Old 01-12-2019, 12:16 AM   #1
xDread92x
xDread92x's Avatar
Default Turbo BOV question and Water Line for Turbo
1990 240 pursuing plus t
1. If a turbo has had the internal bov removed then would that mean I need to install a bov externally?
Also the wastegate doesn’t come with the turbo. This is okay because I have to reclock the turbo anyway with a bracket fab’d for the wastegate to fit properly. I can buy one for it.
2. For the turbo lines I have it decently understood. I understand the oil feed and return.
The coolant/water line for the 16t I can’t find much info on. What is the setup??
Thanks
Image and video hosting by TinyPic
xDread92x is offline   Reply With Quote
Old 01-12-2019, 05:30 AM   #2
soclosenotnear
2. You'll need 2 of these three hoses. One is the radiator hose that tees into the turbo water line and the other goes from the expansion tank to the radiator and tees into the turbo.
https://www.amazon.com/Volvo-turbo-R.../dp/B00LZGWDBW
Old 01-12-2019, 01:00 PM   #3
xDread92x
xDread92x's Avatar
Ok thanks sounds good.
And can anyone help with number 1??
If the internal
Bov on the 16t is removed, what will I need to do? Add a bov on the IC line?
Thanks
Old 01-12-2019, 01:05 PM   #4
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
If the internal
Thanks
Yes, if the internal bypass valve in the 16T, then it would be wise to run an external bypass valve in its place. Probably easier to fit a new internal than external. I run 17 psi from my 16T all day and it runs the stock CBV.
1980 242 Turbo
2004 V70R
Old 01-12-2019, 01:22 PM   #5
xDread92x
xDread92x's Avatar
The owner states he welded over the internal bov. Now I’m thinking I won’t be able to add an internal. I may just have to forget this turbo.
Thoughts?
Also where does the line from the bov on turbo run to?
Thanks
Old 01-12-2019, 01:57 PM   #6
Marvelous3
Who engineered this?
Marvelous3's Avatar
If the wastegate has been welded shut you'll have to run an external wastegate. So you can reclock however you want and not have to worry about a bracket for the internal gate arm.
Old 01-12-2019, 02:59 PM   #7
xDread92x
xDread92x's Avatar
Wastegate and bov are two different things. Wastegate holes are good and ready for wastegate bolt on.
BOV is welded over, bolt holes and all. So I would have to install and external bov because even with cbv it still wouldn’t run correct, right?
Thanks
Old 01-12-2019, 04:48 PM   #8
doucheNozzle
doucheNozzle's Avatar
You'll need a BOV that recircs
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 01-12-2019, 05:01 PM   #9
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
Bypass valve is welded over, bolt holes and all. So I would have to install and external bov because even with cbv it still wouldn’t run correct, right?
It will run fine without a CBV or BOV, but the turbo will flutter and "kill the turbo prematurely". I would get a newer unmolested turbo personally but you can run yours with an in-line blow off valve.
nah
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
Old 01-12-2019, 05:01 PM   #10
doucheNozzle
Originally Posted by PromiseRing View Post
nah
Snooze.
Old 01-12-2019, 05:04 PM   #11
PromiseRing
Snooze.
LH2.4 is fine with a BOV venting to atmosphere, once it learns. Please don't comment unless you have experience with the subject at hand.
Old 01-12-2019, 05:10 PM   #12
doucheNozzle
nah
Old 01-12-2019, 05:29 PM   #13
Duder
His Dudeness, El Duderino
Duder's Avatar
Check out a Bosch recirculating bypass valve like 0 280 142 110. They work well and are relatively cheap.
Old 01-13-2019, 12:05 AM   #14
thismachine13
My experience is that the LH 2.4 would stall with a BOV to atmosphere.
Old 01-13-2019, 12:11 AM   #15
PromiseRing
It can learn around it, or you can move the AMM post turbo.
Old 01-13-2019, 12:16 AM   #16
thismachine13
Post turbo is just silly and at the time it was my DD so I wasn’t going wait for it to “learn around it”. Far easier just to grab a Bosch recirc from a turbo Audi and plumb it in correctly.
Old 01-13-2019, 12:19 AM   #17
PromiseRing
I agree, I too went back with the CBV.
Old 01-13-2019, 01:01 AM   #18
xDread92x
xDread92x's Avatar
Duder or whoever, how would I incorporate this Bosch valve into my set up with turbo situation?
Thanks
Old 01-13-2019, 04:53 PM   #19
Dicktater
Cretin
Dicktater's Avatar
Thanks
Here's how I did mine, Holset hx30 and used the stock airbox.
**** off loser. I will **** you up. I back up the **** I talk. I don't back down because I am not wrong. You want some? Bring it mother****er.
Originally Posted by CaliMeatWagon View Post
I hope your treehouse gets cancer
I buy a few when foodstamps get here because I have an investment strategy.....
Originally Posted by volvo740b234/531 View Post
I smoke my weed and dream of an awesome life
Feedback >http://forums.turbobricks.com/showthread.php?t=197700
Dicktater is offline   Reply With Quote
Old 01-13-2019, 05:40 PM   #20
xDread92x
xDread92x's Avatar
Damn yea I see I’m going to have to fab some openings coming off the AMM plumbing and IC plumbing to set up this valve. Where does the small vacuum line go to?
Old 01-13-2019, 09:07 PM   #21
doucheNozzle
Intake manifold.
There was a couple of years of 740s that had Garrett turbos. You can get those components. Or just get a new compressor housing.
Old 01-13-2019, 10:14 PM   #22
xDread92x
xDread92x's Avatar
Ok guys so I got ahold of a 13t turbo for 60$. It has the wastegate and internal BOV.
With that being said, where do the lines need to run from each?
Also, will I have to reclock this for the 240 and 90+??
Thanks
Old 01-13-2019, 10:17 PM   #23
PromiseRing
Thanks
What do you mean? Headlines or vacuum lines? Bypass valve needs a line running to intake manifold. Wastegate actuator needs a smaller short line running from compressor housing.
And yes, it needs to be re clocked if it’s not in the same orientation as the stock one.
Old 01-13-2019, 11:17 PM   #24
xDread92x
xDread92x's Avatar
What nipple on intake for BOV?
Wastegate to where on compressor housing?
I’m also having trouble finding the water hard lines that connect to turbo. I know about the hose set up kit but I’m talking about the actual hard line feed and return.
Thanks
Old 01-13-2019, 11:21 PM   #25
PromiseRing
Thanks
Doesn’t matter which nipple the CBV goes to on the intake manifold as long as it fits tightly and is post throttle body.
The wastegate line should go from wastegate to nipple on the compressor housing. Let me find a pic..
And I could definitely be wrong but I think the hard lines are the same for coolant on the 13t and 13c..but you’ll have to check.
I went with all custom feed and return so I can’t helo much there, though I would think that they are the same as long as the CHRA is in the same orientation as a stock 13c. I’m also almost positive that the thread pitches are all the same. But again, someone else needs to clarify.
Edit: post number 12 in this thread, you can see the small black line on the compressor housing going to the wastegate actuator
http://www.turbobricks.com/forums/sh...d.php?t=173725
