Old 10-15-2018, 09:12 AM   #1
orrob
Default Wasted Spark for dumbies
Thinking about going ahead and adding a wasted spark board while my engine is torn apart on my '93 240. I have seen videos about how to install the wasted spark board. I saw that the bosch 2 x2 coil pack is recommended. I have a couple of questions though:
1. what jy might have a bosch 2 x2 coil pack (if its worth grabbing a jy version)?
2. What's the best way to plug the dizzy hole?
3. does it reuse the same crank sensor (aw70)?
4. Anything else I am missing that install videos don't show?
Thanks
orrob is offline   Reply With Quote
Old 10-15-2018, 09:20 AM   #2
JW240
All idiot, no savant
JW240's Avatar
1 where are you? Some Fiat, Alfa and Lancia cars use the Bosch 2x2 coil. Probably unobtanium at the junk yard in the staties, here rare but available. New is 40 euro so it's not something you can save a lot on. On my 240 the old junk yard coil gives a misfire after washing the engine bat, suspect a small crack in the resin of the coil. They do fail.
2. Volvo made a freeze plug for that. 940 used it, forgot the pn.
3. Yes.
4. Dunno which video's you watched.
Follow the instructions on here (a faq somewhere) and you should be fine.
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
Old 10-15-2018, 01:44 PM   #3
mck1117
1. 1999-2002 Range Rover and 1999-2004 Land Rover Discovery. They're a v8, so they have two of the Bosch coils. They do exist in junkyards, but they're ultra difficult to get out from between the intake manifold and firewall, but they do exist. Rockauto has the legit Bosch part for $45.
mck1117 is offline   Reply With Quote
Old 10-15-2018, 02:33 PM   #4
Can play the blues
I think you can check out the members site on here user name Duder. He sells the board and setup and should be able to direct you to a place to buy the coil pack.
Old 10-15-2018, 08:53 PM   #5
nitroboie
If you happen to come across the right year and model range rover that's already been torn down then grab the coil. It's wasn't worth the hassle for me to dig that deep to get it. I bought mine on amazon for about 40 dollars; same for the ignition amplifier.
Have a read at this thread:
http://turbobricks.com/forums/showth...wpost&t=246170
nitroboie is offline   Reply With Quote
Old 10-16-2018, 06:38 AM   #6
Mbeas96
Mbeas96's Avatar
It took me 10 mins tops for the two coils from a 99 discovery. Charged me 30 bucks for both of them. Ive used both and they both work, in going on 10k miles on one of them. Pulled my ignition module off a junked miata too
Its easy to rip things apart when you dont care about it
Old 10-16-2018, 06:48 AM   #7
J2_
J2_'s Avatar
The partnr for the dizzyhole (back of the head) is 1336763. Around $5/6 iirc.
J2_ is offline   Reply With Quote
Old 10-16-2018, 12:16 PM   #8
Duder
His Dudeness, El Duderino
Duder's Avatar
Thanks for the plug. I took over sales of the wasted spark board from Karl Buchka a few years ago since he wasn't able to continue selling them but there was still a demand.
I actually do sell the Bosch Motorsport 2x2 coil pack through my site as well. It's not some super rare or specialized part but it works really well with LH2.4 + WS and I figured people may appreciate being able to buy the major components in one place. I also sell a clone of the power stage / ignition module from the 960, which has 3 spark outputs, of which 2 can be used for wasted spark on the redblock.
There was some interest in a complete kit including finished wiring with connectors, a coil bracket, and so on. The sticking point is modification of the EZK, which I'm not set up to handle now. So the end customer would still need to crack open their EZK, solder the board in place, and then install everything.
Old 01-07-2019, 02:24 PM   #9
bumblebeeman
I have been wanting to do a wasted spark conversion. However I'm not running 2.4. Will this work on 2.2? or does it need a CPS?? have been searching the forums but I haven't seen this question covered.
Thanks.
bumblebeeman is offline   Reply With Quote
Old 01-07-2019, 03:55 PM   #10
Dirty Rick
Dirty Rick's Avatar
What about the Bosch 0986221048 Ignition Coil ?
Built in igniter and works with volvo wires.
Not sure about the cheapo ones, I got a Delphi equivalent, working great w/MegaSquirt on 20# of boost.
Old Yesterday, 02:25 PM   #11
Matthama
Matthama's Avatar
I got a hold of a 4 prong coil with build in igniter as well. Not the same part number but was wondering if it would work. Is the signal the same going to those style coils as it would be going to the igniter separately then to the coil?
'90 740 Turbo M46 Wagon,Buchka Spark Waste Mod, TLAO Chips, Persicion 57mm Turbo 48a.r turbine, Full 3", iPd springs, Bilstien HDs, iPd sways
'91 740 Turbo M46 Wagon iPd sways SOLD
'88 Samurai
Matthama is offline   Reply With Quote
Old Yesterday, 04:06 PM   #12
240wagonguy
someone also said this works with LS coils? Those are easy to find and have built in ignitors.
