Old 12-30-2018, 03:53 AM   #1
nickvolvo746
Default help me boost(wooooshhhhh)
1990 760 turbo
Recently installed a Circuit 7 boost controller:
turned it up to about 10-12 psi and it felt a wee bit faster or "peppy", as many of the old lady volvo owners would say. anyway. many weeks later it starts sputtering once I start making boost, so I decided to take the controller off and just reconnect it like normal and now it doesnt sputter. So, where did I go wrong? I triple checked the hoses, clamps and I feel confident I had it set up correctly. Maybe was it leaning out? Im thinking I just expect to much from an antique but also I feel that upping the psi to 10 should be ok, so perhaps the fact that it cant handle it is a sign of something else going on...
nickvolvo746 is offline   Reply With Quote
Old 12-30-2018, 07:43 AM   #2
tryingbe
Boosting along.
tryingbe's Avatar
No wideband? Get one first.
85 GLH 367whp
00 Insight mpg > yours.
Old 12-30-2018, 01:25 PM   #3
LeedomtoFreedom
LeedomtoFreedom's Avatar
Maybe you hit the boost cut.
81 264 - Driveway ornament
90 245 - becoming 16v
Old 12-30-2018, 01:37 PM   #4
Dicktater
Cretin
Dicktater's Avatar
Sounds like the intake hose is collapsing under boost.
**** off loser. I will **** you up. I back up the **** I talk. I don't back down because I am not wrong. You want some? Bring it mother****er.
Originally Posted by CaliMeatWagon View Post
I hope your treehouse gets cancer
I buy a few when foodstamps get here because I have an investment strategy.....
Originally Posted by volvo740b234/531 View Post
I smoke my weed and dream of an awesome life
Feedback >http://forums.turbobricks.com/showthread.php?t=197700
Dicktater is offline   Reply With Quote
Old 12-30-2018, 10:54 PM   #5
2turbotoys
Salaminizer
2turbotoys's Avatar
+1^ make sure intercooler hoses aren't squishy, especially the longer rubber ones. Got a boost gauge? Where does the problem start? Boost leak? Use a socket on intercooler lines, not a screwdriver.
2006 V50 T5 AWD 16 PSI +
Old 12-31-2018, 12:39 PM   #6
mark244turbo
mark244turbo's Avatar
Your antique is perfectly able to handle boost. But only if everything is in good condition.
Possible causes of performance problems:
Collapsing intake hose (replace intake hose and modify airbox to make it less restrictive)
Bad hall- or VR-sensor. They fail due to heat-stress and are located next to the downpipe!
Boost leaks (vacuum lines, intake gasket, intercooler hoses, intercooler)
Clogged flame trap/oil separator.
Clogged cat.
Dirty AMM.
Failing engine temp sensor.
Bad Knock sensor!
Detoriating engine harness (look at the condition of the cables near the injectors).
Dirty air filter, old oil and oil filter, spark plugs, non-bougicord spark plug wires.
Boost-controller (bad quality boost controller, or too soft spring inside)
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 12-31-2018, 05:54 PM   #7
shellshock
Below, is a photo of Clay
shellshock's Avatar
Yeah I bet the inlet boot is getting sucked shut. Crank her up to 12 and power stall it with the hood open and someone watching outside.
1988 740 Turbo
2005 S60R M66 flashcama
2007 XC90 V8 Sport
1983 SAAB 900 Turbo
shellshock is offline   Reply With Quote
Old 12-31-2018, 06:34 PM   #8
LeedomtoFreedom
No no no, lay flat on the open hood. watch carefully while the driver accelerates to highway speeds. It's the only way to get an accurate reading.
Old 12-31-2018, 09:08 PM   #9
lummert
lummert's Avatar
I've had all of the boost hoses on my 88 765 with B230FT go bad at one time or another from oil contamination.
Old 01-01-2019, 03:11 PM   #10
300+hp on the shelf club
In my experience a major cause of this is spark blowout from the spark plug gap being too large/spark is weak. Make sure the gap is .028" and that the plugs are new or like new. If they are copper plugs and more than a year old they are worn out and need replacement anyway. Of course it may also be that you have a couple issues so also check for the intake hose to the turbo collapsing as well as the other suggestions.
Old 01-01-2019, 04:43 PM   #11
nickvolvo746
Thanks a bunch for the responses yall, this has given me a lot of things to check. Ill try and add a wideband soon and ill check all my hoses for squishiness.
Old 01-01-2019, 04:59 PM   #12
lummert
lummert's Avatar
I've been running a set of Autolite Iridium tipped spark plugs for more that 30k miles. I took one out at 30k and it was still in good shape.
