Old 11-04-2020, 11:11 AM   #1
Jussi Alanko
Default Optimum intercooler piping size?
What is optimum size for 4-500hv redblock?
I know that at least 800hp is taken out with 2.5" ic pipings.
But i put a 70mm tb to intake, and it's outer diameter is exactly 3", But holset hx40 super's compressor diam. is 60mm, also i'm looking for do88 intercooler, which is designed in stockholm and they have taken measurements of this intercooler too:
This ic has also a 60mm pipings.
So i I thought 60mm is enough, but is it?
who can calculate airspeed in 60mm pipe at 2.1liter engine at 7200rpm (limiter).
If airspeed exceeds 0.4mach flow resistance will go up very quickly. I think that optimum will be something about 0.3mach. I have read this somewhere, but i can't remember now where!
Flow must be laminar in every cases, if pipe is too small flow goes turbulent, and if pipe is too big then also flow go to laminar to turbulent.
opinions?
Jussi Alanko is offline   Reply With Quote
Old 11-04-2020, 07:14 PM   #2
90volvo
This has been discussed before. I believe it was said that 2.5 is more than enough. Im setting mine up with 3 inch intercooler piping. Search in google, I believe you will find the info your looking for.
B230ft rebuilt -8.8 comp. -Stage 3 rsi cam
3 inch ex.-GTX3076r turbo ballbearing.
ebay intercooler-3 inch IC piping- Oil cooler with 10an hose.
port stock intake (weak, having a custom intake by viking fab.)
Megasquirt 2-1300cc injectors (running E85)
530 head with big valves ported and assemble by culberro
Old 11-04-2020, 07:19 PM   #3
Use the pipe diameter that makes the most sense in terms of size changes and transitions. Don't overthink it.
Old 11-04-2020, 07:42 PM   #4
Jussi Alanko
You are righ't i'm clearly overthinking this thing, but i wan't all areas of this engine build to be optimum.
Now, i'm thinking that i use 60mm tubing, it's 2.36", i find this chart at internet.
if i have calculated airflow right my engine uses about 550cfm air at 2.5pressure ratio, and if this chart was right it means that in max speed and pressure airspeed in intercooler piping is something about 0.24mach, which is very good airspeed, flow stays laminar and doesn't exceed 0.4mach limit, after that limit flow restriction growhts rapidly.
