#26 | |
![]() Quote:
Now I have a Bosch 044 inside a surge tank in the trunk, fed by a Facet low pressure pump in that same cradle. It fixed the issues with the old setup (BAD fuel starvation in corners, and just running out of fuel pressure at high boost/rpm). But it's not perfect. The surge tank gets almost too hot to touch, which hasn't been a problem, but I sure don't like it. Rev 3.0 will probably be a custom or modified stock tank that fits the Bosch 044 inside. The only reason the fuel system is tricky on these cars is because there's no in-tank pump. 240 people have it all figured out. |
#27 |
![]() That's really good information - thanks. Once this is (re)running I hope it's fun enough that it's a race between me blowing up the M41 (or the spare), the fuel system, or swapping out the narrow rods.
One symptom during the last round was a bad throttle bog and when that cleared it was an easy pull to redline. I had the injectors flow tested a few years ago and discovered one was leaking pretty bad. My (hopeful) suspicion is I was fouling a plug and then once that cleaned off it'd go. That said, I always wondered if I was asking too much of the gravity feed.
'71 142E, M41, Corbeau GT seats, iPd bars and springs, Nardi wheel, GT gauges, overmatched KYB Gas-A-Justs, Canisto wheels, 7" and Series 175 Cibies '95 T5-R, yellow, M56H swap |
#28 |
![]() What radiator is that? Where did you get it? And is there any chance you've got photos of how you had to adapt the car to get it to sit where you have it?
I have no idea what I'm doing. |
#29 |
Turbo, what?
![]() Cool car. Do you have a close up of the fuel rail mounts and injectors? They look nice and very close to(or in?) the flange!
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 Endurance Racecar - The General's FB page - Oregon Volvo Tuners - Died ![]() |
#30 | |
![]() Quote:
Griffin Aluminum Drag Race Radiators 2-25185-X Dorman 926-278 Radiator Mount Bushing ![]() This shows the foot of the radiator with the bushing. This mounts on a plate screwed onto some sheetmetal and frame rail (via rivnut) with a pin pointing upwards to locate the bottom. ![]() On the top are two little brackets that go from bosses on the the radiator to the original upper radiator mounts. These are galvanically isolated on the radiator side with some flange washers. Last edited by joel142; 05-05-2020 at 12:19 PM.. |
#31 | |
![]() Quote:
#32 |
![]() Thanks. If I could weld aluminum it would be even better to weld the pin onto the bottom of the foot, flip the rubber bushing upside down, and drop the bushing into the frame rail (it's a 3/4" hole as I recall). That would save you building a part and reduce the stack. Any way to make things smaller in a 140 bay makes things better.
#33 |
![]() ![]() I think this was in a different thread but this shows all the coolers mounted up. They each have about 0.25" of space between them. When planning the stack up I put them all together with thin plywood between them and two big bar clamps holding it together. I don't think I could get it any farther forward. The lower right ear of the oil cooler actually interferes slightly with the headlight trim so trimming that is on the to-do list. |
#34 |
![]() Looking at the photos (and reading the descriptions again) I was wondering what your plan was for when you have to change the accessory belts.
It looks (emphasis on looks... might not actually be) like your oil lines go through that opening between the pulleys, but captures the belts once they're attached to the remote filter housing. |
#35 | |
![]() Quote:
If past performance is any indicator of future results I can expect to change the belts and oil filter once a decade. Last edited by joel142; 05-04-2020 at 08:42 PM.. |
#36 | |
![]() Quote:
The fuel rail itself is affixed to a couple little brackets that are attached to the head using the k-jet bracket screws. Those are really simple: a steel tab behind the rail, a bit of 1/4" round stock, and another tab screwed onto the head. Seems nice and firm. |
#37 |
![]() ![]() I'm getting geared up to do the exhaust. This shows the Yother flange and a 16* cut that unwinds the angle and places the outlet perpendicular to the ground. The intent is to do this in 3" mild steel. I'm still on the learning/exploration track with welding (120V setup, gas shielded, 0.030" wire) - does any one have any tips/tricks/advice on this? One thought I had was to use the rotary table on the mill to cut a relief (probably around 0.050") for the pipe to drop into the flange. I'm at least the downpipe away from final welding it up, but, if there are useful things to do in anticipation I'm all ears. |
#38 | ||
![]() Quote:
Mig with a 120v unit should be fine for exhaust tubing. The reason to skip between joints, and have so many tacks is to alleviate shifting from welding. Use only enough heat/amps/wirefeed rate to get and maintain the puddle. Run it an inch or so, move to a cool joint and let your last weld cool.
The Build Thread SVEA - PUSHROD TURBO! |
#39 | |
Turbo, what?
![]() Quote:
#40 |
#41 |
![]() I imagine it'll be okay. The body is glass re-inforced plastic so insulated and they should be cooled by a continuous flow of fuel. With the NiW rail getting to the connectors is just possible.
#42 |
#43 | |
![]() Quote:
The fan is SPAL VA13-AP70/LL-63A * 13"C/12V I'd forgotten all the gold plating Be Cool puts on those brackets..they do work really well. Last edited by joel142; 05-07-2020 at 12:07 PM.. |
#44 |
![]() Back when I bought the car the control cable to the thermostat was broken so I need to stop and reach under the dash to adjust the heat. When I took the B20 out it swung sideways, hit the firewall mounted thermostat, and cracked it. Heating has always been problematic with this car and bypassed for most of the years I've owned it.
I decided to better seal the back of the water pump and use this as the turbo coolant return. This is a block off plate with an -4 ORB fitting that holds the square o-ring of the coolant transfer pipe. A 3/4" NPT to -4 adapter is in the cylinder head outlet that originally fed the heater core and now feeds the turbo. ![]() ![]() ![]() |
#45 |
![]() Got the radiator in! I was somewhat surprised at how small it really is. And then I was doubly surprised when I realized I forgot to order a radiator cap.
#46 | |
Reformed SAABaholic
![]() Quote:
Is that redblock mounted vertical? Or is that the pics playing tricks on my eyes? I love the 142..... will keep following your progress. ![]()
Project "cheap thrills" build thread: http://forums.turbobricks.com/showth...67#post4211467 Feedback thread: http://forums.turbobricks.com/showthread.php?t=198746 |
#47 | |
![]() Quote:
I just wrapped up tacking together a turbo back 3" exhaust. I still need to get hangers in and cut the downpipe at the transmission for a flange, but, it's getting closer. I'm taking a break from that and returning to the intake side. I know, it's odd those caps come separate... |
#48 | |
![]() Quote:
I'm reusing the filter from v1.0 and it was attached to the AMM in the same way with both located in a worse spot. In that system it was over by the hood hinge for maximum hot air intake. The engine ran okay with the occasional tip in stumble. I now know one injector was badly leaking, but, it could have been compounded by this or fuel flow. While not a final answer if things are behaving weirdly and the hood is still off I can add a long pipe up in that corner and put the filter on that. If it works better then I can figure something out. And, yes, the engine is mounted vertical. I'm using the original M41 transmission (for now). Amusingly, the clutch cover is the transition from imperial to metric fasteners. |
#49 | |
![]() Quote:
Looks like the radiator overflow can is going to end up on the firewall as that's the last spot of space I have. If I end up needing a crankcase catch can maybe that bracket can do double duty. Now I'll need to figure out where I can put the rivnuts... |
#50 |
LH-Jet & Carb Free Zone
