Old 12-28-2018, 09:41 PM   #1
Ben.N
Default Discussion about b230+t fuel system
Hi, I'll make this post short, p.s I'm a huge noob sorry if I sound stupid. I've got a b230 new rebuild with yoshifab rods, turbo cam, valve springs, custom manifolds, bigish turbo (not picked out yet), megasquirt. looking to get around 400 hp. I have brand new stock fuel pumps and lines. My question is should I look to getting a larger pump ? and what kind of fuel rail should I run? Open to any suggestions
Happy New year's!!
Ben
Ben.N is offline   Reply With Quote
Old 12-28-2018, 11:11 PM   #2
2turbotoys
Salaminizer
2turbotoys's Avatar
The stock rail should be fine, the question should be what size injectors, stock fuel pump maybe not enough. I'm sure you will hear many opinions, but if you want good ones give a few more details. Turbo size/boost, what car is it, can you tune the megasquirt yourself, etc
1991 740t RIP at 320K, dam rust...
2006 V50 T5 AWD Eurosport Tuning Stage 1 kit, downpipe, intercooler
Old 12-29-2018, 10:58 AM   #3
Marvelous3
Who engineered this?
Marvelous3's Avatar
400? So you'll be running e85 yes? I'd shoot for 1000cc injectors, bigger is okay since you're going to megasquirt. Probably a dw300 in tank pump. Stock rail should be fine.
What transmission are you planning to run?
Old 12-29-2018, 01:07 PM   #4
Ben.N
1991 Volvo 245 wagon
Tuning won't be an issue, I've been in contact with a few shops in my area with Dino's that are willing to work on megasquirt systems. I'm starting to think I should wait untill I've got most of the car ready/picked out and consult with whichever shop ends up doing the tune. Id rather the car run on pump gas so maybe I'm shooting too high with 400.
Also when upgrading the pump should I replace the one in the tank or the one next to the fuel filter? Or eliminate one and upgrade the other?
Thank you so much for you input
Old 12-29-2018, 01:43 PM   #5
Sweep
Lose the inline and go with a decent in-tank.
Old 12-29-2018, 01:55 PM   #6
Ben.N
Sounds like what I'll do. I was never a fan of having 2 different pumps.
Old 12-31-2018, 12:58 PM   #7
mark244turbo
mark244turbo's Avatar
http://www.turbobricks.com/forums/sh...ad.php?t=26083
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 01-04-2019, 02:09 PM   #8
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
if you're going to run E, get a walbro 450 out of the gate and just be done with it (get the one rated for e85 use). You'll have to upgrade the pump wiring, and you'll need to make sure/replace the sender to filter line with high pressure fuel line.
I always had pretty good luck with the stock pumps as long as they're working well and you're not asking too much of them. depending on which version of megasquirt you're running, you could tie in a fuel pressure sensor, and if it starts dropping off under load, it'll be time for an upgrade. the v8 car ran fine with the stock pumps(within reason) until the in-tank pump finally died of old age, and it'd previously been fine with the 4 cylinder 16vt setup.
Megasquirt Tuning!
Old 01-04-2019, 02:32 PM   #9
Stiggy Pop
Stiggy Pop's Avatar
there's no e85 around here...
'79 242
943 pickup
