Old 12-27-2018, 09:24 PM   #1
themidnightgarage
Default Boost won't go above 0.6 bar
Hi guys,
So i have just installed a boost controller onto my b230fk (13c) and can't get above 0.6 bar.
I have installed the device correctly by my knowledge.
Fully turned down the boost cauge gives me a 0.2 ish reading. But no mather how much i unscrew the controller above 0.6 it wont go.
Now because is can control it below 0.6 bar i think the device is applied correctly.
My knowledge about turbo engines is inssufficient to know where to look for this problem.
One of my friends suggested a leak somewhere but i just dont know.
Hope someone has an explanation.
Cheers.
themidnightgarage is offline   Reply With Quote
Old 12-27-2018, 09:34 PM   #2
2turbotoys
Salaminizer
2turbotoys's Avatar
What type/brand boost controller? and a leak in the hoses feeding it will be a serious problem with building boost.
1991 740t RIP at 320K, dam rust...
2006 V50 T5 AWD Eurosport Tuning Stage 1 kit, downpipe, intercooler
Old 12-27-2018, 10:15 PM   #3
J2_
J2_'s Avatar
Met een beetje pech is de wastegate helemaal weggesmolten in het turbinehuis.. gebeurd helaas wel vaker.
Eerst even kijken of je wel voorspanning hebt op de wastegate actuator.
J2_ is offline   Reply With Quote
Old 12-27-2018, 10:22 PM   #4
2turbotoys
Salaminizer
2turbotoys's Avatar
That didn't translate well:
With a bit of bad luck the wastegate is completely melted away in the turbine house .. unfortunately happened more often.
First check whether you have a pre-tension on the wastegate actuator.
Pretty sure the wastegate isn't melted away. If you were making stock boost levels before the boost controller install the pre tension is probably fine.
Old 12-27-2018, 11:00 PM   #5
soclosenotnear
If it's a ball and spring type mbc, like mine, you should be screwing it in to build more boost.
Old 12-27-2018, 11:45 PM   #6
A cracked/melted turbine housing is very likely.
Pull the down pipe and inspect.
Even with my wastegate hose disconnected my 13c would only make about the same- melted/cracked housing was the prob. It's very common.
Old 12-28-2018, 10:44 AM   #7
gsellstr
gsellstr's Avatar
Leaking hoses to the controller or wastegate will result in higher boost than expected, not lower. No boost to open the actuator, actuator stays closed, boost builds.
I'd check actuator setup, make sure the pretension is correct first. Follow that up with CHECK FOR BOOST LEAKS. Cracked intercooler, leaking hose or coupler, both not uncommon.
Cracked or melted turbine housings aren't uncommon on these cars either.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 12-28-2018, 10:57 AM   #8
2turbotoys
Salaminizer
2turbotoys's Avatar
I didn't know that about the 13c, guess I never left one in long enough haha
Old 12-28-2018, 12:13 PM   #9
lummert
lummert's Avatar
Are you running a late low pressure TD04-13c? IIRC B230FK is low pressure turbo. This turbo uses a lower rated (perhaps 4 PSI) boost actuator.
Old 12-28-2018, 01:15 PM   #10
DMFWallace
Ignoramus Bigotus
Install better turbo
Profit
'90 244 - Too many memories to crush
'92 944T - Need any 940 parts?
'96 854 GLT - Not mine any more but still in the family
'92 245 - For Sale?
'97 854R - Waiting to get fixed
'06 XC90 V8 - Family Hauler - Wifemobile
'04 XC70 - Impulse buy of the year
Feedback:http://forums.turbobricks.com/showth...ght=dmfwallace
DMFWallace is offline   Reply With Quote
Old 12-28-2018, 01:47 PM   #11
towerymt
the real Towery
towerymt's Avatar
A bleed valve...you would "unscrew" to bleed off more pressure from the hose going to the wastegate actuator, thus opening the actuator less than if it had the unmodified pressure signal.
A ball & spring valve...you would "screw" tighter to give more resistance against the pressure moving the ball bearing and allowing the pressurized air to reach the wastegate actuator to open the wastegate.
Check that all clamps are tight on the hoses. Check that none of the hoses are split or torn. You may need to remove the hoses to inspect them closely. I recently had a hose split near the battery and I couldn't see the hole, but I started noticing some oil film on the inner fender where previously it had been totally dry.
The wastegate actuator may be weak and not able to hold closed when pressure builds in the turbine housing. You could try adding some preload to the actuator if it's adjustable.
Old 12-28-2018, 04:57 PM   #12
This.
Does it have a vent to prevent residual pressure from holding the wastegate open?
Old 12-28-2018, 05:26 PM   #13
Disconnect the wastegate hose and go for a drive and see what happens. If it still doesn'tover boost, you could wire the wastegate flap shut and try again.
I am still voting damaged turbine housing.
It's also worth pulling the CBV and making sure the diaphragm isn't torn.
Old 12-28-2018, 09:58 PM   #14
gsellstr
gsellstr's Avatar
I'd guess either housing, cracked plumbing or IC.
Old 12-28-2018, 10:20 PM   #15
Plumbing leaks would likely cause stumble going into boost. I have 20 quid on busted turbine housing!
Old 12-29-2018, 03:51 AM   #16
wujek
wujek's Avatar
Lately I had the same problem. It went to 0,8 and not any further. Problem: broken pipe from idle controlvslve to intake manifold.
my '88 744+
WANTED:
-red floor mats for 7/9
wujek is offline   Reply With Quote
Old 12-29-2018, 02:15 PM   #17
gsellstr
gsellstr's Avatar
If you've got a cracked IC or a coupler that seals until a certain pressure level where it finally opens up, it would drive seemingly normal up to a point. Don't ask how I know...lol
