Old 12-26-2018, 03:05 PM   #1
105Charlie
Default B200FT turbo swap now cuts out after throttle?
Hi
I've just swapped from the 13g to a 15g on my b200ft (in a 343). Running LH2.4, standard chips and injectors but a 012MAF and 2.5in DP/1BAR actuator. Idles and revs perfect throughout the rev range but dies after any sort of boost or hard throttle usage under load. Seems to bog quite a bit and obviously can only be driven gently at the moment.
Are there any obvious reasons for this before I start checking the loom for damage? I have the original MAF but it won't fit easily with the new pipe setup (a lot less space in a 343). I also have a set of 470cc injectors that I could try if it could be fuel starvation?
Was running perfectly fine running 14psi before I did the swap and tidied up the loom. Any obvious ideas?
Cheers
105Charlie is offline   Reply With Quote
Old 12-26-2018, 03:56 PM   #2
Dirty Rick
Dirty Rick's Avatar
Fuel pressure?
Old 12-26-2018, 04:10 PM   #3
105Charlie
Fuel pressure?
Running an aftermarket 044 style pump, regulator is good. It is fine if I roll into the throttle and stay at half throttle, dies when I come off the throttle - seems it can supply enough if needed?
Old 12-26-2018, 04:45 PM   #4
Martin L.
Kombinationskraftwagen
Martin L.'s Avatar
Vacuum leak would be the first thing that comes to mind.
IDKFA
Overnight parts from Sweden.
Martin L. is offline   Reply With Quote
Old 12-26-2018, 05:27 PM   #5
105Charlie
That's what I suspected but can't see anything visible, will smoke it to check but nothing has really changed. Maybe I split something...
Old 12-28-2018, 12:22 PM   #6
lummert
lummert's Avatar
Boost leak? Once upon a time I forgot to check the tightness of a clamp on the hose from the turbo to the intercooler on my 88 765. First time I pulled out to pass a car the car fell flat on it's face. Idled fine. That wouldn't be this cars first boost leak.
Old 12-31-2018, 05:59 PM   #7
shellshock
Below, is a photo of Clay
shellshock's Avatar
I know it sounds petty, but check the two ground leads that bolt up to the retaining bolts for the fuel rail.
1988 740 Turbo
2005 S60R M66 flashcama
2007 XC90 V8 Sport
1983 SAAB 900 Turbo
shellshock is offline   Reply With Quote
Old 01-01-2019, 10:47 AM   #8
mark244turbo
mark244turbo's Avatar
Install the 470 cc/min injectors before you kill your engine! With the stock injectors and a large AMM you are running way too lean.
012 AMM, LH2.4 and 470cc/min injectors should work fine.
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 01-08-2019, 07:57 AM   #9
105Charlie
I fitted them and everything was a little better - still stalling when coming off throttle though!
I'm currently running the flametrap through to a catch can with a filter out... could not running this back into the intake be causing this? I'm putting the same amount of vacuum as before though.
Old 01-09-2019, 08:31 PM   #10
towz-T
EL hipo explosive
towz-T's Avatar
still under boost as well?
could be TPS related...
and is idle valve working like it should?
but i'm only guessing
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 01-10-2019, 01:08 PM   #11
105Charlie
I cleaned out the idle valve recently, seems fine and opens and closes quick. It still has a slight hesitation sometimes under boost but that might be something to do with my boost controller's boost cut. I will test that.
Main issue is still that when I come off throttle it stalls. If I come off the throttle slowly it seems fine, just when I come off quick to say change gear.
Old 01-10-2019, 01:34 PM   #12
towz-T
EL hipo explosive
towz-T's Avatar
WhatsApp type of boost controller?
Old 01-10-2019, 02:03 PM   #13
105Charlie
What type? It's a LDperformance, small company in UK. Electric, works great, just wonder if it was spiking and hitting the cut
Old 01-10-2019, 06:48 PM   #14
towz-T
EL hipo explosive
towz-T's Avatar
Sorry, mobile phone spellcheck hates English. Could be something over there, maybe wastegaten isn't doing it's job and/or for some reason you are getting a lot of backpressure. Have you tried without it?
Old 01-10-2019, 07:03 PM   #15
Pro Sneaker Peddler
This usually happens when the throttle idle switch is not adjusted properly and/or there is a bad connection.
Old 01-11-2019, 04:59 AM   #16
crogthomas
crogthomas's Avatar
Have you checked the rubber hose between turbo and air filter? They go soft with age and oil contamination and then get sucked flat under load.
crogthomas is offline   Reply With Quote
Old 01-11-2019, 08:30 AM   #17
105Charlie
New 1BAR actuator on, all tested and worked fine when I put it on. Would be surprised if this is it but something to try.
I will check this, was adjusted correctly but connection could be bad as I did rewire.
Brand new silicone hose on there and is fine under boost, it's once I let off it dies.
Old 01-11-2019, 08:35 AM   #18
JanP
JanP's Avatar
Probably torn compressor bypass valve.
-92 240 Wagon
JanP is offline   Reply With Quote
Old 01-11-2019, 09:23 AM   #19
105Charlie
I was thinking this, I did have it off recently and it appeared fine though. Also sounds as if it's working pretty strong.
I will pull it off and take a look, I suspect a stronger one would be better anyway considering I'm running more boost.
Old 01-11-2019, 10:13 AM   #20
Fa182
Stage 1
Fa182's Avatar
So just to be clear, the stalling appeared right after swapping the turbo or was it with the old turbo on as well? Also, was the turbo swap the only thing you changed before the stalling appeared or did you do anything else along with it?
That sounds very reasonable, the diaphragm could have a tiny pinhole in it which would be hard to spot. Have a look at it again and inspect thoroughly, as it's off very quickly.
Old 01-11-2019, 10:29 AM   #21
105Charlie
Only after the new turbo went on, perfect before that. Done some general tidying up with wiring and water lines as it's an engine conversion but nothing that should have caused this. Also now running an 012AMM and 470cc injectors but have tried swapping back to original and no better!
I will check the recirc and update
Old 01-11-2019, 02:26 PM   #22
Pro Sneaker Peddler
If you have a hard time checking, set up a timing light. If timing jumps from base (10-15*) to 25-30* as soon as you crack the throttle, then all is well. Otherwise...no.
Old 01-12-2019, 10:47 AM   #23
classicswede
Volvo upgrades
Common issue if not still using the original BOV
