Old 09-19-2005, 11:28 AM   #1
the poi
Has been
the poi's Avatar
Default Chris Wiita's 1995 960R
1995 Volvo 960R
Last update: 12/30/2013
Project: 1995 960 Wagon
Goal: Legit daily driver
More specific goals: Good motor, good suspension, good brakes, good interior, kinda ridiculous bodywork (sorry!)
At the moment:
96 B6304, 2OS, tight squish, decked to 11.5 CR
Ported/polished head
3" exhaust post cat, 1 Dynomax Turbo muffler and 1 Ultraflo
AW30-40LE with locked out accumulators
Homemade Paddle Shifters w/ BASIC Stamp microcontroller
B&M cooled
Seam-welded engine bay
Koni adjustable front coilovers, 450lb Eibach barrel springs, Kaplhenke upper mounts
Fabricated 50mm drop spindles, increased steering ratio
ipd HD endlinks
QA1 rear coilovers with machined spacers to clear framerail, 450lb springs with helpers
BBS LMs: F- 255 AD08s on 19x8.5 R- 295 AD08s on 19x10
14"/355mm STS-V/CTS-V 4-piston brakes on all 4 corners
Wilwood proportioning valve for the rears
Battery in the boot
850R bumper, 740se side skirts, flared fenders
Side markers, clear corners
Valeo HID projectors, giant muffin cup bezels
LED lighting
Charcoal grey Ozite carpet, black unisuede door inserts
LED interior lighting
Autometer Cobalt oil pressure, Orange TPMS
Sparco R505 driver's seat, Momo GTR2 wheel with spacer
Schroth Rallye4 belt
Pioneer Pioneer FH-P8000BT head unit, HD radio tuner
Infinity Kappa 6.5" Components in rear doors and dash
Infinity Kappa 6.5" Two ways in rear doors
Elemental Designs Nine.4 amp
Why?
I posted this, like, 4 years ago. My first thread on this board I think: Heh, a V8! At this point, I had a 97 850glt. Over the next couple years, my brother flung that into a pole, I got an 87 760t, flung that into a tree, bought a 760t wagon, riced it the hell out, and then blew up the trans. So a bought a 95 960, cause hey, that makes sense right?
Motor:
The condensed version: I was driving the car around for awhile with the stock motor. I built the parts needed to turbocharge it. It blew the HG on the shakedown run because of a preexisting cracked cylinder liner. So I bought a T6 motor. I built that up, did some minor surgery on the car, and put the turbo parts on the T6 block, and put that in the car. All was right with the world. I never drove the car as much as it deserved though, because it was totally not steet-legal, and a cop could pretty easily ruin my day. I never knew the probability of this scenario, but it was enough that I just couldn't drive the car without worrying. So I bought a 1964 122S. The big turbo motor goes in the old timey car, unrestrained by smog laws, and the wagon gets something else. I'll be putting a E-Rod LS3 in it. Overdone, but it'll be neatly engineered and dependable/fast.
The long version:
This thing is fun, but its time is ending. Originally I did this because I would need to when I Megasquirted the car, but it's going away when the V8 and the T56 goes in. For the record: I made a really simple Basic STAMP-based controller to control the solenoids on the transmission, controlled by two paddles mounted to the steering column. The transmission has an external cooler, and the accumulators are shimmed out to make shifting as fast as possible. It looks pretty janky now, in hindsight.
References: paddle shifter main thread, also trans cooler, accumulator shimming
Oh dear! Jelly suspension!
Up front, 850 Koni's modified for coilovers from Coleman. 60mm drop spindles with faster steering ratio. Delrin and spherical bearings in the control arms. Kaplhenke upper strut mounts. Engine bay is seam welded. Upper engine mount does some strut bar duties. Had to make a swaybar endlink adapter up front so I could use a long endlink to connect to the 850 struts. Rear has some QA1 coilovers, combined with the "Nivomat" rear transverse spring. 450lb springs all around (wheel rate: front 450, rear 400).
Brakes are off a STS-V. Brembo 4 pots, 14" rotors. Wilwood prop valve for the rears.
I'm trying to keep it look relatively sedate. It is a Volvo station wagon and all. 850R front bumper, 740SE side skirts, clear corners, and 35% tint all around. Also I have one of those sweet rear wiper covers. This all went out the window when I decided I need to out giant 19" BBS LMs on the car. I made some flared fenders. It looks pretty ridiculous now, mostly because the front tires need a lot of space to function properly because McPherson struts are really stupid. I'll probably put wider wheels on the front at some point because stance.
HID headlights. They're Audi S4 assemblies. I mounted them all nice and tidy and painstakingly polished the flutes out of my headlight lenses. They're awesome.
On the inside: charcoal Ozite carpet, black Unisuede door inserts, Sparco R505 driver seat, Momo GTR2 wheel, Schroth Rallye4 belts. All the cabin lighting is now ultra bright white LEDs, and gauges and the like are blue LEDs. I did these a long time ago, before SMD LEDs became commonplace. I'll be replacing everything again in the future. Also on the list, but near the bottom--another R505 and matching material to recover all the seats.
Old stereo stuff. Speakers in the doors are fine, but need some digital amps and a subwoofer.
References: HIDeez, unisuede door inserts , widebody
There's like 8 years of pictures here if you're interested!
UPDATE: 12/30/2013
Got the thing buttoned up, back on the road, in 2013 (barely!). Gotta tie up a few loose ends, and I'll start driving it again, until I get around to the V8...
Old 09-19-2005, 11:36 AM   #2
DoubleV
DoubleV's Avatar
Sweet Chris! The ammount of quality work you have gotten done on that car in this short ammount of time is really amazing. It definitly looks great, and it's perfcet having this thread to easily follow your progress.
DoubleV is offline   Reply With Quote
Old 09-20-2005, 04:10 PM   #3
SwedishFish
SwedishFish's Avatar
That's only 6 months of work. Tell us when you are done how much this was worth the effort. Because I'm pretty sure it will be. And the moderators should buy my turbobrick plate for your car. It was only $27!
Originally Posted by the poi View Post
my brother was an accident
No Volvo @ the moment just 2 v-twin bikes and boosted vtec yo
Dad has a 91 740 Turbo wagon now! 501 red
SwedishFish is offline   Reply With Quote
Old 09-21-2005, 11:50 PM   #4
shaved240
shaved240's Avatar
They make 960R's now
Old 09-22-2005, 12:04 AM   #5
the poi
Has been
the poi's Avatar
no, I do
Old 09-22-2005, 12:35 AM   #6
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
so, when we gonna see 12's
Megasquirt Tuning!
Old 09-22-2005, 12:37 AM   #7
the poi
Has been
the poi's Avatar
2-3 years from now i may be able to make the power, but the rear end and the general fat-assness of the 960 may result in a metallic mess on the track. but then... maybe not...
Old 09-22-2005, 12:48 AM   #8
linuxman51
linuxman51's Avatar
never know til ya try ;)
Old 12-26-2006, 03:47 AM   #9
TurboBrickMan
TurboBrickMan's Avatar
hmm, do I see solidworks usage on the pbase page?
Just got to "pipeface.jpg". The "Extrude 1" give it away. SW is sweet.
TurboBrickMan is offline   Reply With Quote
Old 12-30-2006, 01:06 AM   #10
Boosted2003
Boosted2003's Avatar
If you are going to a manual tranny. Start sourcing a e36 m3 gear box (5speed is about 500-750 bucks) (6speed is 2000-2500), m3 rear diff (custom mounting) and custom rear axles. This is if you want over 400whp I found out through research. This not because the rear diff housing is weak but getting good Locker/LSD is impossible.
2006 VW Passat 2.0t 6 Speed - Current
2005 Dodge Magnum R/T - Sold
2005 Dodge Ram 2500 - Sold
1998 Dodge Ram 1500 - Sold
1990 Volvo 760 Turbo - Sold
Boosted2003 is offline   Reply With Quote
Old 12-30-2006, 01:26 AM   #11
impulse922
or you mean because thats what s90R did for a rear end solution? mk2 irs might be up to it
-Matt
'03 s60 T5M
impulse922 is offline   Reply With Quote
Old 02-27-2007, 12:34 PM   #12
mavawreck
The son of Chico Dusty
mavawreck's Avatar
have you wired in a aftermarket head unit by chance? I was lookin for a schematic break down, aka i want to wire out the preamp without having to figure it out myself...
Blue collars don't pop, they're too soaked with sweat.
- The Saturday Knights.
mavawreck is offline   Reply With Quote
Old 02-27-2007, 02:09 PM   #13
socalsean
back in the game
socalsean's Avatar
Those trannys do not have a removable bell housing...at least the one I dropped into my room mates e30 didn't.
Free Image Hosting at www.ImageShack.us
socalsean is offline   Reply With Quote
Old 02-27-2007, 02:15 PM   #14
acbarnett
SAAB defector
acbarnett's Avatar
just get a whiteblock-M50 adapter plate made, you'll want to use the BMW diff with the BMW tranny but as an added bonus you get reduced NVH because the BMW (and most mercedes as well) setups have the driveshaft spinning at about half the speed that it does in a volvo with a 3.9 or a 4.10 rear end.
acbarnett is offline   Reply With Quote
Old 02-27-2007, 07:10 PM   #15
Big Lan@work
Guest
So just how the hell does this work? At a given ground speed with the same gear ratio and tire size, the driveshaft will spin at the same speed regardless of whether or not the krauts made the car.
Old 02-27-2007, 07:12 PM   #16
thelostartof
unbalanced chemical
thelostartof's Avatar
can you please try NOT to thread jack a good thread otherwise
Old 02-27-2007, 11:12 PM   #17
fengler
fengler's Avatar
mechatronics ftw
Current-2006 Toyota Highlander Hybrid (190k)
Current-1967 Volvo P1800
Fengler would totally smash.
Originally Posted by regina745ti View Post
lext nevel hengler maneuver
Originally Posted by resa850
Nick: I love you.
Originally Posted by CaptainLeah View Post
I saw fengler was the OP and I knew it was going to be gold.
"Without music, life would be a mistake." - Nietzsche
fengler is offline   Reply With Quote
Old 02-28-2007, 02:44 AM   #18
volvorod85
volvorod85's Avatar
12's? shoot im waitin to see it roll outa the garage without the guy pushin it from the rear....
Mark
Hey chris, buy mine!!
1995 E320 wagon AMG 3.6 swap <-- Daily driver
2009 Honda Fit <-- Wifeys ride
1959 Austin Healey Sprite <--something completely different (my project)
1974 Fiat X1/9 <--Mom's little toy (next project)
1982 Olds Custom Cruiser LQ4 <--Dad's beast (current project)
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
volvorod85 is offline   Reply With Quote
Old 09-06-2007, 02:16 AM   #19
the poi
Has been
the poi's Avatar
oky, updated first post so it no longer sucks. and used other people's photos for the most part because I suck at cameras
Old 09-06-2007, 02:40 AM   #20
ThePOWERtoRULE
SoCal Apologist
ThePOWERtoRULE's Avatar
I'm happy to see a couple of pics I took are being put to good use. You had the TB posse there, so you can suck at cameras and get away with it.
-Jason
No Volvos left...
ThePOWERtoRULE is offline   Reply With Quote
Old 09-06-2007, 02:49 AM   #21
the poi
Has been
the poi's Avatar
I dropped a bunch in a folder, so I've forgotten who took what.. lemme know so i can "credit" them right
Old 09-06-2007, 01:56 PM   #22
homer1300
homer1300's Avatar
Have you dyno'd it yet?
1983 244 Turbo
1995 944 Turbo
homer1300 is offline   Reply With Quote
Old 09-06-2007, 02:01 PM   #23
the poi
Has been
the poi's Avatar
Gotta get my fuel lines done first, crank the boost up, drive the piss out of it a bit. If everythings holding together, I head to the dyno for some real tuning.
Old 09-09-2007, 08:09 PM   #24
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Finally.
Old 09-13-2007, 12:51 AM   #25
Volvoteen
Volvoteen's Avatar
The car is gorgeous and im really glad you decided to compile everything in this thread...makes it A LOT easier...although...still not easy ...cant wait till its all tied up!
2005 Volvo XC90(stock)
2006 Pontiac GTO(CAI, exhaust)
1996 850R(SOLD)
Originally Posted by miguels244 View Post
Belief in God(s) does not infer conservatism...
hell it doesn't even infer religiousness.
Religion is a political, dogmatic, economic construct
designed to control a populace.
Faith is another thing entirely
You should read this thread!
Volvoteen is offline   Reply With Quote
