Old 01-07-2019, 12:27 AM   #1
LeedomtoFreedom
LeedomtoFreedom's Avatar
Default Chevy rods in a Redblock ?
Currently pondering the idea of a Chevy rod in a b230. The only issue is that the big end bore isn't exactly the same. The two main Chevy sizes are 2 in and 2.1 in where I think our bore falls slightly in between.
Has anyone looked into this or have any ideas. Otherwise I'd have to either stay 13mm or look for some aftermarket stuff
81 264 - Driveway ornament
90 245 - becoming 16v
Old 01-07-2019, 12:37 AM   #2
If you can't find it grind it.
Old 01-07-2019, 01:41 AM   #3
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Nope.
The stingy man spends the most and all that.
Old 01-07-2019, 03:05 AM   #4
sbabbs
sbabbs's Avatar
https://www.ebay.com/itm/CXRacing-H-...S!-1:rk:3:pf:0
CXRacing H-Beam Connecting Rods (4 PCS) For :US $209.00
VOLVO B230 Engine
Specifications:
Rod Length: 5.984" (152 mm )
B/E Bore: 52 mm
B/E W: 23 mm
S/E W: 29.5 mm
S/E W: 25 mm
Rod Bolt: 3/8"
This Auction is for Rod x 4 pcs
Note:
Forged Aircraft 4340 Steel, Highest Level of Strength
High Performance, Supports 600 HP
Old 01-07-2019, 12:09 PM   #5
LeedomtoFreedom
Originally Posted by MDVLN View Post
Nope.
So I've heard.
Old 01-07-2019, 03:11 PM   #6
John V, outside agitator
The above are OK...but are you looking to do 8v_? 16v? Turbo? What compression...
I just happen to have some CP Pistons forged flat-top 96.5 pistons for stock rod length--152mm..
16v valve reliefs.......is that interesting???
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
