Old 01-08-2019, 01:43 PM   #1
xDread92x
xDread92x's Avatar
Default Volvo 16t turbo for plus T
Hey all,
I’m currently putting everything together for my plus t project. 90 240 b230f 300,000 miles.
I read on the forums that in order to put a 16t on a 240 you have to rotate the hot and cold housings. I would really like to get an angled flange because I know they have better flow. The problem is that when you rotate the hot side, the flange is then angled up instead of down.
Does this mean I have to go with straight flange to put a 16t on the 240? How much flow loss will I have?
Thanks
Image and video hosting by TinyPic
xDread92x is offline   Reply With Quote
Old 01-08-2019, 01:50 PM   #2
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
it means you have an angled flange, no more.
Megasquirt Tuning!
Old 01-08-2019, 02:30 PM   #3
soclosenotnear
You'll have to get a down pipe sorted either way. Either one can be made to work. You can port a straight flange out to nearly the size of an angled. In my opinion, you'll be happy either way you go.
Old 01-08-2019, 11:16 PM   #4
xDread92x
xDread92x's Avatar
Well it seems like it would be a lot more work and will affect flow with a rotated flange that’s upwards and has to be fab’d downward to complete the exhaust.
So I guess straight flange would make the most sense. I thought the 16t was just plug n play. Unfortunately they have to be clocked to fit the b230
Old 01-08-2019, 11:53 PM   #5
white855T
If you want to use the angled housing, do it. You just have to fab up the down pipe which won't be difficult. The angled housing flows slightly better but it's really negligible. The straight housing makes building the down pipe very easy.
Buyer/Seller Feedback
Old 01-09-2019, 05:39 AM   #6
Sjeng
Sjeng's Avatar
I have never seen any flow measurement or back to back dyno comparison on this matter.
The outlet on my HY35 is only 2.5".
But I guess a TD04 with a tiny tiny 45mm turbine would benefit from a 4" exit.
Old 01-09-2019, 10:43 AM   #7
linuxman51
linuxman51's Avatar
it doesn't matter, the restriction on the two housings is well before the outlet flange. Run what you got, don't sweat the details right now.
Old 01-09-2019, 10:49 AM   #8
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I used a flat housing from a 15G on my 16T, would have been a bolt in solution except that I welded a v Band flange to mine, and had to build a new DP to match.
The rotation has to do with the compressor housing and center section, not necessarily the exhaust housing.
1980 242 Turbo
2004 V70R
Old 01-09-2019, 10:55 AM   #9
xDread92x
xDread92x's Avatar
Thanks all
