Old 01-09-2019, 08:05 PM   #1
Dr.d-dizzle
Default M47/46 in a 1971 140?
Hi, i did some searching and couldn't find anything in the topic before. Now I'm sure this is a stupid question, but How hard would it be to put an m47 in a 1971 140? I have a gearbox laying around and the clutch went out on my 71 140. Figured if its not too much fabrication i might as well just put in the m47. I have a feeling the shifter placement will be the biggest issue.
Thanks!
Dr.d-dizzle is offline   Reply With Quote
Old 01-09-2019, 08:19 PM   #2
Transmission tunnel, driveshaft, mounting angle, and transmission mounts are incorrect.
Old 01-09-2019, 08:26 PM   #3
Dr.d-dizzle
Good to know! Thanks
Old 01-09-2019, 08:52 PM   #4
The tunnel is easily taken car of with one of these which I have in stock.
There was a guy in the Netherlands that was cutting and welding bell housings to correct the mounting angle. I don't know how to contact him or if he's still doing it.
If you can find one, Volvo made such a bell housing but they're very rare.
Most drive shaft shops can make a custom shaft, so that's not an issue.
Fabricating the trans mount would probably be the hardest part. That and adapting the clutch cable.
Old 01-10-2019, 12:52 AM   #5
planetman
planetman's Avatar
If you use the special transmission support bracket Volvo made for 140/164 with overdrives, you can bolt in either an M41 or M410(4 cylinder version).
Eric
Torrance, CA 90502
Old 01-10-2019, 02:34 AM   #6
sbabbs
sbabbs's Avatar
The bellhousing needed is the 1975 b20 with m46 bellhousing from a 75 240. Yeah it's rare..
Old 01-10-2019, 08:18 AM   #7
Råda
Volvoretard/Partshoarder
Råda's Avatar
1975 is still M40/M41. 1976 B20 cars has M45.
Jonas
Råda is online now   Reply With Quote
