#26 |
Owner of a Loyal Pit Bull
OK , tested "old" stat. It too is a 82C*(179.6 ) T stat. All I have for thermometer is my A/C /Refrigeration one. It reads from 0-220F* and also has C* markings.
I have no way of knowing if it's 100% accurate though. I heated stat to 180F*. It should be fully open by then if I am correct. But it did not open at 180F*. It only began to crack open at @ 185-188F*and was only very slightly open at that temp. It finally fully opened at 198-200F* and it took @ a minute at that temp to fully open So I presume this stat was faulty. Or do stats only slightly crack open @5-8F* AFTER the designated temp?
Seriously afflicted with CVOCD. Link to my build thread : http://forums.turbobricks.com/showthread.php?t=203083 Link To My Oil Temp Sender Drain Plug Thread: http://forums.turbobricks.com/showth...=smokeyfan1000 Link to my B&S Feedback http://forums.turbobricks.com/showth...=smokeyfan1000 |
#27 |
your test confirms a CRAP T-STAT...."rated opening temp" *SHOULD*
yield a smoth opening and all in by 5* F above rated temp..an 18* spread is too much...good eye!
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity. |
#28 | |
It seems to me that this explains the Inst Clstr gauge readings. But I will drive the car with new stat and keep a very close eye on both the IN. Clstr gauge reading cyl. head temp & the VDO 52mm gauge reading block temp |
#29 |
#30 | |
Guess I need to buy one finally.My findings with the old T stat has given me a new description for how it operates improperly. I call it a *LAZY T STAT*. It finally fully opens ,but not at temp it's supposed too |
#31 |
Also, I have a question TrickMick. When viewing the t stat as it would sit in the cyl head,What the hell does that little shaft with a ball like retainer on the bottom of it's end, and mashed flat on it's top side end do?
It does not seem to limit T stat valve opening distance, and seems to have no real purpose. is it a "pressure equalization/relief valve of sorts? To equalize cyl head & radiator coolant pressures when the engine is cut off and cooling down? Last edited by smokeyfan1000; 08-23-2012 at 10:45 PM.. |
#32 | |
coolant to bypass closed TStat and keep it from AIRLOCKING... |
#33 | |
I was researching t stat posts before making this thread. In another thread(which I cannot find now) one said it was to keep the T stat from failing in the closed position. Which is utter BS, as it cannot do that. |
#34 |
ONE DAY AFTER UPDATE:
So far new stat is doing well. No temp gauge craziness. And FCPG is letting me return the "old" stat for a refund. Seems I bought it in Sept of 2011, longer ago that I remembered it being, but still was just inside the 1 yr warranty. Thanks FCPG! |
#35 |
UPDATE
Was driving to store in Burl today. Ins. Cltr temp gauge rose to previous high reading, but then dropped right back down within one block. Unsure if this stat is beginning to do what last one did, or was just regulating engine temp, or if, in fact gauge is suspect. Wil continue to drive it, and inmeantime, I plan to go to Dealership & order a Vernet brand t stat to install and see if it does same. I figure this will prove/disprove if gauge is starting to fail I'm also wondering if viscous coupling fan is going out. Going to see if I can find how to "test" for bad visous coupling (clutch) in engine/radiator cooling fan Last edited by smokeyfan1000; 08-26-2012 at 06:39 PM.. |
#36 |
manofewords
Could be an air bubble in the system. Also, you did get the jiggle pin positioned at the top when you installed the thermostat, right?
-J
![]() ![]() 1984 245GL - silver; 1984.5 (more like 1985 now) 245Ti - blue - Both M46 cars. |
#37 |
Don't recall. Never had a problem with it before on other 240s & never positioned it in any specia location. Might try that though
#38 |
Hung Ro Froot
If you open it again, test both/ all the tstats you have in a pan at once.
"El Diablo casador de hombres" |
#39 | |
#40 |
I always had odd problems like this on my old 240 as well. I always assumed it was due to the cooling fan being unshrouded and the rad being partically blocked by the intercooler.
My Buyer/Seller Feedback Thread
#41 |
On my previous 760 I installed the t-stat upside down and got wierd readings - reinstalled with the hole at top and readings went back to normal. I associated with an air bubble in the system. Never sure though.
| Thread Tools | |
| Display Modes | |
