Old 01-04-2019, 01:20 AM   #26
jillyboi940
jillyboi940's Avatar
Originally Posted by culberro View Post
Ahhh. Send it.
Pro tip, weld it inside the housing with axles in the side gears. That will keep the side gears aligned and reduce the likelihood of broken axles. Also, welding the side gears to the case will usually result in cracked welds after a while, but it’ll save the diff pin from taking all the load.
Thanks, bud. I appreciate the advice.
jillyboi940 is offline   Reply With Quote
Old 01-04-2019, 01:21 AM   #27
Originally Posted by Vincent Gagnon View Post
The best would be to seek medical help and have your head examined.
Old 01-04-2019, 01:23 AM   #28
Vincent Gagnon
Vincent Gagnon's Avatar
Old 01-04-2019, 04:54 AM   #29
A tough rowing ho
I have a weldy center section if you want it, welded up with a Miller 225 turned all the way up. $35.00 plus shipping. Horrible with wide tires but if you have skinny drifting tires it's fine. It's just funny watching people's expressions when you have to hop it into a parking space.
Old 01-04-2019, 03:02 PM   #30
jillyboi940
PM me
