oldschoolvolvo said:
Do you have any pics of the oil cooler installed in your 242? I'm planning out a +T swap and am having trouble visualizing where the stock 240T oil cooler is mounted. Thanks.
Here you go. In the first pic you can see it sits next to the intercooler. It rests on the rubber grommet used for the air box in NA cars:
Cold side intercooler neck. View from right above battery tray. Had to bend the bracket ever so gently. Still touches intercooler. Bothers me, but not enough to take it all out again. Too many things to do. Will bother with it once I find black paint that does not look brown in the sun and I get around to respraying everything:
This pic is from above the passenger fender. both lines cross over and down below the crank pulley:
You can see the same soft lines under the crank pulley, There is a bracket that holds the hard lines that shares mounting points with the alternator. They snake further toward the passenger side fender, then curve above the crossmember:
View from passenger fender. At this point I think it's pretty self-explanatory:
Let me know whether you need some more help!
Harald
