Old 12-05-2018, 09:39 AM   #51
mikep
The MP
mikep's Avatar
That's a rare one. Every Granada that came through the dealers I worked for had an 8". I only heard rumors of a Granada 9".
Originally Posted by DaBossk View Post
dornald blormpf bad because he has spine xd
I think that's a bit of a stretch to put him in the phylum chordata.
Old 12-06-2018, 08:37 AM   #52
2turbotoys
Salaminizer
2turbotoys's Avatar
I think the rear was originally in a 77 Bronco, and someone put Grenada calipers on it if we deciphered the tag correctly. The story I got was that it came out of a 240 built by a company who did 5.0 conversions. It sat in the sellers parts yard for years and no one there really knew anything else about it. The p/n on the caliper lead back to a Grenada, but they could possibly fit something else as well, it was just a quick search out of mild curiosity since they were getting scrapped anyway.
2006 V50 T5 AWD 16 PSI +
Old 12-06-2018, 09:29 AM   #53
A tough rowing ho
I doubled my investment yesterday with an order to Jegs for the Ford racing carbon fiber clutch disk kit and a new driveshaft u-joint yoke that I didn't feel like going back to the j/y for. I'm gonna start cutting off Ford brackets maybe this evening or tomorrow after work, will drag the 1030 out this weekend to start bracket swap over.
Old 12-08-2018, 09:53 AM   #54
freevolvos
freevolvos's Avatar
Carbon fiber disc...please post pics
Old 12-08-2018, 11:17 PM   #55
A tough rowing ho
2018-12-08_10-15-06 by John Skiba, on Flickr
Old 12-09-2018, 01:51 AM   #56
Vincent Gagnon
Vincent Gagnon's Avatar
What kind of limited slip do you find in 8.8?
Old 12-09-2018, 02:39 AM   #57
A tough rowing ho
Ford Trac-lock used in mustangs, explorers, Etc, the above discs are used in 03-04 Cobra.
Old 12-09-2018, 03:31 AM   #58
Vincent Gagnon
Thanks.
Old 01-05-2019, 10:36 AM   #59
ht834
ht834's Avatar
Originally Posted by 240wagonguy View Post
Friend of mine makes the brackets for an 8.8 swap in both 240 and 740/940 chassis. Easier than scabbing them off the old axle.
Hey I sent you a PM about those brackets.
ht834 is offline   Reply With Quote
Old 01-05-2019, 12:53 PM   #60
A tough rowing ho
I talked to the guy on Facebook, his TAB mounts come with poly bushings pre-installed. He said most of the people who buy his stuff are north of 600hp. I have the Ben's spherical bearings so I didn't go that route. I do have the benefit of a plasma cutter to use at work that I scabbed the Volvo mounts off with. I just finished everything last night when I welded on a couple little tabs for the Ford brake hoses. Some Bricker posted a YouTube that I used for a guide. He cut off the anti rotational nub that keeps the brake hose from unscrewing off the Ford calipers, I didn't think this was a good idea so I left them and looped the hoses around. It doesn't look super but I think it's more secure. The LSD is great, it was raining yesterday and I changed lanes in 2nd and just sort of slipped the whole car sideways when both tires broke loose like it had rear wheel steering. Feels similar to a weldy when when both tires light up. It also drives out of corners hard, much less drama than the G80.
Old 01-07-2019, 12:52 PM   #61
rallydallas
Ah yes I forgot.
https://www.facebook.com/Giffins-Per...4053585318393/
Pinned post at top.
I'll have to mention to him again about posting a for sale thread here. I think fb is just easier tho.
Oh man that is totally awesome, thanks for the linky
Originally Posted by cosbySweater View Post
If anyone of you want a 8.8 in your volvo. Let me know I have a jig for welding the mounts. I can source axles no problem. It isn't going to be dirt cheap. But I have the tooling and time for the next month to do it. Pm for deets
Good info noted.
