Old 12-11-2018, 09:35 PM   #1
LeedomtoFreedom
LeedomtoFreedom's Avatar
Default b230ft + 16v rebuild thread.
Alright so I picked up another long block for some parts, currently have 3 redblocks in the garage now.
Need some advice for a rebuild. Trying to make a little power on this build (300ish) so was planning on staying stock rods and pistons. If my old 94 short block is okay, I'll use that with the squirters or have to drill into the new block.
Any things that I should be aware of or address while I'm doing this? Haven't done an engine rebuild for real yet (except when I was in highschool autos class) and 2 stroke engines. Going to replace bearings, seals, probably get some better quality rings blah blah.
Also scrounging the forum for build threads to get ideas but I was just curious if anyone had anything to say.
81 264 - Driveway ornament
90 245 - becoming 16v
Old 12-11-2018, 09:37 PM   #2
sbabbs
sbabbs's Avatar
We'll what about cutting valve reliefs into the pistons for the 16v head? Are you gonna do that?
Simon
Old 12-11-2018, 09:43 PM   #3
LeedomtoFreedom
Simon
yep definitely going to do that. Got a set of used pistons for that so I don't have to use the ones that look like swiss cheese.
Old 12-14-2018, 09:30 PM   #4
thelostartof
unbalanced chemical
thelostartof's Avatar
For what it's worth it is not needed to cut the reliefs. We have put 16v heads on a few engines without them and some 10+years later both engines run fine.
thelostartof is offline   Reply With Quote
Old 12-15-2018, 04:06 PM   #5
EivlEvo
Wait... this is news to me. How is there no need to cut reliefs into the pistons for the valves? I thought it would interfere otherwise? Even with correct timing.
Old 12-15-2018, 05:01 PM   #6
sbabbs
sbabbs's Avatar
Weird, I wonder whey volvo does then? Maybe it depends on what cams your running? Nah...
Old 12-15-2018, 05:17 PM   #7
John V, outside agitator
Banned
Which engines? which cams? What revs? What springs?
Old 12-15-2018, 05:35 PM   #8
thelostartof
unbalanced chemical
b230f, stock 16v cams, 7000rpm rev limiter, stock springs.
The car is a 244 w/ Getrag is a b230f with a J pipe manifold and hy35cw that ran on LH 2.4 for years before going to Civinco and then MS. This car ran pump gas and then e85. Boost wise it was around 18-20psi on this setup. Car is a hoot.
I am sure Volvo did it to be safe so if you timed it wrong it didn't destroy the pistons when testing.
And uh other people also know this also, if you look back there are others than mention this also that it just works, no need for cuts in the pistons. If you look around at old posts there is mention of people doing a 16v swap and not doing anything to the bottom end as far back as at least 2010.
Old 12-15-2018, 08:50 PM   #9
LeedomtoFreedom
What pistons have they used with this? Stock N/A pistons? Is there a height difference between the n/a and turbo pistons?
Have you done that putty trick to see how much room is left between the valves ? Is that a real thing even ?
Old 12-16-2018, 12:46 PM   #10
thelostartof
unbalanced chemical
Stock pistons. That's it, more than a few have taken a 16v head and bolted it to a b230 without any work. Yes we have done the putty trick.
Old 12-16-2018, 06:37 PM   #11
LeedomtoFreedom
I'm going to check it when I have my short block out of the car
Old 01-10-2019, 12:11 AM   #12
Sven's245
what's the reason for cutting reliefs in pistons then? just to be safe?
Sven's245 is offline   Reply With Quote
