Old 02-02-2017, 09:51 AM   #1
claymore
Default Charge cooling a T-5R
I've decided to switch to water/air cooling on mu 850, in the hope of being able to easier cool down the intake charge between quarter mile runs.
claymore is offline   Reply With Quote
Old 02-02-2017, 02:05 PM   #2
That copper tubing looks scary,
You might want to make sure that its supported or has some type of strain relief.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 02-02-2017, 02:33 PM   #3
claymore
Copper tube will be replaced shortly
Old 02-02-2017, 03:08 PM   #4
routing of the charge tubing looks alot nicer than the typical setup you see on p80s
Old 02-02-2017, 03:27 PM   #5
claymore
I haven't noticed any difference in throttle response with the reduction in pipe length.
Old 02-02-2017, 05:05 PM   #6
Yea, i wouldn't assume that you would.
Old 01-02-2019, 09:12 AM   #7
claymore
Two years of running, and the charge cooler has been faultless.
Old 01-03-2019, 02:17 PM   #8
ovlov760
ovlov760's Avatar
Did you make your own throttle spool cover?
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
Old 01-03-2019, 03:39 PM   #9
claymore
you mean my plastic carton sprayed in bedliner
Old 01-05-2019, 03:07 AM   #10
Sjeng
Sjeng's Avatar
So how fast is it?
Old 01-05-2019, 05:10 AM   #11
claymore
Originally Posted by Sjeng View Post
So how fast is it?
About the same as before, although due to the short pipe run, it does hold boost better.
Old 01-05-2019, 02:07 PM   #12
JohnLane
Which water pump did you choose for charge cooling?
Old 01-05-2019, 02:30 PM   #13
claymore
I can't remember the model, but a Bosch coolant pump off a BMW.
