Closed Thread
Old 04-25-2017, 08:46 AM   #676
PeaceEngineered
Sarcastic Optimist
Originally Posted by sikbrik View Post
When I saw the comments about double shear on the lower, I initially agreed completely...But I'm no suspension guru. Then yesterday I saw that you can buy out of the box coilovers mounts which are designed just like this, from Sweet Mfg and others. Not making judgment either way because I don't know what's right but just saying this seems to be an "accepted" mounting method in motorsports.
It is more a design issue than a suspension issue. Sure it can be done as evidenced here and with other manufactures offering a similar design. However, it should be engineered for the dynamic loads that could be imposed. Race cars vs street cars, drag cars vs rally cars each would have its own limit. I don't think it will sheer off the bolt. My concern is that the connection would bend from the cantilever forces which is yield, and depending on the application yield is failure.
I am not an alarmist. The build is solid. I commented as the top bolt is in double sheer, and it would be "nice" to have the lower one as well. A 1/4" plate of A36 is pretty stout stuff, but it would be fairly easy to run some numbers on an axial load.
Rock on!
2006 V70R a turbo finally!
PeaceEngineered is offline
Old 04-25-2017, 08:57 AM   #677
sikbrik
Thanks, Peace! Makes sense. Trying to learn a bit from all​ of this and that's good info.
sikbrik is offline
Old 04-25-2017, 01:04 PM   #678
cosbySweater
cosbySweater's Avatar
We will see what happens with it. I am very transparent with my builds so if anything does happen I will let you guys know. But I doubt it will. Also
cosbySweater is offline
Old 04-25-2017, 01:57 PM   #679
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Shoot, I for sure would not worry about the bottom mount being double shear, We run our dirt modifieds just like this:
and if we can do this with those cars, I wouldn't worry too much about a street car.
Sorry about the random pics in your thread.
1980 242 Turbo
2004 V70R
Uncleknucklez is offline
Old 04-25-2017, 07:55 PM   #680
cosbySweater
No worries man! I'm loving the setup so far. The car feels very well balanced
Old 04-27-2017, 01:05 PM   #681
cosbySweater
Had a little mishap the other day with the car. My oil feed line wasn't properly secured and touched the exhaust manifold and melted. Luckily I caught it very quickly and it only pumped out a little oil. I repaired it and have done about 600 miles on the swap so far. Need to start tuning it but in reality that will probably have to happen after davis
Old 04-30-2017, 10:23 PM   #682
cosbySweater
The car made it to Davis like a champ!!!! It overheated once so bad it wouldn't crank which was awesome. One fuel injector oring started leaking. Other then that, may burnouts and joyrides in the car. Next up on the list is swapping widebands and tuning, and also a better rear gear. Also tires......
Old 04-30-2017, 10:44 PM   #683
Uncleknucklez
bruspeed
The car is really cool in person! I am impressed by the engine packaging and how everything fit so clean. Good work
Old 05-01-2017, 12:00 AM   #684
thebornotaku
( ͡° ͜ʖ ͡°)
thebornotaku's Avatar
This thing does bitchin' burnouts.
1986 Volvo 244DL M47 "Turd Ferguson"
2009 Volkswagen Rabbit 2.5 "Snowbunny"
thebornotaku is offline
Old 05-01-2017, 03:48 AM   #685
Quin
ಠ_ಠ
it's quick-ish.
Quin is offline
Old 05-01-2017, 12:08 PM   #686
cosbySweater
It's so nice Davis is over. You wouldn't believe how happy I was to drive my civic to work
Old 05-01-2017, 05:45 PM   #687
cosbySweater
https://m.youtube.com/watch?v=OoYvXYRvnLQ
Some pulls and burnouts with a car full of people. In mexico
Old 05-19-2017, 12:48 PM   #688
cosbySweater
So got about 1750 on the car so far. I've been running delo to clean it out because the heads were nasty. So I believe I cleaned most of it out because this happened.....
Also note to self, parts store will give you a Northstar oil filter if you say it's a Escalade. The inside is plastic
Old 05-22-2017, 05:39 PM   #689
cosbySweater
Took it to a car show on Saturday, it was all classic American stuff and a bunch of mustangs (no one got run over so that was good) the car got alot of attention. Also while I was pulling in the brake master cylinder decided it had enough and exploded it's fluid out between it and the booster. I waited for everyone to leave and drove the car home 30 miles with no brakes. That was exciting!!!
Old 05-22-2017, 05:41 PM   #690
Pro Sneaker Peddler
I look like a goddamn cartoon character in that picture
Harlard is offline
Old 05-22-2017, 05:50 PM   #691
Quin
ಠ_ಠ
get real. i dailied a mitsubishi with no brakes for like six months when i was a teenager. your ****'s weak.
Quin is offline
Old 05-22-2017, 06:21 PM   #692
cosbySweater
Lol did you have a stick shift or a parking brake?
Old 05-24-2017, 11:04 AM   #693
cosbySweater
So I decided to ditch the rx7 brakes, with the added weight they just are not good enough for my liking, I loved them on my old car but you can feel it needs more. More on that later tonight
Old 05-24-2017, 03:03 PM   #694
77volvo245
77volvo245's Avatar
What brakes are you going to use?
STSmachining
77volvo245 is offline
Old 05-24-2017, 03:12 PM   #695
cosbySweater
Ats up front, explorer rear
Old 05-24-2017, 11:01 PM   #696
Texas240
Prius Owner
Texas240's Avatar
may your brakes no squeal
93 245 LS Engine Swap Project
Texas240 is offline
Old 05-24-2017, 11:53 PM   #697
cosbySweater
Running stock pads and rotors. My friends at doesn't so I'm not to worried about it. We ended up building our own brackets that were thinner and used wilwood machine washers to center the caliper exactly. So far so good
Old 05-24-2017, 11:58 PM   #698
cosbySweater
Old 05-25-2017, 12:09 AM   #699
mopar318
mopar318's Avatar
Mine don't.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline
Old 05-25-2017, 12:37 PM   #700
SmokesLetsGo
poobie
SmokesLetsGo's Avatar
Man I love this ****ing car. <3 <3
If trump has to destroy the country to get rid of the juggalos, so be it.
SmokesLetsGo is offline
Closed Thread
