Old 01-10-2019, 04:30 AM   #1
89_740Turbo
89_740Turbo's Avatar
Question What clutch and flywheel setup did you use for your T5?
So I was able to source a clean World Class T5 trans, but it didn't come with a flywheel. Its a 1989 T5 if that makes a difference.
What clutch and flywheel setup did you use? My goal is anywhere between 250HP to 300HP. For the clutch, I'm looking at using Yoshifabs stage 3 setup https://yoshifab.com/store/volvo-red...-3-clutch.html
Yoshi says it's good for up to 350ftlbs of torque so that is perfect and I know it will be quality. I don't know what flywheel to use though. Stock or performance.
What did you use? My car is lh2.2
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
Old 01-10-2019, 05:27 AM   #2
Happy Mew Year!!!
Call South bend clutch, they don't have a listing on their website but they have the package for a red block flat flywheel/t5 swap in the computer.
Old 01-10-2019, 05:57 AM   #3
89_740Turbo
Awesome, Ill definitely give them a call. Do you know if its stock stuff or something more geared toward performance like a light flywheel
Old 01-10-2019, 02:16 PM   #4
Happy Mew Year!!!
I'm running the Volvo flat flywheel from an M46 equipped car, the clutch setup from them is supposed to hold 280ft.lbs. It hasn't slipped or broken on me yet after 4 yrs of autocross abuse.
Old 01-10-2019, 02:30 PM   #5
JohnMc
JohnMc's Avatar
JVAB Sooooper bitching flat billet flywheel, Spec Stage 2.5 clutch and disc for a Saaaab 900 Aero (240mm diameter). It's about the biggest diameter clutch you can squeeze into a Volvo bellhousing. So it was holding 300 - 350 whp on mine with no issues, and doing it without a heavy clutch pedal either. The 2.5 disc has ceramic stuff on one side, Kevlar on the other, and a sprung hob, so it was very streetable as well (nice soft initial bite).
They still have a 'Ford T5 flange' option on their website that they added for me: http://www.specclutch.com/cars/Saab/9000/1995/Single
It's not cheap, but since I was getting the whole clutch kit from one source, if it didn't work properly, I had one place to bitch to and they couldn't deflect blame from one part to the other (it's that PP you used! It's that disc you used!).
Would that have helped? Dunno, but I never had any issues with it, it worked great.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 01-10-2019, 03:45 PM   #6
Canuck
Frozen Garage Hell
Canuck's Avatar
I'm using a Yoshi set up with a Center Force pressure plate. It's been fine for 4 years (including thousands of autocross runs). No drama.
- Craig
1966 Canadian (B5234T, C4 up front, Supra out back and a nut in the middle) http://forums.turbobricks.com/showthread.php?t=328003
1981 242 (B230FT, LH 2.4...and a few other things)
YouTube channel covering Canadian build https://www.youtube.com/channel/UCsx...n3CiBQFd4rMyXw
Old 01-11-2019, 07:37 AM   #7
Ilvmetal
I second that, no problems here,2 years of burnouts
1973 142 Turbo 8V build
1988 740 16V money pit
2004 V70R Wife's DD
2017 S60T5 Pole star ecu flash (still slow)
At any given time I have to many projects but not enough Volvos...
Ilvmetal is offline   Reply With Quote
