Old 01-04-2020, 04:37 AM   #1
James M
Bored member
James M's Avatar
Default Is this head destroyed
Reusing this thread since it fits, torn down the 160 head from "Matcha" to find 2 broken valve springs, lots of rust and the usual cracks between valve seats. #1 has cracks showing in the ports, 2-3-4 only in the chamber. Any use working with this head or should I case down a better one without rust stuck to it and cracks?
20200704-155133
20200704-155134
20200704-155233
Current Bricks:
1989 245+t Now with actual FT
1988 245 Gramma gets to drive this one
1983 242 I need more BEIGE
Don't let me get another
1976 245, "Matcha" green, will be restored to stock
1984 245, Flaxon Yellow beute that I didn't know I needed
James M is online now   Reply With Quote
Old 01-04-2020, 05:19 AM   #2
Old 01-04-2020, 05:46 AM   #3
James M
Bored member
James M's Avatar
Practice head it is then. Maybe ill mess with the chamber but likely just for the hell of it
Old 01-04-2020, 07:31 AM   #4
Lankku
Lankku's Avatar
Doesn't look too bad. Just grind the sharp edges and send it. Though check the valves and seats, there might be aluminium pieces and they won't seal.
245 -90 "B6284T"
Old 01-04-2020, 07:45 AM   #5
KwikBrik245
KwikBrik245's Avatar
agreed. grind down any protrusions on the head and maybe replace that piston (or grind down any protrusions). my biggest concern would be the valves and seats after that. The damage definitely isn't pretty or ideal, but I know we've all seen worse.
Wanted:
245 Cargo cover (preferably blue or black)
KwikBrik245 is offline   Reply With Quote
Old 01-04-2020, 02:39 PM   #6
2manyturbos
I wouldn't be the slightest bit concerned about re-using that head. Have it skimmed to clean it up. Have a valve job done at the same time and you'll have a nice reconditioned head.
Old 01-04-2020, 05:16 PM   #7
Turbo3er
definitely, take it to a machine shop, have the head milled and valve job done. I would recommend doing any porting work before hand, and have the machine shop clean, do a valve job, and mill the head. no little sparkly bits inside the engine
2016 Dodge Challenger R/T Scatpack
2006 Chrysler 300C
1999 Dodge Ram 2500 Cummins
1987 BMW 325 PnP MSnS w/HEEBSPEED Tune
2008 H-D VRSCDX V-Rod 11.867 @ 113.86
The Departed
2009 Dodge Ram 3500
Turbo3er is offline   Reply With Quote
Old 01-04-2020, 06:30 PM   #8
Dirty Rick
Dirty Rick's Avatar
Inspect the valves and seats, clean off any aluminum, knock off the sharp edges and send it.
If you have plenty of disposable income take it to a head shop.
But first does any spray cleaner leak past the valves?
Check your turbo for any damage from piston bits....
Old 01-04-2020, 08:13 PM   #9
When stuff like that gets too deep in the head surface. It is repaired by welding and then the head is surfaced. I had a shop do that to save a 531 head.
Old 01-04-2020, 10:37 PM   #10
gsellstr
gsellstr's Avatar
Yup, take it to a machine shop, easily reusable. Jump in on the valve GB, throw some nice valves and a little porting time into it as well, wake it up. Sorry, shameless plug for the valve GB going now...
That sucks man, glad you got a little time on it first. Definitely need more fuel for that setup though, 42's on that setup is pretty small.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 01-04-2020, 10:44 PM   #11
122power
dude
122power's Avatar
[QUOTE=James M;6029563]Question first then story time for my own entertainment: Is this head destroyed beyond usefulness?
20200102-224708
I've seen some some pictures of ported heads with some of the material edge of the combustion chamber removed, specifically the ones from John V.
Volvo-Evo-2-807
Thats more than just material removed. That chamber was filled in and reshaped and maybe longer valves installed. Looks like a sbc chamber on the good heads that are out there. The volvo chambers are so deep, its like a bathtub, lol
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 01-05-2020, 12:27 AM   #12
Turbo3er
I'd say that would have to depend on how deep the gouges in the head are, and how much you can actually take off the head. If you have the room to take off the head, trim it up, close up the chamber a bit and bump the compression a little at the same time.
Old 01-05-2020, 02:56 AM   #13
James M
Bored member
James M's Avatar
I don't think I can grind down this damage
20200104-224609
I checked the turbine wheel and its not damaged, nothing made it out of the chamber luckily. Ill tear the head apart later and check the seats and valve faces, but likly just use it as practice. Luckily I had a 95 b230ft Ide been waiting to put in so I dont have to make any of these parts work.
Time for more boost:
20200104-223646
Old 01-05-2020, 02:59 AM   #14
James M
Bored member
James M's Avatar
I'll have to checkout the GB for those, I've seen it but never been in ready to buy them, sure am now.
80lb injectors should be here soon? Ordered on the 28th from Toronto, UPS ground without tracking so Ive been checking the mailbox every time a truck passes.
Old 01-05-2020, 03:08 AM   #15
122power
dude
122power's Avatar
Dude thats Knarly! Got melted. Cool picture though!
Old 01-05-2020, 03:18 AM   #16
JohnLane
That one tried to warn you.
Opportunity knocks..... Forged pistons and H-Beam rods are the clever way to solve weak stock bits.
Better engine management with more charge cooling will do wonders for keeping it happy while making lots of power in the future.
Old 01-05-2020, 03:36 AM   #17
James M
Bored member
James M's Avatar
Your signature suits this recommendation. Definitely thinking about building a motor next time, but I'm hoping a late model ft will do better then a skinny rod with 300k on the clock. Charged air temps are pretty low with my new intercooler, but not running tiny injectors and waiting more then 3 miles after reconnecting the battery (ECU relearn) may help this one survive
Old 01-05-2020, 03:37 AM   #18
James M
Bored member
James M's Avatar
The melted piston metal in the cylinder looks like JB weld, you can see some of it ran down the bottom of the piston too. Gonna make a cool paperweight
Old 01-05-2020, 03:39 AM   #19
Jack
junkman
Jack's Avatar
Exclamation
Clean that head and run it again.
Not cool
Restore it to stock
I love you even more Jack.
Old 01-05-2020, 03:40 AM   #20
Jack
junkman
Jack's Avatar
It’s the loose but behind the steering wheel
Old 01-05-2020, 03:58 AM   #21
James M
Bored member
James M's Avatar
Couldn't be my fault, it's hard to lift when with the sweet sound of an open downpipe. Detonation just sounds like antilag and I wasn't going to let that Lexus pass me.
Not cool
Restore it to stock
Then will you give me more then 250 for it?
Old 01-05-2020, 10:41 AM   #22
mikep
The MP
mikep's Avatar
You can guarantee SOMETHING got out the exhaust.
Old 01-05-2020, 01:19 PM   #23
122power
dude
122power's Avatar
At least he blew it up for a reason and not from an oil leak.
Old 01-05-2020, 02:33 PM   #24
240240
Poobacca wil survive 2020
240240's Avatar
How much heat needs to be applied to a piston to make it like that?
Originally Posted by bobxyz View Post
I'm sure glad that our mods are protecting us from excess poop in these trying times of TP shortages....
Shoot the poop!
Originally Posted by culberro View Post
I commute daily hoping to get that sweet insurance settlement on my 244.
Old 01-05-2020, 03:48 PM   #25
gsellstr
gsellstr's Avatar
Wow, that's some nasty melting man! Tuning was definitely an issue there, big MAF, small injectors, and it was probably maxed out on the fuel side when that happened, given the turbo and boost levels you're running. Makes my valve failure seem tame. lol
