Old 10-16-2018, 10:48 AM   #1
deadken
Default What Dodge is the 4Bar FPR from?
Hey guys, I'm looking to pick up a 4bar fuel pressure regulator for my 92' 940T. From what I remember, there is a 4bar that came from a Dodge turbo car that fit without any / minimal modification. I thought that I had saved that information but, of course, when I need it I can't find it.
Can someone please give me the year, make, and model if they have the information?
FWIW: I have search the 'how to +T your car' sticky for at least 3 pages and can't find it there or with other forum searches.
Thanks!
BTW: My FPR was leaking, so I swapped it over with a spare I had lying around. I figure that there is no sense in buying a stock 3bar, when I can get a 4bar for probably the same price and have one less thing I need to get for when I am ready to add a manual boost controller.
deadken is offline   Reply With Quote
Old 10-16-2018, 11:39 AM   #2
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
is there some reason you want to put an increased strain on your probably 26 year old fuel system to possibly get a minimal amount of additional fuel?
Megasquirt Tuning!
Old 10-16-2018, 11:40 AM   #3
oldschoolvolvo
oldschoolvolvo's Avatar
Bosch: 0 280 160 260
Mopar: 4306015 437
Ref:
http://forums.turbobricks.com/showthread.php?t=5385
https://forums.tbforums.com/showthread.php?t=149418
Might investigate getting bigger injectors vs. the uprated FPR....YMMV
-Mike
1998 V70 T5
|Feedback|
oldschoolvolvo is online now   Reply With Quote
Old 10-16-2018, 11:40 AM   #4
BR1CKHOUS3
I like the tuna here
BR1CKHOUS3's Avatar
"4 bar FPR found on older turbo I turbo dodges w/ the newer style intake manifold (that draw throw but blow through like ours). bosch part # 280 160 260. mopar # 4306015 437. these bolt right into the volvo rail and will need a 1/4 fuel line to go from the return line on the FPR to the tank. this is a little smaller than the stock return line. this is a 4 bar FPR ... takes fuel pressure up to 55psi."
We don't do it for the glory.
Only two ways to find out...18 bolts or 18psi
BR1CKHOUS3 is offline   Reply With Quote
Old 10-16-2018, 06:21 PM   #5
eli323232
eli323232's Avatar
https://www.ebay.com/itm/New-Herko-F...!US!-1&vxp=mtr
Might be worth a shot, the price is right.
eli323232 is offline   Reply With Quote
Old 10-16-2018, 06:28 PM   #6
eli323232
eli323232's Avatar
Actually, that doesn’t look like it would bolt up right.
Old 10-16-2018, 06:52 PM   #7
cosbySweater
cosbySweater's Avatar
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
Old 10-16-2018, 08:07 PM   #8
tryingbe
Boosting along.
tryingbe's Avatar
You fail at eBay.
This is the one.
https://www.ebay.com/itm/New-Fuel-Pr...S!-1:rk:5:pf:0
FYI,
I put on a Volvo 3 bar regulator in my Turbo Dodge to lower my fuel pressure so I can have more fuel volume.
85 GLH 367whp
00 Insight mpg > yours.
Old 10-17-2018, 01:23 AM   #9
JerryJS8
der Junge
JerryJS8's Avatar
Originally Posted by tryingbe View Post
Added to my wish list!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 10-17-2018, 06:52 AM   #10
doucheNozzle
doucheNozzle's Avatar
Beat me to it.
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 10-17-2018, 10:35 AM   #11
tryingbe
Boosting along.
tryingbe's Avatar
Why?
Add wideband to your list would be more beneficial.
Old 10-17-2018, 11:19 AM   #12
doucheNozzle
Why?
Mod list bro.
Old 10-17-2018, 12:48 PM   #13
eli323232
eli323232's Avatar
You fail at eBay.
This is the one.
FYI,
That's the one, good job by you.
Old 10-17-2018, 01:44 PM   #14
doucheNozzle
So ignored everything everyone else said?
Old 10-17-2018, 02:16 PM   #15
eli323232
eli323232's Avatar
What?
Old 10-17-2018, 02:39 PM   #16
doucheNozzle
What?
Everyone who knows what they’re doing said don’t do it.
Old 10-17-2018, 02:55 PM   #17
eli323232
eli323232's Avatar
I never advised anyone to do it.
Old 10-17-2018, 02:58 PM   #18
doucheNozzle
“Might be worth a shot”
Old 10-17-2018, 03:13 PM   #19
tryingbe
Boosting along.
tryingbe's Avatar
Mod list bro.
An engine needs the correct amount of fuel. Not more, definitely not less.
A wideband will help monitor air fuel ratio while a higher fuel pressure regulator will just allow more fuel flow thru the injectors making the engine run rich, especially at WOT (open loop). Un-burn fuel will get into the oil and eventually wipe out the engine bearings.
Running more fuel than needed = BAD.
Old 10-17-2018, 03:37 PM   #20
eli323232
eli323232's Avatar
Yeah the cheap eBay alternative to the part that the OP stated he wanted "might be worth a shot". i never told the guy he should do anything.
Old 10-17-2018, 04:32 PM   #21
doucheNozzle
K.
Old 10-17-2018, 04:58 PM   #22
JerryJS8
der Junge
JerryJS8's Avatar
Why?
Have a wideband already, see 16v turbo project details in my sig.
Future mods must support more for more! 42lb delphis with a 4bar regulator should comfortably get me enough fuel for 300+ hp.
Old 10-17-2018, 05:46 PM   #23
cosbySweater
A 3 bar will as well with a proper fuel pump.
Old 10-17-2018, 05:55 PM   #24
doucheNozzle
Why not just get the correct injectors?
Old 10-17-2018, 06:06 PM   #25
tryingbe
Boosting along.
tryingbe's Avatar
42lbs injectors are tiny and wouldn't give you any head room.
I thought I had enough fuel with 75lbs injectors, only to find out I was running out of duty cycle using E54 and 25psi, then I had to buy bigger 96lbs injectors. Well, guess what, my 96lbs injectors will be at their limits using E82 and 29psi.
Sell those 42 lbs and get some big injectors instead of spending money on a fuel regulator.
