bg004130
- Sep 5, 2017
- Bulgaria, Sofia
Hi,
Is it possible to make the 1.6 B4164S into a 1.9 T4(B4194T)?
Bore is the same at 81mm.
My concerns are to do with one being a N/A motor and the other a turbo one.
Do both have the same block- for example oil sprayers under the pistons?
Can I put the T4 conrods on the 77mm crank? Is the deck height the same?
The most important question however is- is the gearbox bolt pattern the same as on a 5 cyl?
Why the 1.6? Because laws here suck, that's why. F*cking T?V...
