Old 06-24-2019, 08:13 PM   #1
240sleeper
240sleeper's Avatar
Default Strut Swap?
How much different are the 240 and 7/940 series cars? Would it be possible to run a 240 strut in the 940?
Originally Posted by Mr.bigTurboMan View Post
wtf is this website
If you aren't for us, you're against us.
If you're against us, you're one of us
240sleeper is offline   Reply With Quote
Old 06-24-2019, 09:52 PM   #2
mikep
The MP
mikep's Avatar
940: Longer tube, higher spindle position, different steer arm position, don’t know about the base (ball joint) pattern.
(From memory)
Originally Posted by leecatd8209 View Post
Being dead has a funny way of messing up your small business, too.
Old 06-24-2019, 09:56 PM   #3
GSWAGON
my other ride is a exmark
todd16psi ran 240 strut tubes in his 740 wagon with R brakes back around 2004
87 765 GS Wagon LT4/T56 13.1@111
90 740 Turbo M46
90 780 Bertone Turbo
99 SL500 AMG Sport
08 Corvette JSB LS3 6 speed
08 Escalade AWD- wifes daily
15 Ram CCSB Hemi 4wd
Life is short, so live it! You are only old when your dreams are replaced by regrets.
GSWAGON is offline   Reply With Quote
Old 06-25-2019, 04:14 AM   #4
Lankku
Lankku's Avatar
donít know about the base (ball joint) pattern.
(From memory)
Completely different.
245 -90 "B6284T"
Old 06-25-2019, 04:22 AM   #5
Tangentially related
https://shop.klracing.se/sv/artiklar...mskit-240.html
Old 06-25-2019, 11:09 AM   #6
240sleeper
240sleeper's Avatar
This is partially why I want to run the 240 struts. Because nobody currently makes a quick steer roll corrector and R brake caliper adapter that works together for 7/900 series . Iím looking at shortened 240 struts
Old 06-27-2019, 05:13 PM   #7
mikep
The MP
mikep's Avatar
Thatís right, 4 bolts vs 2.
Wilwood rotors are available for taurus (same pattern), and those calipers are yuuuge.
The police/taxi 940 brakes are plenty. I might test-fit willwoods on those.
Old 07-02-2019, 11:56 AM   #8
Dann sind wir Helden
A police 940? Perfect for napping!
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 07-03-2019, 07:34 PM   #9
240sleeper
240sleeper's Avatar
I already have R calipers so I kind a want to run them. I might just not run the quick Steer roll corrector
Old 07-11-2019, 05:58 AM   #10
roastyleg
Why canít you run r calipers and the quick steer together on 740 struts??
roastyleg is offline   Reply With Quote
