Old 01-16-2021, 10:12 PM   #1
swedish-rocket
Default Project Get Out of Its Own Way V.2
Something I’ve been wanting to do but was having a good time building
a fun B230 Volvo that would get out of its own way is to put a cammed V8 into
my first car. I got this car back in high school in 1997. It wasn’t until I retired it as my daily driver back in 2010 I really started toying with the car. Fast forward 11 years and after going from a 18.6 to 12.9 Quarter mile it’s time to replace the Redblock with a LQ4 6.0, Gt45 and 4L80E.
swedish-rocket is offline   Reply With Quote
Old 01-16-2021, 10:19 PM   #2
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Glad to see you here! If you want you can go check out my thread a few lines down under Andrewhans.
I will 100% suggest you lose the GT45 turbo. They are super outdated and even if given one for free I wouldn't run it.
Grab a 7875 of nearly ANY generation and it will way out perform the GT45.
Current setup - Aluminum L33/Summit Turbo Stage 2, Billet 80mm turbo, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
Old 01-16-2021, 10:53 PM   #3
swedish-rocket
Thanks for mentioning about posting! I’ll probably change the setup many times in the future. Gt45 will be a good starter turbo and pretty affordable. I changed the turbo 4 times on B230 through the years. Part of it was just out of curiosity how they will perform. I’ll look into a 7875 in the future. Btw your car is very impressive!
Old 01-16-2021, 11:10 PM   #4
2turbotoys
Salaminizer
2turbotoys's Avatar
Nice, looking forward to seeing the project.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 01-16-2021, 11:16 PM   #5
swedish-rocket
LQ4 engine that I took apart to clean up.
Old 01-16-2021, 11:21 PM   #6
Vol242vo
Keep it clean...
Vol242vo's Avatar
Cool!
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Vol242vo is online now   Reply With Quote
Old 01-16-2021, 11:25 PM   #7
swedish-rocket
Getting the Motor cleaned up and installing a BTR stage 2 camshaft.
Old 01-16-2021, 11:31 PM   #8
swedish-rocket
More motor work. I flipped the LS truck manifolds forward just to find out they hit.
I welded a 2.25” pipe and V band to get around the power steering pump.
Old 01-16-2021, 11:39 PM   #9
swedish-rocket
The motor is now ready for installation. I’ve added 50Lb injectors, purchased a Holley Terminator Max , installed the correct push rod into the motor. Torqued everything to spec. I will be removing some items when I goto drop the motor in but first I will be removing the B230FT and Aw72L from the car which I will start working on soon.
Old 01-17-2021, 12:05 AM   #10
swedish-rocket
Thank you!
Old 01-17-2021, 12:15 AM   #11
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Ahh I didn't know you already bought it. While you're fabbing your hotside design it to eventually swap in a better turbo. The 7875's are pretty much all smaller(physically) than the gt45. Shouldn't be too difficult to fix the downpipe once you get to that point.
Thanks!
Shooting for 8's this year with the addition of the billet 80mm, a transbrake powerglide and an 8.50 cert'd cage.
Old 01-17-2021, 12:24 AM   #12
swedish-rocket
Thanks!
Just crazy that 8 second 1/4 and Volvo is a possibility. I wish you luck getting that time slip. There is a good chance that even with my setup I may see a 10 second 1/4 mile someday. Maybe even before my 03 Cobra in the photo above,haha.
Old 01-17-2021, 12:30 AM   #13
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
10's are a joke in these cars with a boosted V8. Even with the GT45 its doable. If it dyno's anything near 550whp and you leave off idle with a 235 drag radial you will run a 10.
These cars are REALLY good for drag racing. 8.8 swap, LSD and a drag radial will let it really move out
Old 01-17-2021, 12:39 AM   #14
swedish-rocket
Iím probably going run about 7 psi on pump gas first. Probably will have to goto larger than 340LPH pump if I go E85. Iíll probably swap in my Volvos 80lb injectors when it becomes time. Just taking small steps until I get the kinks out.
Old 01-17-2021, 01:20 AM   #15
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
If you haven't bought the pump yet just go straight to the walbro 450 and deka 80's. Helps you from having to redo things later on. Depending on your end goals you will very likely need more injector and pump than a 450/deka 80 can deliver on e85. They run out pretty early imo.
Gonna be a really fun setup. Low 11's will likely be where you land at wastegate pressure on pump gas.
Old 01-17-2021, 10:26 AM   #16
swedish-rocket
I have a 340LPH pump installed when I did the B230 Turbo Upgrade. I got a set of 8 50LB injectors as Christmas gift for LS swap and will be fine with 550-600whp on pump gas or Race gas. As soon as I go E85 I would upgrade the injectors and sell what I have.
What base pressure are you running on your car?
Old 01-17-2021, 10:03 PM   #17
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
When I had the factory truck regulator it was around 58psi. That was the single 450 ran at 18v over 4psi and deka 80's.
Now I have a PQY regulator(43psi base), Bosch 210's, the same old 450 in the tank and two AEM 400's sumped off the bottom of the tank. All 3 run when over 5psi of boost.
Old 01-18-2021, 07:40 PM   #18
swedish-rocket
Going to start removing the B230FT tonight.
Old 01-19-2021, 01:23 AM   #19
swedish-rocket
I spent couple hours on the car tonight. Removed the antifreeze, power steering fluid, unbolted the torque converter, disconnected fuel lines and removed some turbo piping. I’ll probably pull the motor Thursday night. The 90 dollar T3/4 turbo is still in great shape after two years of up to 35psi of boost.
Old 01-21-2021, 01:23 AM   #20
swedish-rocket
Spent couple hours tonight removing the transmission.
Old 01-22-2021, 12:41 AM   #21
okoye
okoye's Avatar
what radiator is that?
Old 01-22-2021, 04:45 PM   #22
swedish-rocket
Spaced up 3/4Ē.. fits great in the stock location.
Old 01-22-2021, 11:24 PM   #23
qwkswede
faster than you think
What flavor of GM transmission is that there in your pictures? Do you have to do any internal improvements to make it live with the 550hp you are about to make?
-Ken
1967 Volvo 122S
1992 Volvo 745 driver
Old 01-23-2021, 07:56 PM   #24
swedish-rocket
[url=https://ibb.co/wgnDwfp]
Old 01-23-2021, 07:58 PM   #25
swedish-rocket
4L80E, Iím going to run it the way it sits with maybe a highstall converter. If it doesnít hold up Iíll send it over to xtreme transmissions for a modified rebuild.
