Old 01-12-2019, 07:10 PM   #751
cosbySweater
cosbySweater's Avatar
Gap it down to .020 with a 6al and let her eat
1995 Porsche 993
2013 VW Passat TDI
Old 01-13-2019, 03:35 PM   #752
HUB
Needs more cowbell
HUB's Avatar
Amazing as always!!
HUB is offline   Reply With Quote
Old 01-13-2019, 03:56 PM   #753
vintagewrench
vintagewrench's Avatar
Originally Posted by Tfrasca View Post
This damper cut down on the classic T5 decel chatter substantially. My car has always been really bad, and now I'd say it's downright acceptable.
Interesting to find out what helped the "T5 decel chatter." Some 140 series cars I've worked on in the past were fitted with one of these band aid shaft flywheels to quite them done and keep them from eating u-joints.
Old 01-13-2019, 10:55 PM   #754
Tfrasca
Tfrasca's Avatar
Wow, I’ve never seen that. Basically the same thing I got from ford.
Old 01-13-2019, 10:55 PM   #755
Tfrasca
Tfrasca's Avatar
Originally Posted by HUB View Post
Amazing as always!!
Thanks!
Old 04-11-2019, 07:27 PM   #756
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
bump
Old 04-12-2019, 11:02 AM   #757
Tfrasca
Tfrasca's Avatar
Originally Posted by vwbusman66 View Post
bump
That's funny, I was just looking at your thread. Nice car.
I have no real updates. I took the car on another organized drive, and hammered on it for 1200 miles. My wastegate setup isn't ideal, and it'll creep to 25 psi around 5k rpm. I suspect the dump into the downpipe is a restriction. I also need a better cooling fan and either a bigger overflow tank or a proper expansion chamber, as it'll run hot on sustained hill climbs.
Other than that, nothing is happening. House projects and preparing for a baby in August have fully eclipsed car stuff for the time being.
Old 04-12-2019, 11:48 AM   #758
vwbusman66
vwbusman66's Avatar
Thanks man. Hopefully it winds up being about 1/2 as good as yours.
Old 04-12-2019, 12:22 PM   #759
Tfrasca
Tfrasca's Avatar
Aim higher. You already have at least three times the paint on it.
Old 04-12-2019, 02:44 PM   #760
gsellstr
gsellstr's Avatar
We can talk radiator stuff at Davis Tyler. This setup I am doing is looking straight up legit and should have the capacity to cool even with boost. Should have it on the road this weekend.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 04-12-2019, 04:50 PM   #761
vwbusman66
vwbusman66's Avatar
Can you share with the class once you're content with the results? Definetly would like to improve cooling down the road if I go OHC.
Old 04-13-2019, 02:02 PM   #762
gsellstr
gsellstr's Avatar
Definitely.
As it is, recored stock radiator with a 3-row brass core and a DeRale efan/shroud setup, spec'd at 2100cfm on high. Had a fitting added above the lower hose so I can run a switch in the radiator as well, plan to run the BMW 2-stage switch that runs 195/180 and 210/195.
Old 06-18-2019, 07:58 PM   #763
jmc0369
jmc0369's Avatar
Great build. I love the subdued engine bay. And I'm excited to see/hear how the BW works out. I always like hearing what Duder has to say and take seriously his prescription for the 3067 for our cars, but I do like the S series BW's.
Member: TBCCS
"Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who!
"It is no measure of health to be well adjusted to a profoundly sick society" - Jidu Krishnamurti
jmc0369 is offline   Reply With Quote
Old 07-24-2019, 10:36 AM   #764
Tfrasca
Tfrasca's Avatar
Not too much has been happening with this car. Almost all my project energy has been going into the house we bought. It's been 7 months of heavy renovation, with seemingly no end in sight. AND, our baby is coming in 2.5 weeks!
Anyway, I have been driving the car a good amount. I can't get LH not to dump too much fuel in under load, which is frustrating. It had what seemed like weak spark, and would always cut out at higher boost. So, I had Duder solder a wasted spark board into my EZK for me, and got that installed a couple weeks ago, along with one step colder plugs (NGK 8s). That fully cured the spark blowout, but the over rich condition persists. Gary and Ryan have been making progress with LH tuning, and I'm going to try their latest tune before I ditch LH for good.
I bought that big wooden Nardi way before my car had a turbo, or any power whatsoever. It was great for a slow cruiser, not so great for a much faster street car. I finally pulled the trigger on a smaller leather version of the same wheel. This is one of the best things I've done for the driving experience.
And that's pretty much it. I plan on making some slight cosmetic changes soon, just to change it up and keep me interested. But really, I foresee a Microsquirt (or similar) conversion in my future. There are so many things this car needs, but the powertrain should be pretty damn solid now, and these LH drivability issues are a real buzz kill.
Old 07-24-2019, 10:53 AM   #765
Stiggy Pop
Stiggy Pop's Avatar
you take good photos
'79 242
943 pickup
Old 07-24-2019, 10:56 AM   #766
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
QFT
The switch to MS is the best thing I have done to my car, lots of hyperbole about the "fixes" to our cars (T5 noises, pinion angle settings, LH issues, on and on) but really MS is the one "fix" that actually works. I won't put LH back in the car, it starts and runs better than ever, with closed loop it even acts like a normal car.
1980 242 Turbo
2004 V70R
Old 07-24-2019, 12:12 PM   #767
Are you going to be around for Car Week? MY wife and I will be in Moss Landing between 8/16-8/18.
Good going on house and babby. Those are the ones that take the real dedication
Old 07-24-2019, 12:13 PM   #768
Verily. It works out being cheaper in the long run too, go figure.
Old 07-24-2019, 12:30 PM   #769
Tfrasca
Tfrasca's Avatar
QFT
Thanks, guys. Figured with the baby coming, I should probably dust of the ol' DSLR.
Chris, I'm pretty set on going to some kind of programmable ECU, just not sure which one yet. I'm hoping LH can just get me by for a while (Gary's tune has been working really well for him), just because of everything else I have going on. I'd hate to rip all the LH stuff out of my car and then have it sit for 6 months while I adjust to having a baby.
Old 07-24-2019, 12:34 PM   #770
Tfrasca
Tfrasca's Avatar
I am not planning on going down for Car Week. If baby is on time, we will have not slept for about 2 weeks, and even a day trip to Monterey seems unlikely. We'll see.
Thanks re: house + baby. Two things I kind of never thought would happen, but am extremely excited about.
Old 07-24-2019, 12:36 PM   #771
Duder
Comes with a free Frogurt
Duder's Avatar
For standalone, check out Link if you haven't already. They are high quality, high featured, and reasonably priced for what you get. No affiliation just sharing observations.
Glad to hear the wasted spark installation helped with blow-out!
Old 07-24-2019, 01:28 PM   #772
Vol242vo
Keep it clean...
Vol242vo's Avatar
Always loved this 142. Are your exhaust studs stainless?
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 07-24-2019, 01:32 PM   #773
Tfrasca
Tfrasca's Avatar
Thanks. Yeah, they're some stainless studs for a Porsche of some sort. I just got them from Amazon.
Old 07-24-2019, 01:32 PM   #774
Tfrasca
Tfrasca's Avatar
Have you used a Link? How's the software?
Old 07-24-2019, 01:58 PM   #775
Duder
Duder's Avatar
I've played around with one for a while helping Alex Buchka tuning his car on the street early on after his whiteblock swap. Talk to him for a detailed review, but to me the software seemed fairly intuitive. I've seriously considered buying one for my 245 project but stumbled across a Bosch Motorsport ECU so I'm going to try that out first.
