hdBattousai
- Oct 21, 2013
- Chandler, AZ - Benchracing
**NOTE: I'm currently holding off on the final engine build and am temporarily gonna +T for 160-175hp to get my hands dirty and learn more***
Hey all i'm finally getting somewhere with some money and means to do my project so figured i should post a build thread and try to get some help for the next steps. I have a 92 244 that's been pretty good to me so i pretty much wanna rebuild the thing from the ground up as time goes on as a Daily driver with offroad tones.
Probably have about 3-5k to invest in the engine alone over the next year, I don't mind spending a bit more though for a solid reliable engine that's pretty much rebuilt to new with strengthened internals. After the engine i will tackle the rest of the drivetrain/gearing/trans etc. just starting with the engine for now as I learn.
Have in it:
ipd pre pump upgrade
ipd 24 sway
modified aw71
-<del>Accumulator mod</del> found out it doesn't have it yet so have to do
-Full Nolene Kevlar clutches
-2,100 RPM stall (will upgrade to 2.5-2.8k when I swap engine)
-Valve Body porting
Zimmerman slotted front rotors with the green ceramic pads
New Stock Struts
Nissens radiator (will upgrade to performance when dropping in new engine)
diesel engine mounts
Weight Reduction (in progress still, stripped out trunk interior, rear seat, most of interior, )
IPD Performance Spark Plug Wires
Have For it:
'84 b23e
All poly bushings
RSI Stage 2 turbo cam
90+ Manifold
530 Head
3.73 g80 (eventually will swap for Toyota 4 Runner axle)
IPD Alluminum Belly pan
upper strut reinforcement plates
A/C Delete bracket
<del>42lb green giant knockoff injectors</del> returned
<del>IPD Performance Spark Plug Wires</del>
33lb Bosch white tops for now
Plan to get/do:
Megasquirt
squirterize the block
3" Downpipe and mandrel bent exhaust with high flow cat
IPD GT strut braces
Adjustable torque rods
upper strut reinforcement bar
SS Brake lines
Stoptech powerslot Rear rotors
IPD Adjustable Cam Gear
IPD Lower Chassis Tie bars
IPD Adjustable panhard bar?
New High Quality Lights and light assemblies
Fog/Offroad Lights
Wheel Bushings
Blue interior LED's
Lightweight windows
2 Fuel 12 gal cells mounted in trunk inside additional enclosure
Basic Aluminum Rollcage to assist with body roll
E-Fan Conversion
Hydraulic E-Brake?
Sequential Manual Transmission?
Add Lockup to Trans
Add external cooler to Trans
Getting another already ported 530 head, a enem v15 turbo cam, 16T turbo
Current To Do List:
Rebuild Engine
Accumulator mod
LEARN LEARN AND LEARN SUMOR'
Old Pic
Newer Pic
Partially gutted interior
A Few Random Goodies
The Engine
Have in it:
ipd 24 sway
modified aw71
-Valve Body porting
New Stock Struts
Have For it:
'84 b23e
All poly bushings
90+ Manifold
530 Head
A/C Delete bracket
Plan to get/do:
Megasquirt
IPD GT strut braces
SS Brake lines
Fog/Offroad Lights
Wheel Bushings
Blue interior LED's
Lightweight windows
E-Fan Conversion
Hydraulic E-Brake?
Add Lockup to Trans
Current To Do List:
Rebuild Engine
Accumulator mod
Old Pic
Newer Pic
The Engine
