Closed Thread
Old 02-14-2017, 07:39 PM   #476
Mesoam
Mesoam's Avatar
be prepared for that wrap to turn white unless its coated, just did the header and mid on my ducati and already running into this
08 XC90 R-Sport
Mesoam is offline
Old 02-14-2017, 08:02 PM   #477
cosbySweater
cosbySweater's Avatar
meh thats the least of my worries
cosbySweater is offline
Old 02-14-2017, 08:32 PM   #478
Mesoam
Mesoam's Avatar
i figured, unfortunately i need to correct this
funny enough the Ti color stuff doesn't fade like the black
Mesoam is offline
Old 02-14-2017, 08:47 PM   #479
volvoboy67
volvoboy67's Avatar
Where did you source those clamps you used on the downpipe wrapping? I like them much better than the type I've used on wrapped headers in the past couple of years.
DD: 2004 GMC Yukon XL, lowered 4" Front, 6" Rear, staggered 20s, custom paint work, built engine and trans, just under 500HP.
Project DD: 1965 122s coupe, very lowered, bare shell resto with full custom paint, modded B18, M41 OD trans, staggered wheel and tire combo, lots of Dynamat.
Feedback here: http://forums.turbobricks.com/showthread.php?t=208560
volvoboy67 is offline
Old 02-14-2017, 09:51 PM   #480
ryanfay
more bounce to the ounce
ryanfay's Avatar
Erik you have the coolest avatar ever!
ryanfay is offline
Old 02-15-2017, 12:09 AM   #481
122power
dude
122power's Avatar
tonus
122power is offline
Old 02-15-2017, 10:58 AM   #482
cosbySweater
lol, well too far into this car to get discouraged about a little mishap. i bought this from work yesterday. it has a late model 4l80e and a gen 4 6.0! this project just grew up
Old 02-15-2017, 01:31 PM   #483
Tfrasca
Tfrasca's Avatar
Will the 6.0 just bolt in with the mods you did to fit the 5.3?
Tfrasca is offline
Old 02-15-2017, 01:57 PM   #484
toms_elleck
toms_elleck's Avatar
What a weird issue to have. I've never seen a gerotor pump fail. Did the metal just crumble?
Great attitude! Keep plugging away at that thing. It's going to be fantastic once it's on the road.
-Thomas
toms_elleck is offline
Old 02-15-2017, 03:14 PM   #485
cosbySweater
so heres my diagnosis. i think the 5.3 wa in a vehicle that had a nasty front end collision. it cam with no balancer on it. i took the balancer off and cranked it and found the end of the crank was bent! so what im thinking is when i ran it up on higher rpms the gerotor dislodged and **** the bed completely. oh well live and learn. i took a risk with it and luckily nothing major was damaged. the 6.0 will take everything i have off the 5.3 so its no biggie. also i drove this van and i know the trans and engine work flawlessly. so thats good piece of mind!
Old 02-15-2017, 03:17 PM   #486
Tfrasca
Tfrasca's Avatar
That's crazy. Glad the new one will drop right in, though!
Tfrasca is offline
Old 02-15-2017, 03:58 PM   #487
122power
dude
122power's Avatar
Hmm maybe that's why it was so cheap
122power is offline
Old 02-15-2017, 04:08 PM   #488
cosbySweater
it was in a porsche originally and the dude ripped it out. oh well. ill slam it together and have a spare
Old 02-15-2017, 04:17 PM   #489
122power
dude
122power's Avatar
Hilux ls?
122power is offline
Old 02-15-2017, 04:34 PM   #490
cosbySweater
that thing is long gone.
Old 02-15-2017, 09:59 PM   #491
qwkswede
faster than you think
Will the 4l80e require more firewall bending? Assuming you are using the heavier duty trans.
-Ken
1967 Volvo 122S
1992 Volvo 745 driver
qwkswede is offline
Old 02-16-2017, 01:34 AM   #492
cosbySweater
the car already has a 4l80e. the trans tunnel had to be moved in about 2 inches all the way around
Old 02-16-2017, 02:07 PM   #493
cosbySweater
trans is put of the car and the engine is stripped down and ready to be pulled. hopefully i can yank the drivetrain out of the van tonight and get it in by next weekend. that would be ideal
Old 02-17-2017, 12:00 AM   #494
122power
dude
122power's Avatar
do it this weekend!
122power is offline
Old 02-17-2017, 12:56 AM   #495
cosbySweater
i pulled the 6.0/4l80e out of the van. going to steam clean it tomorrow and do the cam and head gaskets. next weekend it will be running. with a 6.0
Old 02-17-2017, 02:41 AM   #496
cosbySweater
pulled the truck in at 12, took a 1.5 hour lunch break and had the sob out on the floor. no cutting the van up, everything taken off properly. here are the pics of the glorious 6.0 before removal.
finished up my gauge setup after work today. ran all new wiring and properly fused and relayed everything so all the gauges have the same amount of light. may put a inline resistor on the boost gauge. also i bought a new analog afr gauge just because i wanted it to look somewhat period correct. i can change the gauge to the same back lighting but i think the red will stay due to the simple fact that it is the most important. so for gauges i am using all vdo vison minus the afr gauge. soon i will mount a speedometer where the factory clock goes. it will be a small gps speedometer that will have a individual circuit. dont really need it but i would like to have it for data logging and tuning.
Old 02-20-2017, 02:08 AM   #497
SmokesLetsGo
Oh Hi, Mark!
SmokesLetsGo's Avatar
Man I'm excited to see this thing!
If trump has to destroy the country to get rid of the juggalos, so be it.
SmokesLetsGo is offline
Old 02-20-2017, 02:31 AM   #498
toms_elleck
Damn, that engine is buried in that van!!
Old 02-20-2017, 04:48 PM   #499
cosbySweater
Got the wheels and tires on the car,they are cragar 17x7s wrapped in continental extreme contacts 225/45/17
Here's pics of the 6.0 I like to call it swamp thing
I removed the rocker arms and push rods and steam cleaned the mess
I did valve springs and swapped in a ls6 cam, got the oil pan and everything on this morning and it's ready to go. I leak checked all the valves and they were sealing fine so I'm not gonna worry about removing the heads
Old 02-22-2017, 02:12 AM   #500
cosbySweater
Got the rear end centered in the car tonight, I had measured all the angles of the trans previously so I set the pinion angle. I'm waiting for some other parts to trickle in this week and I'm going to be throwing the 6.0 in this weekend, and probably install the trans next weekend. I got the fuel lines run on the car and permanently secured. I got the brake situation all figured out as well. I dont know if I posted this but I went with a set of rx7 calipers up front to get something a little better. I am running a single brake circuit to the rear of the car and I will try the stock proportioning valve on there just to see if I like it. But most likely I will be converting to a adjustable one
Closed Thread
