Old 12-29-2018, 03:02 PM   #1
ht834
ht834's Avatar
Default 940 non turbo radiator fan
Hello everyone!
I have a non turbo 92+ 940 Radiator that I’m going to use in my 89’ 240 for a V8 setup.
I am trying to figure out what fan to use, can some one with the same radiator using the stock fan shroud take measurements for me?
I need to know what the depth of the fan/shroud assembly is.
Or if anyone has a recommendation of a fan to use. I have a slim fan I was using on my original 240 radiator but I like the idea of a two speed fan like the 940 has since the PCM for the v8 has a high and low fan setup already.
-Tony
ht834 is offline   Reply With Quote
Old 12-30-2018, 10:05 PM   #2
iHateVolvoPeople
If you’re using the bigger radiator, you should be able to use the stock shroud that came with the efan.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
Past:
80' 242gt m46
88' 245T m47
92' 945T AW71
94' 945T AW71
Old 12-31-2018, 05:55 PM   #3
shellshock
Below, is a photo of Clay
shellshock's Avatar
+1
1988 740 Turbo
2005 S60R M66 flashcama
2007 XC90 V8 Sport
1983 SAAB 900 Turbo
shellshock is offline   Reply With Quote
Old 01-13-2019, 07:20 PM   #4
ht834
ht834's Avatar
I made a custom alloy shroud for my original e-fan setup and since the 9 series radiator core is larger it won’t fit. I decided to make another custom one for now. Thank you for the input though
