volvoboy90
sanna kärlek är svensk
- Jun 1, 2011
- Dayton, Ohio
Hey all, In the midst of trying to figure out a poor running issue on my 244, I thought I would try to re-tune. I had just gotten to the main fuel map, and was adjusting parameters when it just suddenly, flat-out died. So I reverted back any changes I had done, and tried to start. I noticed the fuel pump wasn't priming. After messing with several things, it seems it was the ostrich that caused the issue. I know the internal battery can die, but does it cause this issue? I looked inside, and it seems like it might be a pain/destructive to pull the battery out since the contacts seem to be soldered onto the battery itself. Has anyone had this issue? I put the stock chip in the ecu and it is now running, so it was the ostrich.
