting holes in a print saves material only and not time! Holes create new faces and walls/faces are printed slower than infill.
The new design:
Very proud that I saved 6 grams of material with this design!
Solidly mounted now!!
Old 02-28-2021, 01:53 PM   #113
Duder
Duder's Avatar
New mount looks great! Curious to read your review of this mirror mojangus once you get the car out on the road. Don't forget to "remove it off before use" though.
I haven't played with any DI engines or tuning yet but hopefully in some future project. Kudos to you for diving in and figuring out the 2.3 EB swap in the 240 though! I like your approach. We need in-car video once you're able to hoon it around on the road.
The turbo setup on the 2.3 is a weird one, with the unique twin scroll turbine inlet flange arrangement and the fact that it's reverse rotation (CCW viewed from front). If you need any info on the turbo itself I'm happy to help.
Old 02-28-2021, 02:11 PM   #114
patrickstar
patrickstar's Avatar
Thats awesome, cool product. The piece you printed looks professional, something I'd buy off the shelf.
What are your plans for gauges/filling in your dashboard? I'm at about the same place, have a dash but nothing in it
1983 242 - 4.8/AR5
1980 242 - Daily
1980 242 - Shell
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 02-28-2021, 03:22 PM   #115
Jerd
Jerd's Avatar
Love the last revision. Very nice!
Old 02-28-2021, 05:36 PM   #116
jstblz
jstblz's Avatar
Thank you! I'm close, I can't wait. There will be plenty of video. I'll reach out if I do!
That's upcoming. Digital dash with at least 2 separate gauges (fuel and external temp). It's overly involved like everything else I'm doing haha.
Appreciated!
Old 02-28-2021, 08:36 PM   #117
aidanahunter
aidanahunter's Avatar
Was going to say the same thing - fillet tool is the best. I designed injection molded plastic parts with SolidWorks for a few years.
I see you're in PA also. If you ever put your 240 in a car show this summer, let me know. I think it'd be cool to have two Ford-powered 240's next to each other!
Aidan
4.6 32V 240 Wagon
aidanahunter is offline   Reply With Quote
Old 03-01-2021, 02:07 AM   #118
jstblz
jstblz's Avatar
Hell yeah!
Old 03-01-2021, 11:03 AM   #119
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I literally had no idea there were digital rear view mirrors. That’s awesome.
Old 03-01-2021, 01:35 PM   #120
Tfest
Hipsters ruin everything™
Tfest's Avatar
I love this thread. Isn't it nice to have a 3D printer?
Tfest is offline   Reply With Quote
Old 03-01-2021, 01:50 PM   #121
jstblz
jstblz's Avatar
Yeah I think they are for panel vans and trucks with poor visibility.
So nice!
Old 03-01-2021, 02:26 PM   #122
R-Pow3R3d
Master of Disaster
R-Pow3R3d's Avatar
I like that this car is "relatively" close to me so I can go on with my days imagining I might one day see it. Cool build!
1990 745 Turbo Intercooler
2007 XC90 V8 Sport
2007 XC70
R-Pow3R3d
R-Pow3R3d is offline   Reply With Quote
Old 03-01-2021, 03:22 PM   #123
jstblz
jstblz's Avatar
I'm building it in Washington, PA, but I live in the Dormont/Brookline area.
Old 03-01-2021, 10:28 PM   #124
R-Pow3R3d
Master of Disaster
R-Pow3R3d's Avatar
I say I'm in Pittsburgh. Really, I'm like an hour NW of the city. About as close to the actual city as I might get with any regularity would be if I end up taking a job in Cranberry. I sometimes also go to Forest Hills to visit some of my wife's family. So while it seems unlikely, I'm going to press on with the positive feeling that there's still a chance.
Old 03-02-2021, 03:21 PM   #125
jstblz
jstblz's Avatar
I have family in the Cranberry area. Hopefully we can link up this summer.
