Closed Thread
Old 12-13-2014, 12:48 AM   #176
Pro Sneaker Peddler
Swedish/Japanese V8?
Harlard is offline
Old 12-13-2014, 12:53 AM   #177
cosbySweater
cosbySweater's Avatar
I4 I6 or v6 . Nothing bigger
cosbySweater is offline
Old 12-13-2014, 01:17 AM   #178
Pro Sneaker Peddler
J35 all the things!
Harlard is offline
Old 12-13-2014, 06:10 AM   #179
cosbySweater
Probably going to swap in a m10
Old 12-14-2014, 12:27 PM   #180
cosbySweater
Old 12-14-2014, 12:54 PM   #181
adomz
Volvo 486 owner :D
adomz's Avatar
Like this alot!!!
1991 244 GL, lh2.4 b230ft, 3" SS Exhaust, 7krpm Chips, 16t at 1.3bar , and some more
=->Adam's Joint Creations<-=
adomz is offline
Old 12-16-2014, 12:18 AM   #182
cosbySweater
Me and ben talked a while when he was here visiting and we talked about the stock strut tubes. I have always used them in my coil over setups i have built but man they are garbage! I have 2 sets of full length tubes here at the house and in one set the short billies drop right in and in the other they dont even begin to fit. Upon cutting you can actually feel where the tubes are bent.... that being said this car will get some kaplan coilovers sooner then later
Old 12-16-2014, 04:26 PM   #183
122power
dude
122power's Avatar
Doesnt he use the stock housings though?
122power is offline
Old 12-17-2014, 04:01 AM   #184
cosbySweater
No. Much better housings
Old 12-18-2014, 01:10 AM   #185
cosbySweater
So just about done with the coil overs and camber plates. All the "joints" up front have been converted to sphericals and i made some cheap camberplates for the top. The front end is going to have a very nice planted feel i believe im very excited to get this thing on the ground and see how everything works
Old 12-18-2014, 01:25 AM   #186
I have multiple offerings.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is offline
Old 12-20-2014, 10:58 PM   #187
cosbySweater
Sent off my b21f intake to josh at yoshifab for some modification. Coil overs are done, and the front suspension is ready to be put back on. The spherical front end stuff turned out really good. Ill have to post some pictures of everything on the car.
Old 12-21-2014, 12:35 PM   #188
Mylesofsmyles
I'd love to see that new suspension.
What's Josh doing to your B21F manifold?
Mylesofsmyles is offline
Old 12-21-2014, 12:35 PM   #189
Mylesofsmyles
Old 12-21-2014, 12:59 PM   #190
cosbySweater
Hes welding a big plenum on the intake. Im going to be running a k jet scp head with the injectors in the head. The spray from the injectors when mounted in the head pools right up on the back of the intake valves which is what you want. Im hoping these spherical ball joints i had made up work good but if not i will probably be going with some of bens roll center correctors and swapping back to stock tie rods and ball joints. The only actual bushings left in the car are the poly control arm bushings and poly trailing arm bushings. So nvh is probably going to be through the roof. I did swap in all late model sound deadning but that may not be enough
Old 12-23-2014, 03:39 AM   #191
cosbySweater
Going in the freezer!!!
Old 12-30-2014, 02:09 AM   #192
cosbySweater
Got some pics. With this first adventure into making strut plates i decided to stick with oem style and just center the spherical, next ones i will offset drill the hole. Sphericals and retainers were sourced from rousch yates, i had some 1/4 inch 6x6 steel plates cut. I cut them to the same size as oem and milled them so they are perfectly round, i drilled the center out for 36mm to be able to fit a 15/16 impact socket and the hole on the underside was recessed 1/8th of a inch in at 46mm to provide a machine fit for the retainers and then tig welded. 1/4 inch plates are pretty overkill but i think its going to work out nicely.
Old 12-31-2014, 10:01 PM   #193
Hemily
So a european v8?
how about an American V8 used by Europeans? :P
these things used to be really popular for swaps into random cars.
http://en.wikipedia.org/wiki/Rover_V8_engine
Hemily is offline
Old 12-31-2014, 10:03 PM   #194
Duder
His Dudeness, El Duderino
Duder's Avatar
Any reason you ditched the E21 sport steering wheel? We have one on my wife's 2002 and it's a great wheel.
Duder is offline
Old 12-31-2014, 10:22 PM   #195
BDKR
Section 9
BDKR's Avatar
Originally Posted by cosbySweater View Post
Oleg finally got his **** together and sent me his stage 5 pressure plate. And man, it's a nice piece. Also unfortunately ronals are not going on this car. So I got these instead for a screamin deal
Aren't those Starion / Conquest wheels?
For all you Dijkstra fanboys:
BDKR is offline
Old 12-31-2014, 10:25 PM   #196
cosbySweater
No to the rover motor, to much work. The e21 wheel is still going in the car. Im having the hub fabricated for it currently and this wheel was dirt cheap, i just wanted to have something in the car and had no steering wheels laying around. And yes they are starion conquest wheels. Axles hubs and rotos have been redrilled
Old 12-31-2014, 10:34 PM   #197
BDKR
Section 9
BDKR's Avatar
Rockin!
BDKR is offline
Old 12-31-2014, 10:36 PM   #198
Hemily
i was gonna ask about that, are the wheels 5x114,3?
Hemily is offline
Old 12-31-2014, 10:37 PM   #199
Duder
Duder's Avatar
Very cool. I've always loved the StarQuest wheels too. They look good on a blue 244; who knew? Probably due to the '80s styling.
Duder is offline
Old 01-01-2015, 04:40 PM   #200
cosbySweater
Yea i really like the way the look. They are pretty light as well.
Closed Thread
