Old 03-23-2014, 10:12 PM   #26
77volvo245
77volvo245's Avatar
Cleaned the casting on the intake ports and painted outside. Using long intake studs so Ill be running some phenolic spacers
STSmachining
Old 04-04-2014, 01:07 PM   #27
77volvo245
77volvo245's Avatar
little progress on the coilovers
Thread milled the saab gland nuts to the volvo thread.
Sand blasted the strut tubes I still need to weld the rings onto the struts.
Old 04-04-2014, 02:24 PM   #28
stick70
All the gauges
stick70's Avatar
I'm liking where this is headed. ITBs are a win in my book every time.
Old 04-04-2014, 02:29 PM   #29
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
5 star thread!
Great progress so far, great job!
Old 09-25-2014, 11:24 PM   #30
dkrause
Very nice, is the motor running now? Any reports on performance.
I like your idea of using a cutdown FT piston there still should be enough piston to the top ring to prevent burn through. I question the 11.1 compression ratio when stock AQ151 is 9.7:1. Have you shaved the head aswell?
dkrause is offline   Reply With Quote
Old 09-26-2014, 12:00 AM   #31
77volvo245
77volvo245's Avatar
No, its not running at this point or had made any progress worth a update. The pistons are .012 above deck and using a stock head gasket to get the compression ratio needed.
I did buy two cnc machines a couple weeks ago, been focusing to get them running and my shop insulated.
Old 09-28-2014, 11:20 PM   #32
242 glt
242 glt's Avatar
ohhh I know those units, nice.
1984 242ti I has turbo again
1985 volvo 244dl
1989 volvo dl
1967 Plymouth GTX HT, 4spd, 360, 391 posi, daily driver.
1964 Plymouth Valiant 2d post, Welded frame conn, torque boxes, super slant 6 project, now daily driver.
242 glt is offline   Reply With Quote
Old 06-01-2017, 03:50 AM   #33
77volvo245
77volvo245's Avatar
After a few years from my last post a lot have changed personally. My last job I had back in 2015 closed down and was something that was bound to happen that last 6 month I worked there. While still
employed I made the jump and purchased my own CNC machines. The last two years I've worked on other projects car and non car related. The GT has been sitting the same spot for a number of years. I decided to pull the car in a do some actual progress. I ripped the entire interior out and the carpet. I know the sunroof leaks, I wasn't sure if it caused damaged from water sitting inside the car from the years sitting. Some surface rust under the carpet and some holes in the floor on the passenger side at the drain plug. I already ordered a passenger floor pan. I already DA the car but going to stripped the car completely. I'm going to take all the panels that can be removed to be soda or walnut basted.
Old 07-12-2018, 02:06 AM   #34
77volvo245
77volvo245's Avatar
I Purchased a new 242 GT. it's a 1980, I really don't care that it as butt cheeks for the spare tire. I don't have pictures at the moment. overall the outside it more presentable than my 79. The 80 GT has been repainted 10 years ago? I've decided if I'm going to get this project going is to start with one thing at a time and still having the 80 242 drivable. I've started with the getrag conversion.
I design brackets for the shifter and had them laser cut and cut a modified the m46 shifter to length. Im very close to have everything to complete the swap and then going in the 242 with the original b21f in the new 80 GT. All there is left to do is driveline and trans mount.
Old 09-05-2018, 10:43 PM   #35
77volvo245
77volvo245's Avatar
here is the new GT that will replace my old 79 242. I've know about this car for about 10 years. Finally the owner decided to sell it, I had another chance to buy a couple of years ago but she decided to keep it. I bought a set of c30 seats, I only installed the drivers side as of now. I machined my own coilover tubes direct fit for saab shock inserts. Been planning on the next step for the itb air filters. Jenvey does not have a backing plate with the volvo spacing so I'll be buying a blank template and machine out the holes with the correct spacing. Will be using jenvey throttle linkage as well.
Old 09-06-2018, 09:18 AM   #36
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Those are really nice pieces! I wish I could ditch my T5 for a Getrag swap someday.
1980 242 Turbo
2004 V70R
Uncleknucklez is online now   Reply With Quote
Old 09-06-2018, 12:24 PM   #37
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
Those seats are awesome!
'88 245DL Uncle Sven|'95 945T Darth Haul|'82 242GLT B23E Lumpy the Angry Viking (sold)|'77 244DL, red/sold.|'90 744T C3P-LOL, gold/sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 09-10-2018, 12:06 AM   #38
Can play the blues
I know how things can be. I'm slow with projects. You're doing some wonderful work.
Old 09-11-2018, 12:31 AM   #39
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
if the trunk stripe goes straight across, instead of following the indentation in the lid, I know who owned that car many years ago. Was one of the former PSVCOA chapter presidents.
Old 11-26-2018, 04:49 AM   #40
77volvo245
77volvo245's Avatar
For anyone that want to have a motor built in the portland metro area I do not recommend M&B cylinder heads in NE Portland. After having the short block assembled by M&B and I felt something wasn't quite right. The short block was very hard to turn over by hand and thinking the cylinder wall to piston gap was tight. I decided to have another machine shop take a second look. They have found out the bores were tight and tapered. Also It wasn't really necessary but I had M&B do a line bore of the block for the stroker crank. The new machine shop had found out the line bore that was performed was not even straight. I basically paid twice to have my motor worked on by two different shops.
Anyway I have made some progress. I had to repaint the block. The new machine shop decided to take the paint off the front around the water pump and front seal plate. Also for anyone that wants to use a penta 531 head you need to drill a tap the head for the coolant temp sensor. Also there is a hole for a coolant passage by number four intake port that needs to tapped with a M14x1.5 tap.
I powder coated a valve cover and polished the VOLVO letters. I had to wet sand the areas that were not taped off from powder coat. Then wetsand again with 2000 grit then polished.
I did purchase a air filter and backing plate. Also the throttle linkage from jenvey.
My coilovers are almost completed and will be sent to platting soon. Also a video of clamping in the lathe to bore the old strut tube from the spindle. Then press out to insert the new strut body
At this point when I'm ready I'll be removing the b21f out of the 242 instead of putting the getrag and doing the whole thing at one go. Ill be prepping the engine bay myself and having someone paint it instead since I'm not quite setup at the moment.
I have too much going on and try to take on too many projects. My goal is to have this done by spring.
his name was wes? the floor mats were personalize with wes's 242 GT. I threw them away because of mold.
Old 01-16-2019, 11:20 PM   #41
jmc0369
jmc0369's Avatar
Looking great! I cant wait to hear that motor.
Member: TBCCS
"Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who!
"It is no measure of health to well adjusted to a profoundly sick society" - Jidu Krishnamurti
jmc0369 is offline   Reply With Quote
