Old 01-06-2019, 02:37 PM   #1
73amc
Default $500 1988 740 Budget Build
Hey guys,
Picked up a solid 88 740 turbo that needs a motor. I have one lined up that is coming out of my buddies 93 940 which is also a turbo. I've never built a volvo using volvo stuff. I have an LS swapped 240 wagon, and another wagon that I daily drive.
Once I get the motor out and back in I'd like to go ahead and play around a little with making a little more power. Say 300, not even sure if that is possible. The car is currently auto, but again once the engine is in and the car is running I think the first project will likely be a t5 manual swap.
Am I out of my mind thinking that 300whp is possible? I'll start researching solid combinations and recipes for more power, but wanted to get thoughts about my goal.
73amc is offline   Reply With Quote
Old 01-06-2019, 02:46 PM   #2
S70T5fivespeed
S70T5fivespeed's Avatar
Nice quad light turbo
99 S70T5M black on graphite suede
91 740SE white on black
90 740TI oe aero kit black
In the barn: 67 123GT
S70T5fivespeed is offline   Reply With Quote
Old 01-06-2019, 03:03 PM   #3
iHateVolvoPeople
300whp is definitely doable on the stock bottom end of the 93 engine, assuming it’s healthy. Trans will be okay too, just do the accumulator mod.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
Past:
80' 242gt m46
88' 245T m47
92' 945T AW71
94' 945T AW71
Old 01-06-2019, 03:59 PM   #4
73amc
Great news. My LS car has plenty of power. I would just like to wake the car up some. Still undecided on what I want to do with the transmission. Keep it auto or manual swap it.
Old 01-06-2019, 05:17 PM   #5
iHateVolvoPeople
Auto. Make it a nice DD.
Old 01-06-2019, 06:50 PM   #6
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Originally Posted by PromiseRing View Post
Auto. Make it a handicapped appliance.
FTFY
... LS Everything. Easy and reliable power.
#79WDP
2010 Porsche Cayenne S - DD
2010 Cadillac Escalade ESV - Wifeys ride - 194k stock
2006 Cadillac DTS - Sons ride - 193k stock mint
1979 Porsche 911SC - stock
1948 Spartan Mansion travel trailer - aluminum greatness
Old 01-06-2019, 07:11 PM   #7
Broke4speed
Broke4speed's Avatar
Pft. Clutching is for young folk.
Built autos are for men.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 01-06-2019, 08:02 PM   #8
73amc
Originally Posted by Pillow View Post
FTFY
I already have one of those. 88 245, 650whp.
Old 01-06-2019, 08:07 PM   #9
A tough rowing ho
It will be difficult to reach 300 on lh2.2 which is what I'm assuming your 88 has. You can ms or switch to lh2.4.
Old 01-07-2019, 01:11 AM   #10
sbabbs
sbabbs's Avatar
For my old 89 744 500 dollar redblock hot rod I did upgrade to lh2.4 and then put a 84 B23ft motor in it with 15g and ran 12.61 in the quarter mile with slicks. Then turned a rod bearing and put in a 90 plus big rod b230ft and ran 12.7. Getrag 265 5 speed man trans. Stock cast iron flywheel exploded during a burnout at PIR totaled the car.
Old 01-07-2019, 01:26 AM   #11
white855T
T5 trans and a 16g turbo with J pipe header.
Buyer/Seller Feedback
Old 01-07-2019, 08:34 AM   #12
73amc
This is all I want. Simple.
rod I did upgrade to lh2.4 and then put a 84 B23ft motor in it with 15 and ran 12.61 in the quarter mile with slicks. Then turned a rod bearing and put in a 90 plus big rod b230ft and ran 12.7. Getrag 265 5 speed man trans. Stock cast iron flywheel exploded during a burnout at PIR totaled the car.
Old 01-07-2019, 03:34 PM   #13
sbabbs
sbabbs's Avatar
We'll I wouldn't want my worst M-N-E that. You best get billet steel flywheel. All I run nowdays..
Old 01-08-2019, 10:15 PM   #14
73amc
Trying to get a list together of the typical things to do before I put the new motor in. So far I've been banking on motor mounts, timing belt, water pump, and the 3 seals. Is there anything else I should consider doing what I have the engine out?
Old 01-08-2019, 10:23 PM   #15
73amc
Going to do the accumulator mod to the trans as well.
Old 01-09-2019, 04:43 PM   #16
tintintin
Inspect closely the radiator and hoses. Since you are unhooking those anyway, now would be a good time to replace them if needed, to guard against future problems down the road.
Old 01-09-2019, 06:40 PM   #17
73amc
Good idea. Was wondering if it was worth my time replacing the valve gushers what I had the motor out. Doesnt look to bad to even do with the engine in, so i might skip that for now.
Old 01-09-2019, 07:49 PM   #18
iHateVolvoPeople
Nah don’t do it, waste of time
Old 01-10-2019, 08:38 AM   #19
73amc
Ok. Looks like I'll just be doing routine maintenance, motor mounts, lh 2.4 swap and accumulator mod right away.
Old 01-10-2019, 08:40 AM   #20
73amc
Would a 15g turbo be a worthwhile upgrade or not really? I hear conflicting stories.
Old 01-10-2019, 09:21 AM   #21
soclosenotnear
Yeah. Not much difference in a 15g and 16t. That's the standard "upgrade" turbo on an otherwise stock setup. I enjoyed mine.
Old 01-10-2019, 03:57 PM   #22
iHateVolvoPeople
I didn’t notice too much of a difference in my 13c vs 15g, but that’s probably because I didn’t run the 15g at very many boosts. But both turbos at 10psi felt the same to me, could also be because I got 2 or 3 bad 15Gs off the for sale section. People love selling blown turbos on this forum so be aware. I would just run the 13c that comes with the motor if it’s healthy.
Old 01-12-2019, 11:13 PM   #23
73amc
Got most of everything disconnected under the hood. All that's left are the mounts, driveshaft and shift linkage. Hoping that some of the front end comes apart to help get it out if the bay.
Can anyone give me some guidance with this engine harness? Most all the plugs are disconnected, but it seems like one giant harness with no end. What gives?
Old 01-12-2019, 11:54 PM   #24
iHateVolvoPeople
If it's anything like the 240s, most of the harness is underneath the intake manifold. You'll need to disconnect all the sensors. On a 240, you have to remove the alternator wiring and route it behind the PS/AC bracket (kind of a PITA). But on a 7 I don't think you need to since the alt is up top.
Be sure to label everything. It should be a really straight forward swap. And FWIW, I personally have never had to remove the front clip to get a motor and trans out, but I've only ever pulled motor by itself, only after dropping the trans first. Removing the intercooler and radiator will give you a few extra inches.
Old 01-12-2019, 11:59 PM   #25
89_740Turbo
89_740Turbo's Avatar
It can be done. After everything is said and done this spring with my 740 upgrades, I will be at or around 300whp.
- Chipped ECU
- Chipped EZK
- Turbocam
- Adjustable cam gear
- 3" turboback exhaust
- 19T
- Manual boost controller
- T5 trans
- Aluminum wheels
- Performance intercooler
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
My Feedback Thread - http://forums.turbobricks.com/showthread.php?t=342247
